Home » Eclipse Projects » Dali » Dali EJB3-JPA tooling priorities – feedback requested
Dali EJB3-JPA tooling priorities – feedback requested [message #433691] Wed, 12 April 2006 08:28 Go to next message
In an effort to plan our final work items for the 0.5 preview release of the Dali project, we wanted to re-engage the community to help us determine what features should have priority. Following are the remaining features that we are considering for the 0.5 preview release. New feature suggestions are also welcome.
-Inheritance
-Generator Library (Management of sequence generator configurations)
-Cascade support for an Array of Cascade Types
-Support for IdClass, EmbeddedID
-Support multiple JoinColumns for association mappings
-Callback annotation support
-Support for additional EJB3 mapping annotations
-SecondaryTables
-Lob
-Temporal
-Enumerated
-MapKey
-Schema/Catalog annotation support
-Integration with Java refactoring
-Quick fixes
Also, please vote for Dali ER’s that you would like to see implemented. They can be found in bugzilla under Technology->Dali
Thanks for your help,
Neil Hauge
Dali Lead
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #433693 is a reply to message #433691] Wed, 12 April 2006 09:52 Go to previous messageGo to next message
Wow! What an open-ended request! :-) Here it goes...
First off, I don't seem to have the authority to actually "vote" on the
ER's in the Bugzilla database. So, I will just point out three bug
reports that I feel should be fixed before shipping 0.5:
134811 - 'Sequence Generator "null" cannot be resolved' error
134825 - No ddl generation wizard appears. (FYI, it seems that some
people actually have this working since there other bug reports about the
ddl generation that get past this point. But, I am not the only one on my
team that is experiencing this problem.)
136321 - Missing attributes on Persistence Properties panel
As far as missing function that I would like to see in the 0.5 release:
@ManyToMany relationships on both sides of the relationship
@JoinTable support
@Embedded and associated @AttributeOverrides
@DiscriminatorValue and @DiscriminatorColumn support
@PrimaryKeyJoinColumn support
Entity Listener and Callback annotation support
FYI, my first set of tests are being based off the samples in the JPA spec
(sections 9.2.1 and 9.2.2). I'm sure other people have other priorities,
but I would think it would be nice to be able to support the samples in
the spec first. That's my priority at this point.
Thank you for asking and keep up the good work!
Kevin
welcome.
> -Inheritance
> -SecondaryTables
> -Lob
> -Temporal
> -Enumerated
> -MapKey
> -Quick fixes
> Neil Hauge
> Dali Lead
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #433696 is a reply to message #433693] Wed, 12 April 2006 10:27 Go to previous messageGo to next message
Hi Kevin,
Thanks for the feedback!
First off, I am wondering if you have installed the latest Dali build and
if it installed correctly. We already have some JoinTable support(only
multiple joinColumns are missing) and we also already support Embedded and
AttributeOverrides. Are you sure your latest Dali plugins didn't wind up
in an eclipse subfolder, it's easy to do this especially since our
original builds didn't have the eclipse subfolder? Let me know if you see
the new functionality, and maybe it will fix you ddl generation wizard
problem as well.
I'm not sure what you mean by this one, but maybe it's another feature
that you aren't seeing.
I would agree with this, we have thought about trying to support the spec
examples as a first pass.
thanks,
Karen
> @JoinTable support
> Kevin
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #433698 is a reply to message #433691] Wed, 12 April 2006 10:53 Go to previous messageGo to next message
I've tried a latest build from HEAD today and I've been impressed by the
progess of this project.
> -Quick fixes
https://bugs.eclipse.org/bugs/show_bug.cgi?id=136333
BTW, it looks like Bugzilla voting is disabled.
Cu, Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: Dali EJB3-JPA tooling priorities – feed back requested [message #433700 is a reply to message #433698] Wed, 12 April 2006 11:20 Go to previous messageGo to next message
Voting should now be enabled. Thanks for all of the feedback Gunnar.
-Neil
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #433701 is a reply to message #433696] Wed, 12 April 2006 12:02 Go to previous messageGo to next message
Thanks, Karen. I'm now hitting one new problem... The other comments I
will respond to on another thread to avoid confusion.
> problem as well.
I did have the right eclispe subfolder structure (I had noticed the
difference when I got the latest M1 driver). But, *something* was out of
whack with what I had on my system. I downloaded the driver again,
deleted the old *dali* files and folders under both features and plugins,
and "re-installed" Dali. Things are working better (and worse)... :-)
First off, the DDL generation wizard now appears! I will have to
experiment with this now and see if it's doing what I am expecting. Thank
you!
