Home » Modeling » EMF » how to create a stand alone plugin foom EMF model
how to create a stand alone plugin foom EMF model [message #431458] Sat, 11 July 2009 05:29 Go to next message
Hello.
I have created an EMF plug-in, and I want to move it
to a different Eclipse that users will be able to work with it.
My plug-in name is called "TESTING", so I have 5 folders :
TESTING,TESTING.diagram,TESTING.edit,TESTING.editor,TESTING. tests.
I tried to export all of them to JAR and then move it to the new Eclipse
program
in the "plugins" folder. The Eclipse doesnt seems to recognize the plug-in.
Can someone please tell me how to do it properly or give me a tutorial
link.
Thanks a lot.
Elad
Re: how to create a stand alone plugin foom EMF model [message #431459 is a reply to message #431458] Sat, 11 July 2009 05:46 Go to previous messageGo to next message
Elad,
You need to export the 5 plugin projects with the "Deployable Plugins
and Fragments" wizard.
Cheers
/Eike
Elad schrieb:
> Hello.
> Eclipse program in the "plugins" folder. The Eclipse doesnt seems to
> link.
> Thanks a lot.
> Elad
Re: how to create a stand alone plugin foom EMF model [message #431461 is a reply to message #431459] Sat, 11 July 2009 05:58 Go to previous messageGo to next message
Thanks for the quick answer.
Do I need to put the JAR file in a folder inside the plugins? should I add
the plugin.xml to that folder?
Re: how to create a stand alone plugin foom EMF model [message #431462 is a reply to message #431461] Sat, 11 July 2009 06:08 Go to previous messageGo to next message
You're welcome.
> add the plugin.xml to that folder?
Sorry, I have no clue what you mean by this ;-(
Maybe you should google a bit. Or start here:
http://agile.csc.ncsu.edu/SEMaterials/tutorials/plugin_dev
Cheers
/Eike
Re: how to create a stand alone plugin foom EMF model [message #431463 is a reply to message #431462] Sat, 11 July 2009 06:52 Go to previous messageGo to next message
I export the 5 folders to the plugins directory.
The work environment looks like my plug-in. But when I try to open a new
diagram file ( which is my emf based file ) I only see "Example EMF Model
Creation Wizards" and inside a file type named "Test Model" which
contains only the EMF element and not the graphic model.
How can I see my graphic model when I want to create a new diagram.
Sorry for my bad English.
thanks
Elad
Eike Stepper wrote:
> You're welcome.
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: how to create a stand alone plugin foom EMF model [message #431464 is a reply to message #431463] Sat, 11 July 2009 06:57 Go to previous message
"I only see "Example EMF Model
> contains only the EMF element and not the graphic model."
when choose to create the "Test Model" it tells me to choose a "Model
Object" which is an element from my EMF.
Why is he asking that instead of opening my original diagram file?
> thanks
> Elad
> Eike Stepper wrote:
>> You're welcome.
>> Cheers
>> /Eike
Previous Topic:[TENEO][EMF] Viewing problems in Linux and Windows
Next Topic:EMF List databinding
Current Time: Sun Jul 20 06:15:06 EDT 2025
Powered by FUDForum. Page generated in 0.17138 seconds
