Home » Modeling » EMF » [Databinding API] Path over multi-valued features
[Databinding API] Path over multi-valued features [message #431519] Wed, 15 July 2009 04:48 Go to next message
If i have the following model:
X {
List<Y> y;
Y {
List<Z> z;
the EMFObersvables.list(FeaturePath.fromList(MyPackage.Literals. X__y,
MyPackage.Literals.Y__z)) is not working as y is a multi-valued feature.
How can i manage to get list of all z's for a given instance of X?
Thanks for your help,
Henning
Re: [Databinding API] Path over multi-valued features [message #431538 is a reply to message #431519] Wed, 15 July 2009 09:55 Go to previous messageGo to next message
It looks like you opened
https://bugs.eclipse.org/bugs/show_bug.cgi?id=283498
> X {
> List<Y> y;
> Y {
> List<Z> z;
> feature. How can i manage to get list of all z's for a given instance
> of X?
> Henning
Re: [Databinding API] Path over multi-valued features [message #431539 is a reply to message #431519] Wed, 15 July 2009 10:02 Go to previous messageGo to next message
I hacked up something to which uses but I need to discuss with Matt Hall
to find out if some hidden magic stuff in Eclipse-Databinding could help.
---------8<-------------
> new ComputedList() {
> private IObservableList l = EMFProperties.list(MyPackage.Literals.X__y).observe(target);
> private Map<Y, IObservableList> listMap = new HashMap<Y, IObservableList>();
> l.addListChangeListener(new IListChangeListener() {
> @Override
> public void handleListChange(ListChangeEvent event) {
> event.diff.accept(new ListDiffVisitor() {
> @Override
> public void handleRemove(int index, Object element) {
> listMap.remove(element).dispose();
> @Override
> public void handleAdd(int index, Object element) {
> @Override
> protected List<?> calculate() {
> List<Object> rv = new ArrayList<Object>();
> for( Object o : l ) {
> IObservableList list = listMap.get(o);
> if( list != null ) {
> rv.addAll(list);
> } else {
> IObservableList obsList = EMFProperties.list(MyPackage.Literals.Y__z).observe(o);
> listMap.put((Y) o, obsList);
> rv.addAll(obsList);
> return rv;
What we'd like to have in the end is a MultiList where sublists can be
added and removed. The above is a 5 minute hack but from my tests it
looks like it is working as expected.
Tom
> X {
> List<Y> y;
> Y {
> List<Z> z;
> Henning
Re: [Databinding API] Path over multi-valued features [message #431540 is a reply to message #431539] Wed, 15 July 2009 11:09 Go to previous messageGo to next message
Tom Schindl wrote:
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=263714
Matthew
Re: [Databinding API] Path over multi-valued features [message #431541 is a reply to message #431540] Wed, 15 July 2009 11:22 Go to previous messageGo to next message
Ha - I was so sure you've something like this in your queue :-)
Tom
Matthew Hall schrieb:
> Tom Schindl wrote:
>> Hi,
> Matthew
Re: [Databinding API] Path over multi-valued features [message #431562 is a reply to message #431539] Thu, 16 July 2009 12:43 Go to previous messageGo to next message
Hi Tom,
thanks for your quick solution. It also seems to work fine for me :)
Henning
Re: [Databinding API] Path over multi-valued features [message #431563 is a reply to message #431538] Thu, 16 July 2009 12:47 Go to previous message
Hi Ed,
that's true. The bug was aimed to document the behaviour in JavaDoc. I
assumed that it will take longer to develop the wanted functionality. But
i still wanted to ask you for advice on a temporary solution.
Henning
Previous Topic:[CDO] Derby drivers
Next Topic:edit FeatureMap Text feature from text field in a form
Current Time: Sat Jul 19 11:45:45 EDT 2025
Powered by FUDForum. Page generated in 0.04367 seconds