After I re-connect to my database and re-establish my "persistence
connection", I am getting the following error in the Error.log. This may
be due to the ManyToOne relationship support not quite there yet??? Not
sure.
java.lang.ClassCastException:
org.eclipse.dali.core.adapters.java.JavaManyToOneMappingMode lAdapter
incompatible with
org.eclipse.dali.core.adapters.ISingleRelationshipMappingMod elAdapter
at
org.eclipse.dali.core.impl.SingleRelationshipMappingImpl.set Optional(SingleRelationshipMappingImpl.java:165)
at
org.eclipse.dali.core.adapters.java.JavaSingleRelationshipMa ppingModelAdapter$2.setPersValue(JavaSingleRelationshipMappi ngModelAdapter.java:56)
at
org.eclipse.dali.core.adapters.java.AbstractAnnotationElemen tAdapter.updatePersElement(AbstractAnnotationElementAdapter. java:76)
at
org.eclipse.dali.core.adapters.java.JavaSingleRelationshipMa ppingModelAdapter.updateOptional(JavaSingleRelationshipMappi ngModelAdapter.java:114)
at
org.eclipse.dali.core.adapters.java.JavaSingleRelationshipMa ppingModelAdapter.updatePersModel(JavaSingleRelationshipMapp ingModelAdapter.java:106)
at
org.eclipse.dali.core.adapters.java.JavaAttributeMappingMode lAdapter.engage(JavaAttributeMappingModelAdapter.java:58)
at
org.eclipse.dali.core.adapters.java.JavaPersistentAttributeM odelAdapter.updatePersAttributeMapping(JavaPersistentAttribu teModelAdapter.java:83)
at
org.eclipse.dali.core.adapters.java.JavaPersistentAttributeM odelAdapter.updatePersModel(JavaPersistentAttributeModelAdap ter.java:54)
at
org.eclipse.dali.core.adapters.java.JavaPersistentAttributeM odelAdapter.engage(JavaPersistentAttributeModelAdapter.java: 43)
at
org.eclipse.dali.core.adapters.java.JavaPersistentTypeModelA dapter.addPersistentAttributeModelAdapter(JavaPersistentType ModelAdapter.java:262)
at
org.eclipse.dali.core.adapters.java.JavaPersistentTypeModelA dapter.updatePersMappings(JavaPersistentTypeModelAdapter.jav a:252)
at
org.eclipse.dali.core.adapters.java.JavaPersistentTypeModelA dapter.updatePersModel(JavaPersistentTypeModelAdapter.java:1 46)
at
org.eclipse.dali.core.adapters.java.JavaPersistentTypeModelA dapter.engage(JavaPersistentTypeModelAdapter.java:72)
at
org.eclipse.dali.core.adapters.java.JavaPersistenceFileModel Adapter.addPersistentType(JavaPersistenceFileModelAdapter.ja va:155)
at
org.eclipse.dali.core.adapters.java.JavaPersistenceFileModel Adapter.updatePrimaryType(JavaPersistenceFileModelAdapter.ja va:142)
at
org.eclipse.dali.core.adapters.java.JavaPersistenceFileModel Adapter.updateModel(JavaPersistenceFileModelAdapter.java:80)
at
org.eclipse.dali.core.adapters.java.JavaPersistenceFileModel Adapter.engage(JavaPersistenceFileModelAdapter.java:56)
at
org.eclipse.dali.core.impl.PersistenceFileImpl.engageModel(P ersistenceFileImpl.java:170)
at
org.eclipse.dali.core.impl.PersistenceContainerImpl.getPersi stenceFile(PersistenceContainerImpl.java:320)
at
org.eclipse.dali.core.impl.PersistenceModelManager.getPersis tenceFile(PersistenceModelManager.java:120)
at org.eclipse.dali.core.DaliPlugin.getPersistenceFile(DaliPlug in.java:87)
at
org.eclipse.dali.core.impl.PersistenceFileImpl.resolvePersis tentType(PersistenceFileImpl.java:230)
at
org.eclipse.dali.core.impl.RelationshipMappingImpl.getResolv edTargetEntity(RelationshipMappingImpl.java:280)
at
org.eclipse.dali.core.adapters.java.JavaJoinTableModelAdapte r.defaultName(JavaJoinTableModelAdapter.java:108)
at
org.eclipse.dali.core.adapters.java.JavaTableModelAdapter.up datePersDefaultName(JavaTableModelAdapter.java:79)
at
org.eclipse.dali.core.adapters.java.JavaTableModelAdapter.up datePersModel(JavaTableModelAdapter.java:74)
at
org.eclipse.dali.core.adapters.java.JavaJoinTableModelAdapte r.updatePersModel(JavaJoinTableModelAdapter.java:62)
at
org.eclipse.dali.core.adapters.java.JavaMultiRelationshipMap pingModelAdapter.updatePersModel(JavaMultiRelationshipMappin gModelAdapter.java:91)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.dali.core.adapters.java.JavaPersistentTypeModelA dapter.getParentPersistentType(JavaPersistentTypeModelAdapte r.java:644)
