Home » Modeling » EMF » [CDO] Fetch multiple objects by CDOID
[CDO] Fetch multiple objects by CDOID [message #431300] |
Tue, 07 July 2009 17:00  |
Hello.
For perfomance reasons I need to do some direct SQL queries (regexp search in the database). As
there is no query implemented for CDO yet, I thought of just connecting to the database directly
(beside the CDO connection) and query for the CDOID's directly.
What would be the best way to load the objects then with CDO?
Just use Transaction.getObject(cdoId, true)? Even if it is a very large list of CDOID's (about 50000)?
Kai
Re: [CDO] Fetch multiple objects by CDOID [message #431307 is a reply to message #431300] |
Wed, 08 July 2009 02:24   |
--------------000100060707050409000706
Content-Type: text/plain; charset=ISO-8859-1
Kai,
I strongly recommend to spend your time on efforts that are more
re-usable ;-)
Yesterday Martin implemented HQL for the HibernateStore within only 2 or
3 hours:
* Implements server side HQL query execution..
* @author Martin Taal
*public class *HibernateQueryHandler *implements *IQueryHandler
*public static final *String QUERY_LANGUAGE = "hql";
*public static final *String FIRST_RESULT = "firstResult";
*private *HibernateStoreAccessor hibernateStoreAccessor;
* Executes hql queries. Gets the session from the {@link HibernateStoreAccessor} creates a hibernate query and sets
* the parameters taken from the {@link CDOQueryInfo#getParameters()}. Takes into account the
* {@link CDOQueryInfo#getMaxResults()} and the {@link HibernateQueryHandler#FIRST_RESULT} values for paging.
* @param info
* the object containing the query and parameters
* @param context
* the query results are placed in the context
* @see IQueryHandler#executeQuery(CDOQueryInfo, IQueryContext)
*public **void *executeQuery(CDOQueryInfo info, IQueryContext context)
*if *(!QUERY_LANGUAGE.equals(info.getQueryLanguage().toLowerCase ()))
*throw new *IllegalArgumentException("Query language " + info.getQueryLanguage() + " not supported by this store");
// get a transaction, the hibernateStoreAccessor is placed in a threadlocal
// so all db access uses the same session.
*final *Session session = hibernateStoreAccessor.getHibernateSession();
*try*
// create the query
*final *Query query = session.createQuery(info.getQueryString());
// get the parameters with some parameter conversion
*int *firstResult = -1;
*for *(String key : info.getParameters().keySet())
*if *(key.toLowerCase().equals(FIRST_RESULT.toLowerCase()))
*final *Object o = info.getParameters().get(key);
*if *(o != *null*)
*try*
firstResult = (Integer)o;
*catch *(ClassCastException e)
*throw new *IllegalArgumentException("Parameter firstResult must be an integer but it is a " + o
+ " class " + o.getClass().getName());
*else*
// in case the parameter is a CDOID get the object from the db
*final *Object param = info.getParameters().get(key);
*if *(param *instanceof *CDOIDHibernate)
*final *CDOIDHibernate hibernateId = (CDOIDHibernate)param;
query.setEntity(key, session.get(hibernateId.getEntityName(), hibernateId.getId()));
*else*
query.setParameter(key, param);
// set the first result
*if *(firstResult > -1)
query.setFirstResult(firstResult);
// the max result
*if *(info.getMaxResults() != CDOQueryInfo.UNLIMITED_RESULTS)
query.setMaxResults(info.getMaxResults());
// and go for the query
// future extension: support iterate, scroll through a parameter
*for *(Object o : query.list())
*final **boolean *addOneMore = context.addResult(o);
*if *(!addOneMore)
*return*;
*finally*
hibernateStoreAccessor.endHibernateSession();
*public *HibernateStoreAccessor getHibernateStoreAccessor()
*return *hibernateStoreAccessor;
*public **void *setHibernateStoreAccessor(HibernateStoreAccessor hibernateStoreAccessor)
*this*.hibernateStoreAccessor = hibernateStoreAccessor;
Cheers
/Eike
Kai Schlamp schrieb:
> Hello.
