Home » Modeling » EMF » Possible to configure the xml-structure of an ecore-model instance?
Possible to configure the xml-structure of an ecore-model instance? [message #431664] Tue, 21 July 2009 06:01 Go to next message
Originally posted by: formatzeh.gmx.de
I'm interested in if it is possible to configure the structure of the
xml which will be created when instantiating an ecore model by an
generated editor. I would have an xml structure containing classes of my
metamodel as xml structure-elements and not as attributes. Now that's
the case only for my root class of my model, containing the defined
prefix. All the other classes appear as attributes in the xml and the
roles of the references are represented as xml elements. I imagine that
only classes of the metamodel are sufficient as xml-elements and roles
names of the references don't need to appear, isn't it? Hope I expressed
myself understandable.
best regards,
Gilbert
Re: Possible to configure the xml-structure of an ecore-model instance? [message #431677 is a reply to message #431664] Tue, 21 July 2009 10:11 Go to previous message
--------------040700020009010609070909
Gilbert,
Comments below.
> generated editor.
To an extent yes.
Extended meta data annotations can be used for that.
> Now that's
Not sure what you mean. Have a read through this:
http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf
The annotations it describes can be added directly to an Ecore model...
> Hope I expressed
> best regards,
> Gilbert
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
<title></title>
</head>
Gilbert,<br>
<br>
Comments below.<br>
<br>
<br>
<blockquote cite="mid:h443mk$7ms$1@build.eclipse.org" type="cite">
<pre wrap="">I'm interested in if it is possible to configure the structure of the
generated editor. </pre>
</blockquote>
To an extent yes. <br>
<pre wrap="">I would have an xml structure containing classes of my
metamodel as xml structure-elements and not as attributes.</pre>
</blockquote>
Extended meta data annotations can be used for that.<br>
<pre wrap=""> Now that's
names of the references don't need to appear, isn't it? </pre>
</blockquote>
Not sure what you mean. Have a read through this:<br>
<blockquote><a
href=" http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf"> http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf</a><br>
</blockquote>
The annotations it describes can be added directly to an Ecore model...<br>
<pre wrap="">Hope I expressed
best regards,
Gilbert
</pre>
</blockquote>
</body>
</html>
--------------040700020009010609070909--
Previous Topic:EMF XML Serialization
Next Topic:Creating an Instance on ModelPackage; Extension Point
Current Time: Sat Jul 19 16:45:55 EDT 2025
Powered by FUDForum. Page generated in 0.26496 seconds