at
org.eclipse.dali.core.impl.PersistentTypeImpl.getParentPersi stentType(PersistentTypeImpl.java:520)
at
org.eclipse.dali.core.impl.EntityImpl.getParentPersistentTyp e(EntityImpl.java:611)
at
org.eclipse.dali.core.impl.EntityImpl.inheritedAttributeName s(EntityImpl.java:592)
at
org.eclipse.dali.core.adapters.java.JavaEntityModelAdapter.u pdatePersAttributeOverrides(JavaEntityModelAdapter.java:215)
at
org.eclipse.dali.core.adapters.java.JavaEntityModelAdapter.u pdatePersModel(JavaEntityModelAdapter.java:141)
at
org.eclipse.dali.core.adapters.java.JavaEntityModelAdapter.e ngage(JavaEntityModelAdapter.java:75)
at
org.eclipse.dali.core.adapters.java.JavaPersistentTypeModelA dapter.engageTypeMappingModelAdapter(JavaPersistentTypeModel Adapter.java:92)
at
org.eclipse.dali.core.adapters.java.JavaPersistentTypeModelA dapter.setTypeMappingKey(JavaPersistentTypeModelAdapter.java :136)
at
org.eclipse.dali.core.impl.PersistentTypeImpl.setTypeMapping Key(PersistentTypeImpl.java:310)
at
org.eclipse.dali.core.adapters.java.JavaPersistentTypeModelA dapter.updatePersTypeMapping(JavaPersistentTypeModelAdapter. java:165)
at
org.eclipse.dali.core.adapters.java.JavaPersistentTypeModelA dapter.updatePersModel(JavaPersistentTypeModelAdapter.java:1 43)
at
at
at
at
at
at
at
at
org.eclipse.dali.core.impl.PersistenceContainerImpl$1.visit( PersistenceContainerImpl.java:174)
at org.eclipse.core.internal.resources.Resource.accept(Resource .java:112)
at org.eclipse.core.internal.resources.Resource.accept(Resource .java:126)
at
org.eclipse.dali.core.impl.PersistenceContainerImpl.buildInt ernalResources(PersistenceContainerImpl.java:189)
at
org.eclipse.dali.core.impl.PersistenceContainerImpl$1.visit( PersistenceContainerImpl.java:180)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.dali.core.impl.PersistenceProjectImpl$1.run(Pers istenceProjectImpl.java:260)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #433702 is a reply to message #433696] Wed, 12 April 2006 12:15 Go to previous messageGo to next message
I have the following code in my Employee class. I can not get the
Persistence Properties to ever display anything related to the "projects"
property. Not the relationship, or the table, or the even the property
itself.
@ManyToMany(cascade=CascadeType.PERSIST)
@JoinTable(name="EMP_PROJ",
joinColumns=@JoinColumn(
name="EMP_ID", referencedColumnName="ID"),
inverseJoinColumns=@JoinColumn(
name="PROJ_ID", referencedColumnName="ID"))
public Collection<Project> getProjects() {
return projects;
public void setProjects(Collection<Project> projects) {
this.projects = projects;
Since you indicated that multiple JoinColumns is not supported yet, maybe
that's the basis of the problem I am seeing? If so, I want JoinColumns to
raise on your priority list. :-)
What I meant by "both sides of the relationship" is that the Project class
(which contains the "employees" property) does not seem to recognize the
ManytoMany mappedBy attribute. But, at least with the "updated" Dali
build (per my previous append), the Persistence Properties now displays
correctly for the Project's employees property. So, we're making
progress...
Thanks again!
Kevin
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #433703 is a reply to message #433693] Wed, 12 April 2006 13:11 Go to previous messageGo to next message
Karen's suggestion of re-loading the Dali plugin helped in several areas.
Where I am still having problems, I re-posted to the forum. The following
areas have been resolved.
Neil resolved this. I can now vote on the bugs that I want to get in.
I now get the ddl generation wizard to appear. I cancelled this bug
report.
> @JoinTable support
I replied to Karen on a separate thread concerning the problem I am having
with ManyToMany. Might be resolved...
Looks to be resolved by re-loading the Dali build.
Secondary table support (which is on your list).
Still would like this.
Hope this helps clarify my requests. Thanks again!
