Home » Modeling » EMF » [CDO] CDO sources workspace setup under Linux
[CDO] CDO sources workspace setup under Linux [message #431592] Sat, 18 July 2009 07:59 Go to next message
Eike, as we already discussed some time, when setting up the workspace with the provided
SetupWorkspace under Linux, it fails cause SetupWorkspace.java can't unpack tar.gz files.
If you would add org.apache.ant as a referenced library to develop.setup, then I could implement
that also a tar.gz file is handled correctly.
Kai
Re: [CDO] CDO sources workspace setup under Linux [message #431593 is a reply to message #431592] Sat, 18 July 2009 08:05 Go to previous messageGo to next message
Or better to say ... I just need ant.jar
> with the provided SetupWorkspace under Linux, it fails cause
> develop.setup, then I could implement that also a tar.gz file is handled
> correctly.
> Regards,
> Kai
Re: [CDO] CDO sources workspace setup under Linux [message #431594 is a reply to message #431593] Sat, 18 July 2009 08:41 Go to previous messageGo to next message
Can you file a bugzilla with the patch?
I'd be happy to apply it ;-)
Cheers
/Eike
>> workspace with the provided SetupWorkspace under Linux, it fails
>> handled correctly.
>> Regards,
>> Kai
Re: [CDO] CDO sources workspace setup under Linux [message #431615 is a reply to message #431594] Sat, 18 July 2009 09:36 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=283928
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>>> handled correctly.
>>> Regards,
>>> Kai
Previous Topic:Distinguishing between XMIException
Next Topic:[CDO] CDO sources and "Unsatisfied version constraint"
Current Time: Sat Jul 19 05:02:37 EDT 2025
Powered by FUDForum. Page generated in 0.12744 seconds
