Home » Modeling » EMF » java.lang.AbstractMethodError in registerEntityNameResolvers
java.lang.AbstractMethodError in registerEntityNameResolvers [message #431236] Sat, 04 July 2009 16:01 Go to next message
I am just trying to create a very basic hibernate/teneo/emf/rcp project.
After several hours of experimenting, reading, re-configuring ...
My application follows the QuickStart example (with the 'main' in a
plugin forming a RCP application).
I create a simple EMF package. And try to set up a datastore
as follows:
Hibernate is located in a separate plugin.
The MySql driver is also in a separate plugin.
The buddy-stuff seems to work. (The driver can be resolved.)
This is the setup code:
String dbName = "library";
String hbName = "MySF";
HbDataStore hbds = (HbDataStore) HbHelper.INSTANCE
.createRegisterDataStore(hbName);
final Properties props = new Properties();
props.setProperty(Environment.DRIVER, "com.mysql.jdbc.Driver");
props.setProperty(Environment.USER, "finster");
props.setProperty(Environment.URL, "jdbc:mysql://127.0.0.1:3306/"+dbName);
props.setProperty(Environment.PASS, "xxxxx");
props.setProperty(Environment.DIALECT,
org.hibernate.dialect.MySQLInnoDBDialect.class.getName());
hbds.setProperties(props);
hbds.setEPackages(new EPackage[] { libPackage });
hbds.initialize();
When I try hbd.initialize() the following error (attached below) is issued.
Can anyone give me a pointer please?
Kind regards
Harald
!SESSION 2009-07-04 21:45:26.738
eclipse.buildId=unknown
java.version=1.6.0_10-rc
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -application TestRCP_EMF_Hibernate1.application
Command-line arguments: -application TestRCP_EMF_Hibernate1.application
-data
/home/finster/EMBED/workspace/../runtime-TestRCP_EMF_Hiberna te1.application
-dev
file:/home/finster/EMBED/workspace/.metadata/.plugins/org.ec lipse.pde.core/TestRCP_EMF_Hibernate1.application/dev.proper ties
-os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.osgi 4 0 2009-07-04 21:45:29.491
!MESSAGE Application error
!STACK 1
at
org.hibernate.impl.SessionFactoryImpl.registerEntityNameReso lvers(SessionFactoryImpl.java:440)
at
org.hibernate.impl.SessionFactoryImpl.registerEntityNameReso lvers(SessionFactoryImpl.java:435)
at
org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:330)
at
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1341)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.buildSess ionFactory(HbSessionDataStore.java:171)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:83)
at
testrcp_emf_hibernate1.ApplicationWorkbenchAdvisor.setUpSamp leEMF(ApplicationWorkbenchAdvisor.java:102)
at
testrcp_emf_hibernate1.ApplicationWorkbenchAdvisor.createWor kbenchWindowAdvisor(ApplicationWorkbenchAdvisor.java:23)
at
org.eclipse.ui.internal.WorkbenchWindow.getWindowAdvisor(Wor kbenchWindow.java:3437)
at
org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpening(Wo rkbenchWindow.java:1284)
at org.eclipse.ui.internal.WorkbenchWindow.<init>(WorkbenchWindow.java:398)
at
org.eclipse.ui.internal.tweaklets.Workbench3xImplementation. createWorkbenchWindow(Workbench3xImplementation.java:31)
at
org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workben ch.java:1731)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:1 729)
at
org.eclipse.ui.internal.Workbench$19.runWithException(Workbe nch.java:1023)
at
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3468)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3115)
at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at
org.eclipse.ui.internal.Workbench$28.runWithException(Workbe nch.java:1384)
at
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:179)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4113)
at
org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:94)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1379)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2335)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at testrcp_emf_hibernate1.Application.start(Application.java:20 )
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
This is the output of the log at hibernate/teneo startup:
9 [main] INFO org.hibernate.cfg.Environment - Hibernate 3.3.2.GA