Kevin
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #433704 is a reply to message #433702] Wed, 12 April 2006 13:16 Go to previous messageGo to next message
Karen,
After re-loading my Eclipse project, the ManyToMany relationships now seem
to be displayed correctly in the Persistence Properties panels. So,
*something* is still a little flakey with how these annotations are
detected and displayed. But, in general, the support is working as
expected.
Sorry for the confusion. If I can consistently reproduce the steps when
the annotations are not detected properly, I'll re-post or write a bug
report.
Thanks again,
Kevin
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #433707 is a reply to message #433701] Wed, 12 April 2006 16:09 Go to previous messageGo to next message
> sure.
> incompatible with
> at
> at
I made some changes recently that should fix this problem for M2. There
was also a bug that looks related that is now fixed bug 136149.
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #433710 is a reply to message #433704] Wed, 12 April 2006 17:43 Go to previous messageGo to next message
Karen,
> report.
Here's the scoop. I close all of my open files (just to make a clean
re-start). I stop Eclipse and re-start it. I reconnect to my database
(Derby). I Add Java Persistence to my project. I open my Employee class
(from section 9.2.2 of the JPA spec).
In the Persistence Outline, I notice that only 4 of my 8 attributes are
shown (id, version, name, and address). Navigating to the various
properties within the source window, the Persistence Properties panel only
gets updated when I touch one of these 4 "known" properties. If I touch
any of the other properties, the Persistence Panel either stays where it
is or it defaults back to the Entity panel -- in either case, it's not
what I wanted. This was the situation I was seeing this morning and
caused me to say that this didn't work.
Now, here's the weird part. If I go to one of the "unknown" properties,
such as phoneNumbers (either the specific attribute declaration or the
property methods) and benignly modify some character (ie, backspace over
the "s" and then retype the "s") and re-save the file -- the phoneNumbers
attribute is now recognized! Both in the Persistence Outline as well as
the Persistence Properties panels. But, I'm still missing the other three
attributes.
So, I go to the next attribute (projects) and do the same thing by
benignly modifying the attribute and re-saving the file. Here again --
magic. The projects attribute now appears in both Persistence panels.
But, now for some reason, this magic was better this time and the other
two attributes are now recognized as well -- salary and employmentPeriod.
Without doing any of the benign modifying...
So, I can now reproduce the situation and I know of a workaround that
seems to work most of the time. Is this a new problem or is this a known
situation?
Kevin
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #433712 is a reply to message #433710] Wed, 12 April 2006 18:04 Go to previous messageGo to next message
> attributes.
> situation?
> Kevin
Kevin,
I can't say that I've seen this problem before. Are there any exceptions
in the Error log view when you fist open the Employee file? Could you
post the contents of that file as well?
thanks,
Karen
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #433714 is a reply to message #433712] Thu, 13 April 2006 08:39 Go to previous messageGo to next message
>> attributes.
>> situation?
>> Thanks,
>> Kevin
> Kevin,
> thanks,
> Karen
Okay, I took it a bit slower and watched for any logged errors along the
way. When I first Add Java Persistence to the project (after
re-establishing the database connection), I get the exception that I
posted earlier about the ManyToOne ClassCastException:
An internal error occurred during: "reLoadActiveProject"
incompatible with
at
at
Then, when I do the backspace, re-type and save of the file, I get the
following two errors posted:
Problems occurred when invoking code from plug-in: "org.eclipse.jdt.core".
incompatible with
at
at
Exception occurred in listener of Java element change notification
incompatible with
at
at
So, they all have the same callstack, but different errors are being
detected. And, the same two errors get posted when I do the next benign
modification and save. Any additional saves beyond that point (when all
of the attributes are now recognized and displayed) do not generate these
errors.
Which file are you requesting? The error file or the Employee file? If
you would like, I could provide an Eclipse project with all of the files
from section 9.2.2 of the JPA spec.
Let me know what else you need for this problem.
Kevin
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #433716 is a reply to message #433714] Thu, 13 April 2006 09:28 Go to previous messageGo to next message
Ok, so I'm going to make an assumption here that the error you are getting
is probably causing the mappings not to appear. Since this
ClassCastException won't happen in the current code base, we can hope your
magic mappings just magically start working again. So, you could either
get the head out of CVS or wait until our M2 build comes out early next
week. Or you could yank the 'optional' attribute out of your mapping
annotations, since that appears to be the culprit (not the most helpful
workaround :-)
Karen
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #433718 is a reply to message #433716] Thu, 13 April 2006 10:01 Go to previous message
> workaround :-)
Thanks, Karen. I've got other activities to keep myself busy until your
M2 becomes available, so I'll just wait.
