Home » Modeling » EMF » Hide elements in [List]Viewer
Hide elements in [List]Viewer [message #431182] |
Wed, 01 July 2009 14:12  |
My model:
Gruppe - Leiter - Person
1 - N 1 - 1
I have two ListViewers. There are view things from different resources.
On the left there is a complete list of Persons and on the right one is
the detail from a masterDetail scenario.
Now when I load the application new, all persons are viewed on the left
one. When I add a person to the detail view, the Person is removed from
the left viewer and added to the right. Thats all fine, but i would when
I start the application in the left one all persons are viewed in the
left one without there in the right on.
In my meaning i should implement a Filter, but i have problems with it,
can you help me there?
This are my inputs:
For my Detail ListViewer:
leiterAuswahl.setInput(EMFEditObservables.observeDetailList( Realm
.getDefault(), p.getEditingDomain(), viewerSelection,
ZlvpPackage.Literals.GRUPPEN__LEITER));
For my all Persons Viewer:
getPersons is a IObservableList.
leiter.setInput(p.getPersons());
it should be p.getPersons()-ZlvpPackage.Literals.GRUPPEN__LEITER) ;-)
Annother realy easy an short question:
I do this:
Command cmdRemove = RemoveCommand.create(p.getEditingDomain(), gruppe,
ZlvpPackage.Literals.GRUPPEN__LEITER, leiter);
if (cmdRemove.canExecute()) {
p.getEditingDomain().getCommandStack().execute(cmdRemove);
p.getResourcePerson().getContents().add(leiter.getPerson());
}else{
System.out.println("Hat ned geklappt");
It works fine but ithink it dirty. Is there another way to delete only a
reference? Only this: Command cmdRemove =
Deletes the Person and the Leiter...
Re: Hide elements in [List]Viewer [message #431185 is a reply to message #431182] |
Wed, 01 July 2009 15:11   |
Waldi Waldemar schrieb:
> My model:
> 1 - N 1 - 1
> This are my inputs:
> viewerSelection,
ViewerFilter?
> I do this:
> }else{
I'm not sure I understand what you are asking.
Tom
Re: Hide elements in [List]Viewer [message #431187 is a reply to message #431185] |
Wed, 01 July 2009 15:25   |
I mean a thing like this (if you had another way, i can use it):
Taken from the TeamAdmin example.
public class ViewFilterImpl extends ViewerFilter {
public boolean select(Viewer viewer, Object parentElement, Object
element)
if (element != null && element instanceof Person)
if(element is in the other ListViewer){
return false;
return true;
Explanation to your secound statement:
In the Database is save a association between the Leiter and the person.
I will delete the Leiter without the person. How can I do this better
than below.
>> Hi,
>> My model:
>> 1 - N 1 - 1
>> This are my inputs:
>> viewerSelection,
> ViewerFilter?
>> I do this:
>> }else{
> Tom
Re: Hide elements in [List]Viewer [message #431191 is a reply to message #431190] |
Wed, 01 July 2009 15:47   |
Teneo doesn't care if you are going through the EditingDomain or not but
Undo/Redo does.
To execute a Command on the Resource you need to:
--------8<--------
AddCommand.create(
p.getResourcePerson().getContents(),
leiter.getPerson()
--------8<--------
Tom
> But it works fine, Teneo delete only the Leiter, not the Person.
> I try this but it doesnt work
> Command cmdAdd = AddCommand.create(p.getEditingDomain(), null,
> ZlvpPackage.Literals.PERSON, leiter.getPerson());
> Person has no owner...
>>>> I do this:
>> Not going through the editing-domain with the add looks wrong!
>> Tom
Re: Hide elements in [List]Viewer [message #431192 is a reply to message #431191] |
Wed, 01 July 2009 16:02   |
Your Snipped doesn't run. The
AddCommand.create(want,four,parameters,not) three
This Command cmdAdd =
AddCommand.create(p.getEditingDomain(),p.getResourcePerson() .getContents(),
doesn't run to
> Undo/Redo does.
> --------8<--------
> AddCommand.create(
> leiter.getPerson()
> --------8<--------
> Tom
>>>>> I do this:
>>> Tom
Re: Hide elements in [List]Viewer [message #431193 is a reply to message #431192] |
Wed, 01 July 2009 16:04   |
Sorry:
new AddCommand(....)
Tom
> doesn't run to
>> Undo/Redo does.
>> --------8<--------
>> AddCommand.create(
>> leiter.getPerson()
>> --------8<--------
>> Tom
>>>>>> I do this:
>>>>>> gruppe,
>>>> Tom
Re: Hide elements in [List]Viewer [message #431194 is a reply to message #431193] |
Wed, 01 July 2009 16:18   |
Worked fine.
Have you a solution for my question above? I haven't a idea how to
implement the ViewerFilter. I try some things and play with it but no
success.
> Sorry:
> Tom
>> doesn't run to
>>> Undo/Redo does.
>>> --------8<--------
>>> AddCommand.create(
>>> leiter.getPerson()
>>> --------8<--------
>>> Tom
>>>>>>> I do this:
>>>>>>> gruppe,
>>>>> Tom
Re: Hide elements in [List]Viewer [message #431195 is a reply to message #431194] |
Wed, 01 July 2009 16:53   |
I don't get what the problem should be a simply check of the opposite
(right hand side) IObservableList.contains(o) should be enough to find
out if you want filter out or not.
Tom
> Worked fine.
> success.
>> Sorry:
>> Tom
>>> doesn't run to
>>>> but
>>>> Undo/Redo does.
>>>> --------8<--------
>>>> AddCommand.create(
>>>> leiter.getPerson()
>>>> --------8<--------
>>>> Tom
>>>>>>>> I do this:
>>>>>>>> gruppe,
>>>>>> Tom
Re: Hide elements in [List]Viewer [message #431197 is a reply to message #431195] |
Thu, 02 July 2009 05:28  |
Ok... I try it, no success:
Try:
IObservableList detailList = EMFEditObservables.observeDetailList(Realm
ZlvpPackage.Literals.GRUPPEN__LEITER);
Person personFromCompleteList = (Person)element;
if (detailList.contains(personFromCompleteList)) {
//never comes here ... because thats Leiter, no Persons
return false;
then i try this. Ok its a dirty way but see you another solution?
Iterator<?> iterator = detailList.iterator();
while(iterator.hasNext()){
Leiter tempLeiter = (Leiter) iterator.next();
Person tempPerson = tempLeiter.getPerson();
if (tempPerson.getId() == personFromCompleteList.getId()) {
return false;
Thanks for your help
"Tom Schindl" <tom.schindl@bestsolution.at> schrieb im Newsbeitrag
news:h2gibs$t1k$1@build.eclipse.org...
> Tom
>> Worked fine.
>> success.
>>> Sorry:
>>> Tom
>>>> doesn't run to
>>>>> but
>>>>> Undo/Redo does.
>>>>> --------8<--------
>>>>> AddCommand.create(
>>>>> leiter.getPerson()
>>>>> --------8<--------
>>>>> Tom
>>>>>>>>> I do this:
>>>>>>>>> gruppe,
>>>>>>> Tom
Current Time: Sat Jul 19 11:24:04 EDT 2025
Powered by FUDForum. Page generated in 0.04721 seconds
