Home » Eclipse Projects » Dali » Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS"
Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #434451] Fri, 08 June 2007 10:23 Go to next message
- Eclipse 3.3RC2 (Build id: I20070525-1350)
- WTP 2.0RC2 (complete)
- Java 5 Update 11
- JBoss 4.2.0GA
Hello, everybody!
I'm getting the following error at design time in an EJB 3.0 project:
This table, GE_FUNCIONARIOS, exists in my database. This is the content of
my
persistence.xml file:
<persistence version="1.0" xmlns="http://java.sun.com/xml/ns/persistence"
xsi:schemaLocation="http://java.sun.com/xml/ns/persistence
http://java.sun.com/xml/ns/persistence/persistence_1_0.xsd">
<persistence-unit name="laboratorio-informatica">
<provider>org.hibernate.ejb.HibernatePersistence</provider >
<jta-data-source>java:/LaboratorioInformaticaDS</jta-data-source >
<class>br.urca.www.laboratorioinformatica.entidade.Funcionario </class>
<!-- other classes -->
<properties>
<property name="hibernate.dialect"
value="org.hibernate.dialect.HSQLDialect" />
<property name="hibernate.hbm2ddl.auto" value="create-drop" />
</properties>
</persistence-unit>
</persistence>
And this is the configuration of the datasource referenced in the element
<jta-data-source> in the file
C:\jboss-4.2.0.GA\server\default\deploy\laboratorio-informat ica-ds.xml:
<!-- $Id: mssql-ds.xml 61002 2007-02-28 16:13:00Z weston.price@jboss.com $
<datasources>
<local-tx-datasource>
<jndi-name>LaboratorioInformaticaDS</jndi-name>
<connection-url>jdbc:sqlserver://SERVDEG;databaseName=DBTESEUS</connection-url>
<driver-class>com.microsoft.sqlserver.jdbc.SQLServerDriver</driver-class >
<user-name>MARCOS</user-name>
<password><!-- there's a valid password here --></password>
<!-- corresponding type-mapping in the standardjbosscmp-jdbc.xml
(optional) -->
<metadata>
<type-mapping>MS SQLSERVER2000</type-mapping>
</metadata>
</local-tx-datasource>
</datasources>
This datasource configuration is valid as the server doesn't report any
problem
about it when it is started.
This is my mapped class:
package br.urca.www.laboratorioinformatica.entidade;
import javax.persistence.Column;
import javax.persistence.Entity;
import javax.persistence.Id;
import javax.persistence.Table;
@Entity
@Table(name = "GE_FUNCIONARIOS") // Error message is here
public class Funcionario
private String fMatricula;
@Id
@Column(name = "MATRICULA")
public String getMatricula()
return fMatricula;
public void setMatricula(String matricula)
fMatricula = matricula;
So, I would like to know what I'm doing wrong to get this error and how
I solve it.
Thank you.
Marcos
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #434452 is a reply to message #434451] Fri, 08 June 2007 15:40 Go to previous messageGo to next message
Hi Marcos,
The JPA Tooling uses the chosen DTP connection to determine what is valid
in your Entities. It looks like MARCOS is the user name of your
connection and therefore the default schema. Are you able to browse this
schema in the Data Source Explorer?
Also, click on the Schema combo box in the Entity UI in the JPA Details
View and see if there are other schema choices displayed.
Neil
> - Java 5 Update 11
> - JBoss 4.2.0GA
> Hello, everybody!
> my
> <properties>
> </properties>
> </persistence-unit>
> </persistence>
> C:jboss-4.2.0.GAserverdefaultdeploylaboratorio-informatica-d s.xml:
> <datasources>
> (optional) -->
> <metadata>
> </metadata>
> </datasources>
> problem
> @Entity
> @Id
> return fMatricula;
> I solve it.
> Thank you.
> Marcos
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #434455 is a reply to message #434452] Mon, 11 June 2007 09:35 Go to previous messageGo to next message
Hello, Neil!
> It looks like MARCOS is the user name of your connection and therefore the
default schema.
Yes, MARCOS is the user name of my connection. I just didn't know that
would be
the name of the default schema. Here is my connection settings:
Database.: DBTESEUS
URL......: jdbc:sqlserver://SERVDEG;databaseName=DBTESEUS
User name: MARCOS
Password.: ---
> Are you able to browse this schema in the Data Source Explorer?
Yes, and it is connected there. The Data Source Explorer shows:
Databases -> SQL Server (Microsoft SQL Server v. 8.0.2039) -> DBTESEUS ->
Catalogs -> DBTeseus -> Schemas
There are other Catalogs too other than DBTeseus, but there's nothing
under Schemas.