> search in the database). As there is no query implemented for CDO yet,
> I thought of just connecting to the database directly (beside the CDO
> Regards,
> Kai
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Kai,<br>
<br>
re-usable ;-)<br>
or 3 hours:<br>
<br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<!-- = Java Sourcecode to HTML automatically converted code = --><!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = -->
<!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3" cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td align="left" nowrap="nowrap"
valign="top"> <code><font color="#3f5fbf">/**</font><br>
<font color="#ffffff"> </font><font color="#3f5fbf"> * Implements server side  ;HQL query execution.. </font><br>
<font color="#ffffff"> </font><font color="#3f5fbf">* </font><br>
<font color="#ffffff"> </font><font color="#3f5fbf">* </font><font
color="#7f9fbf">@author </font><font color="#3f5fbf">Martin Taal</font><br>
<font color="#ffffff"> </font><font color="#3f5fbf">*/</font><br>
<font color="#7f0055"><b>public class </b></font ><font
color="#000000">HibernateQueryHandler </font><font color="#7f0055"><b>implements </b></font><font
color="#000000">IQueryHandler</font><br>
<font color="#000000">{</font><br>
<font color="#ffffff"> </font><font color="#7f0055"><b>public static final </b></font><font
color="#000000">String QUERY_LANGUAGE = </font><font color="#2a00ff">"hql"</font><font
color="#000000">;</font><br>
<font color="#ffffff"></font><br>
color="#000000">String FIRST_RESULT = </font><font color="#2a00ff">"firstResult"</font><font
<font color="#ffffff"> </font><font color="#7f0055"><b>private </b></font><font
color="#000000">HibernateStoreAccessor hibernateStoreAccessor; </font><br>
<font color="#ffffff"> </font><font color="#3f5fbf">/**</font><br>
<font color="#ffffff"> </font><font color="#3f5fbf"> * Executes hql queries. Gets the session from th e </font><font
color="#3f3fbf">{@link HibernateStoreAccessor} </font><font
color="#3f5fbf"> creates a hibernate query&nbs p;and sets </font><br>
<font color="#ffffff"> </font><font color="#3f5fbf"> * the parameters taken f rom the </font><font
color="#3f3fbf">{@link CDOQueryInfo#getParameters()} </font><font
color="#3f5fbf"> . Takes into account the </font><br>
color="#3f3fbf">{@link CDOQueryInfo#getMaxResults()} </font><font
color="#3f5fbf">and the </font><font color="#3f3fbf"> {@link HibernateQueryHandler#FIRST_RESULT}  ; </font><font
color="#3f5fbf">values for paging.</font ><br>
color="#7f9fbf">@param </font><font color="#3f5fbf">info</font><br>
<font color="#ffffff"> </font><font color="#3f5fbf"> *   ; the object containing the query an d parameters </font><br>
color="#7f9fbf">@param </font><font color="#3f5fbf">context</font><br>
<font color="#ffffff"> </font><font color="#3f5fbf"> *   ; the query& amp;nbsp;results are placed in&am p;nbsp;the context </font><br>
color="#7f9fbf">@see </font><font color="#3f5fbf"> IQueryHandler#executeQuery(CDOQueryInfo, IQueryCont ext) </font><br>
<font color="#ffffff"> </font><font color="#7f0055"><b>public </b></font><font
color="#7f0055"><b>void </b></font><font color="#000000">executeQuery</font><font
color="#000000">(</font><font color="#000000"> CDOQueryInfo info, IQueryContext context </font><font
color="#000000">)</font><br>
<font color="#ffffff"> </font><font color="#000000">{</font><br>
<font color="#ffffff"> </font ><font color="#7f0055"><b>if </b></font><font
color="#000000">(</font><font color="#000000">!QUERY_LANGUAGE.equals</font><font
color="#000000">(</font><font color="#000000">info.getQueryLanguage</font><font
color="#000000">()</font><font color="#000000">.toLowerCase</font><font
color="#000000">()))</font><br>
<font color="#ffffff"> </font ><font color="#000000">{</font><br>
<font color="#ffffff"> </font><font color="#7f0055"><b>throw new </b></font ><font
color="#000000">IllegalArgumentException</font><font color="#000000">(</font><font
color="#2a00ff">"Query language " </font><font color="#000000">+ info.getQueryLanguage</font><font
color="#000000">() </font><font color="#000000">+ </font><font