Just so that we're sure we're talking about the same problem(s), I tried
your workaround of removing the "optional" attribute. It did immediately
recognize the phoneNumbers property when I did this, but it still didn't
recognize the projects, salary, and employementPeriod properties. And, I
got two new errors logged this time:
java.util.ConcurrentModificationException
at
org.eclipse.emf.common.util.BasicEList$EIterator.checkModCou nt(BasicEList.java:1252)
at
org.eclipse.emf.common.util.BasicEList$EIterator.next(BasicE List.java:1200)
at
org.eclipse.dali.internal.utility.iterators.TreeIterator.nex tInternal(TreeIterator.java:120)
at
org.eclipse.dali.internal.utility.iterators.TreeIterator.nex t(TreeIterator.java:104)
at
org.eclipse.dali.internal.utility.iterators.FilteringIterato r.loadNext(FilteringIterator.java:108)
at
org.eclipse.dali.internal.utility.iterators.FilteringIterato r.next(FilteringIterator.java:87)
at
org.eclipse.dali.core.impl.PersistenceModelManager$ElementCh angeProcessor.elementChanged(PersistenceModelManager.java:40 3)
at
org.eclipse.dali.core.impl.PersistenceModelManager$ElementCh angeListener.elementChanged(PersistenceModelManager.java:378 )
at
org.eclipse.jdt.internal.core.DeltaProcessor$3.run(DeltaProc essor.java:1432)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at
at
at
at
at
at
at
at
at
Here again, if I do the benign modification and save, these other
attributes appear and I'm good to go until the next Eclipse restart (or
close/re-open of the project).
If you think that these problems are all related and will be resolved by
the M2 drop next week, I'll trust you and wait. Just wanted to make sure
that you had all of the information.
Thanks again for your help!
Kevin
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #580455 is a reply to message #433691] Wed, 12 April 2006 09:52 Go to previous message
@JoinTable support
Kevin
welcome.
> -Inheritance
> -SecondaryTables
> -Lob
> -Temporal
> -Enumerated
> -MapKey
> -Quick fixes
> Neil Hauge
> Dali Lead
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #580501 is a reply to message #433693] Wed, 12 April 2006 10:27 Go to previous message
Hi Kevin,
problem as well.
thanks,
Karen
> @JoinTable support
> Kevin
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #580533 is a reply to message #433691] Wed, 12 April 2006 10:53 Go to previous message
> -Quick fixes
Cu, Gunnar
Gunnar Wagenknecht
Re: Dali EJB3-JPA tooling priorities – feed back requested [message #580552 is a reply to message #433698] Wed, 12 April 2006 11:20 Go to previous message
-Neil
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #580569 is a reply to message #433696] Wed, 12 April 2006 12:02 Go to previous message
> problem as well.
you!
sure.
incompatible with
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #580587 is a reply to message #433696] Wed, 12 April 2006 12:15 Go to previous message
itself.
return projects;
progress...
Thanks again!
Kevin
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #580607 is a reply to message #433693] Wed, 12 April 2006 13:11 Go to previous message
report.
> @JoinTable support
Kevin
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #580622 is a reply to message #433702] Wed, 12 April 2006 13:16 Go to previous message
Karen,
expected.
report.
Thanks again,
Kevin
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #581548 is a reply to message #433701] Wed, 12 April 2006 16:09 Go to previous message
> sure.
> incompatible with
> at
> at
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #581602 is a reply to message #433704] Wed, 12 April 2006 17:43 Go to previous message
Karen,
> report.
attributes.
situation?
Kevin
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #581649 is a reply to message #433710] Wed, 12 April 2006 18:04 Go to previous message
> attributes.
> situation?
> Kevin
Kevin,
thanks,
Karen
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #581697 is a reply to message #433712] Thu, 13 April 2006 08:39 Go to previous message
>> attributes.
>> situation?
>> Thanks,
>> Kevin
> Kevin,
> thanks,
> Karen
incompatible with
at
at
incompatible with
at
at
incompatible with
at
at
errors.
Kevin
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #581736 is a reply to message #433714] Thu, 13 April 2006 09:28 Go to previous message
workaround :-)
Karen
Re: Dali EJB3-JPA tooling priorities – feedback requested [message #581757 is a reply to message #433716] Thu, 13 April 2006 10:01 Go to previous message
> workaround :-)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Kevin
Previous Topic:Hibernate EJB3 (J2SE) vs. Generic EJB 3 Persistence
Next Topic:NullPointerException when opening DDL wizard.
Current Time: Thu Sep 18 12:40:29 EDT 2025
Powered by FUDForum. Page generated in 0.17539 seconds
