Home » Modeling » EMF » [CDO] Little patch for setting up the CDO sources workspace
[CDO] Little patch for setting up the CDO sources workspace [message #431313] Wed, 08 July 2009 05:08 Go to next message
Hi Eike,
below is a little patch for the SetupWorkspace.java for setting up the CDO Sources.
The problem is when you are working on Linux and change url-target.txt and url.baseline.txt as
mentioned on http://wiki.eclipse.org/CDO_Source_Installation#Bootstrap, then those files are not
downloaded correctly.
Was not sure if it is really worth a bug report.
### Eclipse Workspace Patch 1.0
#P develop.setup
Index: src/setup/SetupWorkspace.java
RCS file:
/cvsroot/modeling/org.eclipse.emf/org.eclipse.emf.cdo/develo p/setup/src/setup/SetupWorkspace.java,v
retrieving revision 1.1
diff -u -r1.1 SetupWorkspace.java
--- src/setup/SetupWorkspace.java 4 Jul 2009 05:11:43 -0000 1.1
+++ src/setup/SetupWorkspace.java 8 Jul 2009 09:01:51 -0000
@@ -123,7 +123,7 @@
URLConnection connection = url.openConnection();
String contentType = connection.getContentType();
- if (!"application/zip".equals(contentType))
+ if (!"application/zip".equals(contentType) && !"application/x-gzip".equals(contentType))
copy((InputStream)connection.getContent(), System.err);
throw new IOException("Invalid content type: " + contentType);
Re: [CDO] Little patch for setting up the CDO sources workspace [message #431370 is a reply to message #431313] Wed, 08 July 2009 05:14 Go to previous messageGo to next message
Kai,
Thx for the hint! Usually we prefer patches on bugzillas, but in this
case no production code is affected. That said, I can't apply the patch.
But the change is simple enough and I can apply it manually ;-)
Cheers
/Eike
Kai Schlamp schrieb:
> Hi Eike,
> CDO Sources.
> and url.baseline.txt as mentioned on
> files are not downloaded correctly.
> #P develop.setup
> RCS file:
> @@ -123,7 +123,7 @@
Re: [CDO] Little patch for setting up the CDO sources workspace [message #431408 is a reply to message #431370] Wed, 08 July 2009 07:42 Go to previous messageGo to next message
Another problem is that the tar.gz file is not unpacked into the .target folder (only .zip files are
handled by SetupWorkspace.java).
I'll take a look into that problem, when I have some time.
Do you really develop under Windows, Eike? I tried that once, but Windows (XP, Vista, whatever)
always complained when trying to move or delete files that are in a deep folder structure + have
long path names (like it often happens in Eclipse development). That drove me really crazy.
Re: [CDO] Little patch for setting up the CDO sources workspace [message #431416 is a reply to message #431408] Wed, 08 July 2009 10:33 Go to previous messageGo to next message
> .target folder (only .zip files are handled by SetupWorkspace.java).
That would be great!
I really hope that we're soon able to use Buckminster ;-)
> Windows (XP, Vista, whatever) always complained when trying to move or
> delete files that are in a deep folder structure + have long path
> really crazy.
Yes. My workspace is under C:\develop\ws\cdo and under Vista that works
great.
Cheers
/Eike
Re: [CDO] Little patch for setting up the CDO sources workspace [message #431422 is a reply to message #431416] Wed, 08 July 2009 17:28 Go to previous messageGo to next message
What prevents you from doing so? A missing feature, or simply time?
Re: [CDO] Little patch for setting up the CDO sources workspace [message #431423 is a reply to message #431422] Thu, 09 July 2009 01:37 Go to previous message
Many things ;-)
Most important: I'd like the central build be the same as my local one
and changing the central build is far beyond my capabilities.
Cloudsmith has offered to invest in helping me setup initial Buckminster
support, so something might happen some time soon...
Cheers
/Eike
Previous Topic:Re: Teneo + EclipseLink simple complete example
Next Topic:[CDO] Need help with the testing framework
Current Time: Sun Jul 20 06:14:11 EDT 2025
Powered by FUDForum. Page generated in 0.04792 seconds