color="#2a00ff">" not supported by this&a mp;nbsp;store "</font><font
color="#000000">)</font><font color="#000000">;</font><br>
<font color="#ffffff"> </font ><font color="#000000">}</font><br>
<font color="#ffffff"> </font ><font color="#3f7f5f"> // get a transaction, th e hibernateStoreAccessor is place d in a threadlocal </font><br>
<font color="#ffffff"> </font ><font color="#3f7f5f"> // so all db access& nbsp;uses the same session. </font><br>
<font color="#ffffff"> </font ><font color="#7f0055"><b>final </b></font><font
color="#000000"> Session session = hibernateStoreA ccessor.getHibernateSession </font><font
color="#000000">()</font><font color="#000000">;</font><br>
<font color="#ffffff"> </font ><font color="#7f0055"><b>try</b></font><br>
<font color="#ffffff"> </font><font color="#3f7f5f">// create the query </font><br>
<font color="#ffffff"> </font><font color="#7f0055"><b>final </b></font><font
color="#000000"> Query query = session.createQuery </font><font
color="#000000">(</font><font color="#000000">info.getQueryString</font><font
color="#000000">())</font><font color="#000000">;</font><br>
<font color="#ffffff"> </font><font color="#3f7f5f"> // get the parameters wi th some parameter conversion </font><br>
<font color="#ffffff"> </font><font color="#7f0055"><b>int </b></font><font
color="#000000">firstResult = -</font><font color="#990000">1</font><font
<font color="#ffffff"> </font><font color="#7f0055"><b>for </b></font><font
color="#000000">(</font><font color="#000000">String key : info.getParameters </font><font
color="#000000">()</font><font color="#000000">.keySet</font><font
color="#000000">())</font><br>
<font color="#ffffff"> </font><font color="#7f0055"><b>if </b></font><font
color="#000000">(</font><font color="#000000">key.toLowerCase</font><font
color="#000000">()</font><font color="#000000">.equals</font><font
color="#000000">(</font><font color="#000000">FIRST_RESULT.toLowerCase</font><font
color="#000000">Object o = info.getParameters </font><font
color="#000000">()</font><font color="#000000">.get</font><font
color="#000000">(</font><font color="#000000">key</font><font
color="#000000">(</font><font color="#000000">o != </font><font
color="#7f0055"><b>null</b></font><font color="#000000">)</font><br>
<font color="#ffffff"> </font><font color="#7f0055"><b>try</b></font><br>
<font color="#ffffff"> </font><font color="#000000">firstResult = </font><font
color="#000000">(</font><font color="#000000">Integer</font><font
color="#000000">)</font><font color="#000000">o;</font><br>
<font color="#ffffff"> </font><font color="#000000">}</font><br>
<font color="#ffffff"> </font><font color="#7f0055"><b>catch </b></font><font
color="#000000">(</font><font color="#000000">ClassCastException e</font><font
color="#2a00ff">" Parameter firstResult must be& ;nbsp;an integer but it is a " </font><font
color="#000000">+ o</font><br>
color="#000000">+ </font><font color="#2a00ff">" class " </font ><font
color="#000000">+ o.getClass</font><font color="#000000">()</font><font
color="#000000">.getName</font><font color="#000000">())</font><font
<font color="#ffffff"> </font><font color="#7f0055"><b>else</b></font><br>
<font color="#ffffff"> </font><font color="#3f7f5f"> // in case the parameter is a CDOID get  ;the object from the db </font><br>
color="#000000"> Object param = info.getParameters </font><font
color="#000000">(</font><font color="#000000">param </font><font
color="#7f0055"><b>instanceof </b></font><font color="#000000">CDOIDHibernate</font><font
color="#000000">CDOIDHibernate hibernateId = </font><font
color="#000000">(</font><font color="#000000">CDOIDHibernate</font><font
color="#000000">)</font><font color="#000000">param;</font><br>
<font color="#ffffff"> </font><font color="#000000">query.setEntity</font><font
color="#000000">(</font><font color="#000000">key, session.get</font><font
color="#000000">(</font><font color="#000000">hibernateId.getEntityName</font><font
color="#000000">()</font><font color="#000000">, hibernateId.getId</font><font
color="#000000">()))</font><font color="#000000">;</font><br>
