[CDO] TimeoutException on session refresh [message #431918] |
Wed, 29 July 2009 10:30  |
CDOSessionImpl.refresh() sometimes throws TimeoutException. As I see
there is way to configure timeout, but I wonder is it right to set big
number. Refresh operation depending on changes might take long time if
it requires to load a lot of data from database.
How timeouts are working in this case? For example if timeout is 10
seconds and operation on server takes 20 seconds to load data. Will it
timeout?
Or server can inform client that everything is fine and operation in
progress? So client will not timeout.
Saulius
Re: [CDO] TimeoutException on session refresh [message #431940 is a reply to message #431938] |
Thu, 30 July 2009 03:30   |
Saulius Tvarijonas schrieb:
> Actually I haven't saw anything on server console. Looks everything is
> fine. We experience this problem with CDOSession.refresh() only.
> Is there option to turn performance tracing on server side for refresh()?
Not that I know off ;-(
Is it a new problem with code that formerly worked for you?
In any case, can you file a bugzilla, so that we can track it there?
Cheers
/Eike
> Regards,
> Saulius
> On 2009.07.29 21:09, Eike Stepper wrote:
>> Saulius,
>> For all client-->serv ver requests (with the exception of the commit
>> signals) a timeout value of 10 seconds means: As soon as no data can be
>> read from the *response* stream for more than 10 seconds throw
>> TimeoutException. Since the data is continuoesly streamed I don't think
>> that there's a problem with that. While you're waiting on the client
>> side, does something happen on the server console?
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>> http://twitter.com/eikestepper
>>> Hi,
>>> timeout?
>>> Regards,
>>> Saulius
Re: [CDO] TimeoutException on session refresh [message #467956 is a reply to message #431940] |
Mon, 03 August 2009 08:59  |
Eike,
I opened new issue https://bugs.eclipse.org/bugs/show_bug.cgi?id=285433
Saulius
>> Hi,
> Cheers
> /Eike
>> Regards,
>> Saulius
>>> Saulius,
>>> Cheers
>>> /Eike
>>>> Hi,
>>>> timeout?
>>>> Regards,
>>>> Saulius
FUDForum. Page generated in 0.05134 seconds