> Also, click on the Schema combo box in the Entity UI in the JPA Details View
I have to say that the project where are my entities is not a JPA Project,
but
an EJB Project. But I choose to the JPA Development perspective and there's
nothing in the JPA Details View, only the message
"Details are not available for the current selection", even though I'm
with the
entity Funcionario selected in the Package Explorer and in the editor.
However,
the entity is listed in the JPA Structure, but when I click on it I get a
dialog
with this error message:
An error has ocurred. See error log for more details.
Reason:
java.util.NoSuchElementException
and the .log file reports this for the error:
!ENTRY org.eclipse.jface 4 2 2007-06-11 10:23:48.468
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
at
org.eclipse.jpt.db.internal.DTPDatabaseWrapper.getDefaultCat alogName(DTPDatabaseWrapper.java:197)
at
org.eclipse.jpt.ui.internal.mappings.details.CatalogCombo.po pulateDefaultCatalogName(CatalogCombo.java:243)
at
org.eclipse.jpt.ui.internal.mappings.details.CatalogCombo.po pulateCatalogCombo(CatalogCombo.java:223)
at
org.eclipse.jpt.ui.internal.mappings.details.CatalogCombo.do Populate(CatalogCombo.java:197)
at
org.eclipse.jpt.ui.internal.details.BaseJpaController.popula te(BaseJpaController.java:69)
at
org.eclipse.jpt.ui.internal.mappings.details.TableComposite. doPopulate(TableComposite.java:111)
at
at
org.eclipse.jpt.ui.internal.mappings.details.EntityComposite .doPopulate(EntityComposite.java:185)
at
at
org.eclipse.jpt.ui.internal.details.PersistentTypeDetailsPag e.populateMappingPage(PersistentTypeDetailsPage.java:223)
at
org.eclipse.jpt.ui.internal.details.PersistentTypeDetailsPag e.populateMappingComboAndPage(PersistentTypeDetailsPage.java :216)
at
org.eclipse.jpt.ui.internal.details.PersistentTypeDetailsPag e.doPopulate(PersistentTypeDetailsPage.java:179)
at
org.eclipse.jpt.ui.internal.details.BaseJpaDetailsPage.doPop ulate(BaseJpaDetailsPage.java:52)
at
at
org.eclipse.jpt.ui.internal.details.BaseJpaDetailsPage.popul ate(BaseJpaDetailsPage.java:47)
at
org.eclipse.jpt.ui.internal.views.JpaDetailsView.setCurrentP age(JpaDetailsView.java:135)
at
org.eclipse.jpt.ui.internal.views.JpaDetailsView.select(JpaD etailsView.java:60)
at
org.eclipse.jpt.ui.internal.selection.JpaDetailsSelectionPar ticipant.selectionChanged(JpaDetailsSelectionParticipant.jav a:31)
at
org.eclipse.jpt.ui.internal.selection.SelectionManager.fireS electionChange(SelectionManager.java:178)
at
org.eclipse.jpt.ui.internal.selection.SelectionManager.selec t(SelectionManager.java:157)
at
org.eclipse.jpt.ui.internal.selection.JpaStructureSelectionP articipant$StructureViewSelectionListener.selectionChanged(J paStructureSelectionParticipant.java:53)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:162)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:850)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 3)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:160)
at
org.eclipse.jface.viewers.StructuredViewer.updateSelection(S tructuredViewer.java:2044)
at
org.eclipse.jface.viewers.StructuredViewer.handleSelect(Stru cturedViewer.java:1138)
at
org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected( StructuredViewer.java:1168)
at
org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenS trategy.java:227)
at org.eclipse.jface.util.OpenStrategy.access$3(OpenStrategy.ja va:221)
at
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:388)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
I would like to have your help to solve this problem
(the error Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS")
as I'm stuck with it and unable to proceed. It seems like a simple
problem, but
the solution is getting hard to appear. Another user advised me to create
an
orm.xml file with this content:
<entity-mappings xmlns="http://java.sun.com/xml/ns/persistence/orm"
xsi:schemaLocation="http://java.sun.com/xml/ns/persistence/orm
http://java.sun.com/xml/ns/persistence/orm_1_0.xsd" version="1.0">
<persistence-unit-metadata>
<persistence-unit-defaults>
<schema>MARCOS</schema>
</persistence-unit-defaults>
</persistence-unit-metadata>
</entity-mappings>
but it also didn't help. The error message didn't disappear.
Thank you very much.
Marcos
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #434456 is a reply to message #434455] Mon, 11 June 2007 16:43 Go to previous messageGo to next message
> under Schemas.
You say there is nothing under Schemas. Are you able to browse the Tables
you are interested in mapping in the Data Source Explorer? I just want to
make sure I understand what you are seeing. It is possible that the DTP
component isn't functioning correctly for some reason.
Neil
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #434459 is a reply to message #434456] Tue, 12 June 2007 07:16 Go to previous messageGo to next message
> Neil
Hello, Neil!
