Home » Modeling » EMF » [CDO] Need help with the testing framework
[CDO] Need help with the testing framework [message #431419] Wed, 08 July 2009 13:10 Go to next message
Hi.
I just implemented the SQL query, but now also want to test it.
I took a look at HibernateQueryTest, but don't really understand what's going on.
Especially the line CDOSession session = openModel1Session();
It seems to create the database and the session.
In HibernateQueryTest it creates a database by using Hibernate, but in my case (in the plugin
org.eclipse.emf.cdo.tests.db it seems to create a H2 database. That is fine, but I would like to
know where that magic happens (and I am not able to find it myself). What if I want to test it with
Derby instead of H2? Where is the switch?
I also don't find the database on my harddrive, so it seems it is automatically deleted after the
test. Could you point me to the location where that happens. Cause I want to turn the deletion off
for a moment.
Kai
Re: [CDO] Need help with the testing framework [message #431420 is a reply to message #431419] Wed, 08 July 2009 13:20 Go to previous messageGo to next message
Ok, I found the location of the database. It's created in /temp and is not deleted after a test run.
But I still wonder how for example to run the test with Derby or HSQLDB instead.
Kai Schlamp wrote:
> Hi.
> going on.
> my case (in the plugin org.eclipse.emf.cdo.tests.db it seems to create a
> H2 database. That is fine, but I would like to know where that magic
> with Derby instead of H2? Where is the switch?
> automatically deleted after the test. Could you point me to the location
> where that happens. Cause I want to turn the deletion off for a moment.
> Regards,
> Kai
Re: [CDO] Need help with the testing framework [message #431427 is a reply to message #431420] Thu, 09 July 2009 05:00 Go to previous messageGo to next message
Kai,
I have to admit that I don't understand every single bit of the magic
behind the scenes, either ;)
That said, be sure to check out the project org.eclipse.eml.cdo.tests.db
There you'll find different AllTestsDBxxx classes which configure the
different databases (and also there the paths etc. are set).
Generally, the test framework has a list of all relevant test classes in
AllTests. This class is extended by the AllTestsDBxxx classes which set
up the context of repository and network configurations. The neat thing
about this is, that you can easily test different configurations (e.g.,
different databases) with one test run, just by configuring the
respective scenarios.
The line you mentioned -- CDOSession session = openModel1Session() -- is
a shortcut for setting up the whole CDO client stack, connect to the
server, open the session and register the model1 package (which is
contained in the .cdo.tests.model1 project).
I hope this helps a bit...
Stefan
> HSQLDB instead.
> Kai Schlamp wrote:
>> Hi.
>> what's going on.
>> in my case (in the plugin org.eclipse.emf.cdo.tests.db it seems to
>> create a H2 database. That is fine, but I would like to know where
>> want to test it with Derby instead of H2? Where is the switch?
>> for a moment.
>> Regards,
>> Kai
Re: [CDO] Need help with the testing framework [message #431429 is a reply to message #431427] Thu, 09 July 2009 05:21 Go to previous message
Guys,
That's all correct. I just wanted to add, that most test cases don't
need to pre-register model1 anymore. This should be good, too:
CDOSession session = openSession();
Registering packages in advance is usually only needed in UIs, where for
example an editor must present the list of available classes *before*
instances are created/attached.
Cheers
/Eike
Stefan Winkler schrieb:
> Kai,
> Cheers,
> Stefan
>> HSQLDB instead.
>> Kai Schlamp wrote:
>>> Hi.
>>> what's going on.
>>> for a moment.
>>> Regards,
>>> Kai
Previous Topic:[CDO] Little patch for setting up the CDO sources workspace
Next Topic:Bug in validation with ecore model in 3.5 : "containment or bidirectionnal reference must be un
Current Time: Sat Jul 19 06:01:23 EDT 2025
Powered by FUDForum. Page generated in 0.05054 seconds