<font color="#ffffff"> </font><font color="#000000">query.setParameter</font><font
color="#000000">(</font><font color="#000000">key, param</font><font
<font color="#ffffff"> </font><font color="#3f7f5f">// set the first result </font><br>
color="#000000">(</font><font color="#000000">firstResult > -</font ><font
color="#990000">1</font><font color="#000000">)</font><br>
<font color="#ffffff"> </font><font color="#000000">query.setFirstResult</font><font
color="#000000">(</font><font color="#000000">firstResult</font><font
<font color="#ffffff"> </font><font color="#3f7f5f">// the max result </font><br>
color="#000000">(</font><font color="#000000">info.getMaxResults</font><font
color="#000000">() </font><font color="#000000">!= CDOQueryInfo.UNLIMITED_RESULTS </font><font
<font color="#ffffff"> </font><font color="#000000">query.setMaxResults</font><font
<font color="#ffffff"> </font><font color="#3f7f5f"> // and go for the&nb sp;query </font><br>
<font color="#ffffff"> </font><font color="#3f7f5f"> // future extension: support& nbsp;iterate, scroll through a&am p;nbsp;parameter </font><br>
color="#000000">(</font><font color="#000000">Object o : query.list </font><font
color="#7f0055"><b>boolean </b></font><font color="#000000">addOneMore = context.addResult </font><font
color="#000000">(</font><font color="#000000">o</font><font
color="#000000">(</font><font color="#000000">!addOneMore</font><font
<font color="#ffffff"> </font><font color="#7f0055"><b>return</b></font><font
<font color="#ffffff"> </font ><font color="#7f0055"><b>finally</b></font><br>
<font color="#ffffff"> </font><font color="#000000">hibernateStoreAccessor.endHibernateSession </font><font
color="#000000">HibernateStoreAccessor getHibernateStoreAccessor </font><font
color="#000000">()</font><br>
<font color="#ffffff"> </font ><font color="#7f0055"><b>return </b></font><font
color="#000000">hibernateStoreAccessor;</font><br>
color="#7f0055"><b>void </b></font><font color="#000000">setHibernateStoreAccessor</font><font
color="#000000">(</font><font color="#000000">HibernateStoreAccessor hibernateStoreAccessor </font><font
<font color="#ffffff"> </font ><font color="#7f0055"><b>this</b></font><font
color="#000000"> .hibernateStoreAccessor = hibernateStoreAc cessor; </font><br>
<font color="#000000">}</font></code> </td>
<!-- end source code --> </tr>
</tbody>
</table>
</div>
<!-- = END of automatically generated HTML code = -->
<!-- ======================================================== --><br>
Cheers<br>
/Eike<br>
<br>
----<br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a><br>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a><br>
<br>
<br>
<br>
<blockquote cite="mid:h30d1n$uau$1@build.eclipse.org" type="cite">Hello.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Kai
<br>
</blockquote>
</body>
</html>
--------------000100060707050409000706--
Re: [CDO] Fetch multiple objects by CDOID [message #431309 is a reply to message #431307] |
Wed, 08 July 2009 03:35   |
Ok, sounds reasonable. I'll see what I can do.
Eike Stepper wrote:
> Kai,
> re-usable ;-)
> 3 hours:
> * @param info
> * @param context
> *try*
> // create the query
> *if *(o != *null*)
> *try*
> *else*
> *else*
> // the max result
> *if *(!addOneMore)
> *return*;
> *finally*
> Cheers
> /Eike
>> Hello.
>> Regards,
>> Kai
Re: [CDO] Fetch multiple objects by CDOID [message #431310 is a reply to message #431309] |
Wed, 08 July 2009 03:36  |
Kai,
Note that there is:
248933: [DB] Support SQL as a CDOQuery language
https://bugs.eclipse.org/bugs/show_bug.cgi?id=248933
Cheers
/Eike
> Eike Stepper wrote:
>> Kai,
>> re-usable ;-)
>> or 3 hours:
>> * * @author Martin Taal
>> * * @param info
>> * @param context
>> threadlocal
>> *try*
>> // create the query
>> *if *(o != *null*)
>> *try*
>> *else*
>> *else*
>> // the max result
>> *if *(!addOneMore)
>> *return*;
>> *finally*
>> Cheers
>> /Eike
>>> Hello.
>>> yet, I thought of just connecting to the database directly (beside
>>> Regards,
>>> Kai
Current Time: Sat Jul 19 06:06:59 EDT 2025
Powered by FUDForum. Page generated in 0.03601 seconds