11 [main] INFO org.hibernate.cfg.Environment - hibernate.properties not
found
14 [main] INFO org.hibernate.cfg.Environment - Bytecode provider name :
javassist
16 [main] INFO org.hibernate.cfg.Environment - using JDK 1.4
java.sql.Timestamp handling
411 [main] INFO org.hibernate.cfg.HbmBinder - Mapping class: Book -> book
Jul 4, 2009 9:45:29 PM org.eclipse.emf.teneo.hibernate.HbDataStore
setDefaultProperties
WARNING: No hibernate cache provider set, using
org.hibernate.cache.HashtableCacheProvider
WARNING: For production use please set the ehcache (or other) provider
explicitly and configure it
INFO: Hibernate property: hibernate.hbm2ddl.auto not set, setting to update
logProperties
INFO: teneo.mapping.fetch_containment_eagerly: false
logProperties
INFO: hibernate.connection.password: xxxxxx
logProperties
INFO: teneo.naming.sql_fk_name_prefix:
logProperties
INFO: hibernate.cache.provider_class:
logProperties
INFO: teneo.naming.version_column: e_version
logProperties
INFO: teneo.mapping.disable_econtainer: false
logProperties
INFO: hibernate.connection.username: finster
logProperties
INFO: teneo.naming.econtainer_feature_persistence_strategy: FEATURENAME
logProperties
INFO: teneo.mapping.default_cache_strategy: NONE
logProperties
INFO: teneo.mapping.sql_name_escape_character: `
logProperties
INFO: teneo.mapping.set_default_cascade_on_non_containment:
logProperties
INFO: teneo.mapping.map_all_lists_as_idbag: false
logProperties
INFO: teneo.naming.max_sql_name_length: -1
logProperties
INFO: teneo.mapping.default_temporal: TIMESTAMP
logProperties
INFO: teneo.mapping.emap_as_true_map: true
logProperties
INFO: teneo.mapping.default_varchar_length: -1
logProperties
INFO: teneo.naming.default_id_column: e_id
logProperties
INFO: teneo.mapping.also_map_as_class: true
logProperties
INFO: teneo.mapping.add_index_for_fk: false
logProperties
INFO: teneo.naming.join_table_naming_strategy: unique
logProperties
INFO: teneo.runtime.handle_unset_as_null: false
logProperties
INFO: teneo.mapping.XSDDateClass: javax.xml.datatype.XMLGregorianCalendar
logProperties
INFO: teneo.mapping.always_version: true
logProperties
INFO: teneo.naming.idbag_id_column_name: ID
logProperties
INFO: teneo.mapping.max_comment_length: 0
logProperties
INFO: teneo.naming.sql_table_name_prefix:
logProperties
INFO: teneo.mapping.set_entity_automatically: true
logProperties
INFO: teneo.mapping.hibernate_mapping_file: false
logProperties
INFO: teneo.naming.set_foreign_key_name: true
logProperties
INFO: teneo.mapping.cascade_policy_on_containment: ALL
logProperties
INFO: teneo.naming.id_feature_as_primary_key: true
logProperties
INFO: teneo.naming.set_generated_value_on_id_feature: true
logProperties
INFO: hibernate.connection.driver_class: com.mysql.jdbc.Driver
logProperties
INFO: teneo.runtime.update_schema: false
logProperties
INFO: teneo.naming.sql_discriminator_version_immutable_eclass: true
logProperties
INFO: teneo.naming.strategy: lowercase
logProperties
INFO: teneo.mapping.always_map_list_as_bag: false
logProperties
INFO: teneo.mapping.UserDateTimeType:
org.eclipse.emf.teneo.hibernate.mapping.XSDDateTime
logProperties
INFO: hibernate.connection.url: jdbc:mysql://127.0.0.1:3306/library
logProperties
INFO: hibernate.dialect: org.hibernate.dialect.MySQLInnoDBDialect
logProperties
INFO: teneo.naming.join_column_naming_strategy: unique
logProperties
INFO: teneo.mapping.set_proxy: false
logProperties
INFO: teneo.mapping.UserDateType:
logProperties
INFO: teneo.mapping.cascade_policy_on_non_containment:
logProperties
INFO: teneo.mapping.ignore_eannotations: false
logProperties
INFO: hibernate.hbm2ddl.auto: update
logProperties
INFO: teneo.naming.default_id_feature: e_id
logProperties
INFO: teneo.mapping.map_embeddable_as_embedded: false
logProperties
INFO: teneo.mapping.optimistic_locking: true
logProperties
INFO: teneo.naming.sql_column_name_prefix:
logProperties
INFO: teneo.mapping.join_table_for_non_contained_associations: true
logProperties
INFO: teneo.mapping.cascade_all_on_containment:
485 [main] INFO org.hibernate.connection.DriverManagerConnectionProvider
- Using Hibernate built-in connection pool (not for production use!)
