Home » Modeling » EMF » generating code while refering to a runtime instance of a model
generating code while refering to a runtime instance of a model [message #431783] Sun, 26 July 2009 15:45 Go to next message
Hello
I have a *.ecore file that refers to elements of a runtime instance of
an other model. If I try to create a genmodel for that there is no
referenced generator model to select at the last page of the wizard and
the root package of the referenced runtime instance of the model is not
shown either.
I already checked that the referenced model has the following extension
point declared:
<extension point="org.eclipse.emf.ecore.generated_package">
<package
uri = "http://www.eclipse.org/jcrm/0.8.0/dmodel"
class = "org.eclipse.emf.jcrm.dmodel.DmodelPackage"
genModel = "model/domainmodel.genmodel" />
</extension>
Any help is much appreciated.
Best,
Sandro
Eclipse JCR Management
http://jcrmanagement.blogspot.com/
Re: generating code while refering to a runtime instance of a model [message #431796 is a reply to message #431783] Mon, 27 July 2009 05:53 Go to previous messageGo to next message
Hi Sandro!
Sandro Böhme schrieb:
> Hello
> an other model.
What do you mean with "runtime instance of another model"? Your
..ecore-file refers to model elements of another .ecore file?
> shown either.
You have to create a .genmodel file for your referenced model and add
this file on the last wizard page you mentioned.
> point declared:
> <package
> </extension>
Although extending the generated_package extension point is necessary
(or at least highly recommended) for model plugins, (as far as I know)
it has nothing to do with your cross model references issue.
> Best,
> Sandro
Mario
Re: generating code while refering to a runtime instance of a model [message #431798 is a reply to message #431796] Mon, 27 July 2009 06:59 Go to previous messageGo to next message
Mario Winterer schrieb:
> Hi Sandro!
>> Hello
>> an other model.
When loading a resource to an ecore file one can choose between a
runtime instance and a development instance of a resource. In my case I
need a runtime instance. I learned that this runtime instance uses the
package URI (in my case http://www.eclipse.org/jcrm/0.8.0/dmodel) of the
model in the actual reference within the ecore file while the
development instance uses the file URI to the *.ecore file.
When I used the development instance there was no problem creating the
genmodel including references to an other model. But since I now need
the runtime instance it doesn't work anymore.
>> and the root package of the referenced runtime instance of the model
>> is not shown either.
>> extension point declared:
>> <package
>> </extension>
>> Best,
>> Sandro
> Mario
Re: generating code while refering to a runtime instance of a model [message #431802 is a reply to message #431798] Mon, 27 July 2009 09:13 Go to previous messageGo to next message
>> Hi Sandro!
>>> Hello
>>> of an other model.
OK. I've tried to do the same and it worked for me - but "runtime
models" refers to all models that are registered in the currently
running platform (e.g. emf plugins and others), and not to models that
you have defined somewhere in your workspace (e.g. in your domain model
plug-in).
How did you manage to add a reference to your model? Did you modify the
ecore xml directly, or did you use the default ecore editor's "load
resource..." context menu and then choose "Browse registered packages"?
>>> <package
>>> </extension>
>>> Best,
>>> Sandro
>> Mario
Re: generating code while refering to a runtime instance of a model [message #431803 is a reply to message #431802] Mon, 27 July 2009 09:40 Go to previous messageGo to next message
Hi Mario,
>>> Hi Sandro!
>>>> Hello
>>>> of an other model.
>> I need a runtime instance. I learned that this runtime instance uses
>> the package URI (in my case http://www.eclipse.org/jcrm/0.8.0/dmodel)
>> of the model in the actual reference within the ecore file while the
> plug-in).
I used the "load resource..." action. In my case I have a generic model
in one Eclipse instance and start a second one. In this second instance
I create a new model refering to the runtime version of the generic model.
Thanks for having a look into it.
Best,
Sandro
Re: generating code while refering to a runtime instance of a model [message #431808 is a reply to message #431803] Mon, 27 July 2009 12:25 Go to previous messageGo to next message
Sandro,
You need to refer to the development time instance to generate code.
I'm not sure what else to say...
Sandro Böhme wrote:
> Hi Mario,
>>>> Hi Sandro!
>>>>> Hello
>>>>> instance of an other model.
>>> case I need a runtime instance. I learned that this runtime instance
>>> uses the package URI (in my case
>>> http://www.eclipse.org/jcrm/0.8.0/dmodel) of the model in the actual
>>> reference within the ecore file while the development instance uses
>>> the genmodel including references to an other model. But since I now
>>> need the runtime instance it doesn't work anymore.
>> that you have defined somewhere in your workspace (e.g. in your
>> domain model plug-in).
>> the ecore xml directly, or did you use the default ecore editor's
>> "load resource..." context menu and then choose "Browse registered
>> packages"?
> model in one Eclipse instance and start a second one. In this second
> instance I create a new model refering to the runtime version of the
> generic model.
> Best,
> Sandro
Re: generating code while refering to a runtime instance of a model [message #431815 is a reply to message #431808] Mon, 27 July 2009 12:57 Go to previous message
I just thought I can use a model containing a reference to a runtime
version of a model for both - generating code and working with it
reflectively as described in my post from last week.
But in this case I will just try to generate different ecore files with
MWE one with a development time reference and one with a runtime reference.
Thanks for your feedback Ed.
Sandro
Ed Merks schrieb:
> Sandro,
> Sandro Böhme wrote:
>> Hi Mario,
>>>>> Hi Sandro!
>>>>>> Hello
>>> packages"?
>> generic model.
>> Best,
>> Sandro
Previous Topic:Errorneous code generated
Next Topic:XMLResource.OPTION_USE_DEPRECATED_METHODS option in EMF Book
Current Time: Sun Jul 20 08:19:44 EDT 2025
Powered by FUDForum. Page generated in 0.04661 seconds