Yes, in my last reply there was nothing under Schemas, but for some reason
there are now. I can see now many schemas (user names) listed there,
inclusive the "MARCOS" schema, but there is nothing in the schema folders
of the "MARCOS" schema (the same with the other schema folders). I mean
that the Tables folder under the schema folder has nothing. There are not
tables there. The same happens with the Dependencies, Stored Procedures,
User-Defined Functions and Views folders. Do you know the reason why it's
happaning and what I can do to make the tables appear?
Thank you.
Marcos
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #434461 is a reply to message #434459] Tue, 12 June 2007 09:44 Go to previous messageGo to next message
Marcos,
You should take this thread over to the eclipse.dtp newsgroup so we can
get to the root of the issue. I am unable to cross post it from here, but
I recommend you take the information that we have gathered here and post
to eclipse.dtp with this information and ask for help. You can cross post
to the dali newsgroup as well. The DTP group won't be able to help you
with Dali specific problems, but can better help you specific database
metadata related issues it seems you are having.
Hope this helps,
Neil
>> Neil
> Hello, Neil!
> Thank you.
> Marcos
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #434462 is a reply to message #434461] Tue, 12 June 2007 09:51 Go to previous messageGo to next message
Neil Hauge wrote:
> Marcos,
> Hope this helps,
> Neil
Hello, Neil!
Yesterday I have already posted this issue in the DTP newsgroup.
http://www.eclipse.org/newsportal/article.php?id=724&gro up=eclipse.dtp#724
I just hope that I got some answer from there because this is very
important to me. Everything is working well, just this is getting in the
way and I can't proceed with my project until there's a solution to this.
Marcos
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #434478 is a reply to message #434462] Thu, 14 June 2007 17:04 Go to previous messageGo to next message
Marcos,
RC3 is now available, so you may want to try to see if your issues have
been resolved with changes to Dali and DTP. We have made some changes on
the Dali side that might help your situation, but since you still can't
browse tables in the DS Explorer, I doubt that Dali is going to be able to
see them.
Neil
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #434482 is a reply to message #434478] Fri, 15 June 2007 08:41 Go to previous message
Hello, Neil!
I have just upgraded to RC3 and unfortunately I still can't browse the
tables in the Data Source Explorer view. It's almost clear now that the
problem is not related with Dali, but with DTP or something that I'm doing
wrong or driver related, I don't know. I have a post in the DTP newsgroup
about this issue:
but until now I haven't got any answer from there.
Thank you, Neil.
Marcos
Neil Hauge wrote:
> Marcos,
> see them.
> Neil
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #599517 is a reply to message #434451] Fri, 08 June 2007 15:40 Go to previous message
Hi Marcos,
Neil
> - Java 5 Update 11
> - JBoss 4.2.0GA
> Hello, everybody!
> my
> <properties>
> </properties>
> </persistence-unit>
> </persistence>
> <datasources>
> (optional) -->
> <metadata>
> </metadata>
> </datasources>
> problem
> @Entity
> @Id
> return fMatricula;
> I solve it.
> Thank you.
> Marcos
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #599537 is a reply to message #434452] Mon, 11 June 2007 09:35 Go to previous message
Hello, Neil!
default schema.
would be
Database.: DBTESEUS
User name: MARCOS
Password.: ---
under Schemas.
but
with the
However,
dialog
Reason:
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
problem, but
an
</entity-mappings>
Marcos
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #599540 is a reply to message #434455] Mon, 11 June 2007 16:43 Go to previous message
> under Schemas.
Neil
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #600034 is a reply to message #434456] Tue, 12 June 2007 07:16 Go to previous message
> Neil
Hello, Neil!
Thank you.
Marcos
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #600047 is a reply to message #434459] Tue, 12 June 2007 09:44 Go to previous message
Marcos,
Hope this helps,
Neil
>> Neil
> Hello, Neil!
> Thank you.
> Marcos
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #600050 is a reply to message #434461] Tue, 12 June 2007 09:51 Go to previous message
Neil Hauge wrote:
> Marcos,
> Hope this helps,
> Neil
Hello, Neil!
Marcos
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #600120 is a reply to message #434462] Thu, 14 June 2007 17:04 Go to previous message
Marcos,
see them.
Neil
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #600142 is a reply to message #434478] Fri, 15 June 2007 08:41 Go to previous message
Hello, Neil!
about this issue:
Thank you, Neil.
Marcos
Neil Hauge wrote:
> Marcos,
> see them.
> Neil
Previous Topic:Table Generator combos in JPA Details view not populated
Next Topic:Problems closing and reopening DALI projects
Current Time: Sat Jul 19 13:48:56 EDT 2025
Powered by FUDForum. Page generated in 0.11086 seconds