486 [main] INFO org.hibernate.connection.DriverManagerConnectionProvider
- Hibernate connection pool size: 20
- autocommit mode: false
492 [main] INFO org.hibernate.connection.DriverManagerConnectionProvider
- using driver: com.mysql.jdbc.Driver at URL:
- connection properties: {user=finster, password=****}
685 [main] INFO org.hibernate.cfg.SettingsFactory - RDBMS: MySQL,
version: 5.0.45
685 [main] INFO org.hibernate.cfg.SettingsFactory - JDBC driver:
MySQL-AB JDBC Driver, version: mysql-connector-java-5.1.7 ( Revision:
${svn.Revision} )
701 [main] INFO org.hibernate.dialect.Dialect - Using dialect:
704 [main] INFO org.hibernate.transaction.TransactionFactoryFactory -
Using default transaction strategy (direct JDBC transactions)
705 [main] INFO
org.hibernate.transaction.TransactionManagerLookupFactory - No
TransactionManagerLookup configured (in JTA environment, use of
read-write or transactional second-level cache is not recommended)
705 [main] INFO org.hibernate.cfg.SettingsFactory - Automatic flush
during beforeCompletion(): disabled
705 [main] INFO org.hibernate.cfg.SettingsFactory - Automatic session
close at end of transaction: disabled
705 [main] INFO org.hibernate.cfg.SettingsFactory - JDBC batch size: 15
705 [main] INFO org.hibernate.cfg.SettingsFactory - JDBC batch updates
for versioned data: disabled
706 [main] INFO org.hibernate.cfg.SettingsFactory - Scrollable result
sets: enabled
706 [main] INFO org.hibernate.cfg.SettingsFactory - JDBC3
getGeneratedKeys(): enabled
706 [main] INFO org.hibernate.cfg.SettingsFactory - Connection release
mode: auto
706 [main] INFO org.hibernate.cfg.SettingsFactory - Maximum outer join
fetch depth: 2
707 [main] INFO org.hibernate.cfg.SettingsFactory - Default batch fetch
707 [main] INFO org.hibernate.cfg.SettingsFactory - Generate SQL with
comments: disabled
707 [main] INFO org.hibernate.cfg.SettingsFactory - Order SQL updates by
primary key: disabled
707 [main] INFO org.hibernate.cfg.SettingsFactory - Order SQL inserts
for batching: disabled
707 [main] INFO org.hibernate.cfg.SettingsFactory - Query translator:
org.hibernate.hql.ast.ASTQueryTranslatorFactory
708 [main] INFO org.hibernate.hql.ast.ASTQueryTranslatorFactory - Using
708 [main] INFO org.hibernate.cfg.SettingsFactory - Query language
substitutions: {}
708 [main] INFO org.hibernate.cfg.SettingsFactory - JPA-QL strict
compliance: disabled
708 [main] INFO org.hibernate.cfg.SettingsFactory - Second-level cache:
enabled
708 [main] INFO org.hibernate.cfg.SettingsFactory - Query cache: disabled
710 [main] INFO org.hibernate.cfg.SettingsFactory - Cache region factory
: org.hibernate.cache.impl.bridge.RegionFactoryCacheProviderBr idge
711 [main] INFO
org.hibernate.cache.impl.bridge.RegionFactoryCacheProviderBr idge - Cache
provider: org.hibernate.cache.HashtableCacheProvider
711 [main] INFO org.hibernate.cfg.SettingsFactory - Optimize cache for
minimal puts: disabled
711 [main] INFO org.hibernate.cfg.SettingsFactory - Structured
second-level cache entries: disabled
714 [main] INFO org.hibernate.cfg.SettingsFactory - Statistics: disabled
714 [main] INFO org.hibernate.cfg.SettingsFactory - Deleted entity
synthetic identifier rollback: disabled
714 [main] INFO org.hibernate.cfg.SettingsFactory - Default entity-mode:
pojo
714 [main] INFO org.hibernate.cfg.SettingsFactory - Named query checking
: enabled
745 [main] INFO org.hibernate.impl.SessionFactoryImpl - building session
factory
Re: java.lang.AbstractMethodError in registerEntityNameResolvers [message #431237 is a reply to message #431236] Sat, 04 July 2009 17:15 Go to previous messageGo to next message
Hi Harald,
Which Teneo version are you using? Only the latest Teneo 1.1.1 maintenance build works with hibernate 3.3.2 GA.
See also a post with this title a few days back:
Teneo 1.0.4/Teneo 1.1.1 Maintenance Builds, Hibernate version, xsd:any/xsd:anytype
I checked but I still can't find this build on an update site... :-(. Will check this further.
In the mean time you can download the 1.1.1 build directly on this page (scroll a little down).
http://www.eclipse.org/modeling/emf/downloads/?showAll=1& ;project=teneo&hlbuild=M200906300456#M200906300456
gr. Martin
Harald Finster wrote:
> Hello,
> as follows:
> hbds.initialize();
> Kind regards
> Harald
> -data
> -dev
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> found
> javassist
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> version: 5.0.45
> ${svn.Revision} )
> 705 [main] INFO
> sets: enabled
> mode: auto
> fetch depth: 2
> comments: disabled
> substitutions: {}
> enabled
> 711 [main] INFO
> pojo
> : enabled
> factory
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: java.lang.AbstractMethodError in registerEntityNameResolvers [message #431240 is a reply to message #431237] Sun, 05 July 2009 04:12 Go to previous messageGo to next message
Hi Martin,
thanks a million for your reply.
I should have mentioned in my original posting,
that I am using teneo 1.1.0. My apologies.)
So, I am (once more) lost in the version-dependency-hell ;-)
I will try your suggestion with 1.1.1 or downgrade
to an older hibernate version.
(I will report about the results here.)
Again, thanks for your support and especially for all
the marvelous tools!
Greetings Harald
Martin Taal wrote:
> Hi Harald,
> xsd:any/xsd:anytype
[ ... RCP/teneo/hibernate application fails ... ]
>> !STACK 1
>> at
Re: java.lang.AbstractMethodError in registerEntityNameResolvers [message #431241 is a reply to message #431237] Sun, 05 July 2009 04:24 Go to previous message
Hi again,
Martin Taal wrote:
> Hi Harald,
this works like a charm!
Thanks a million!
Greetings Harald
Previous Topic:The definitive truth about multiple inheritance
Next Topic:EAttribute.getDefaultValue returns Integer(0) when upperbound=-1 and eDataType is integer
Current Time: Sat Jul 19 05:44:54 EDT 2025
Powered by FUDForum. Page generated in 0.04416 seconds
