Home » Modeling » EMF » [TENEO] EMF, Association, Update and Resources
[TENEO] EMF, Association, Update and Resources [message #430828] |
Thu, 11 June 2009 09:37  |
I have a problem. The following:
A list of persons saved in a database table.
This list of persons are viewed in a listViewer
Now I have leiter and a leiter is a Person.
You can see it here:
Person p = Modelpackage.eInstance.createPerson;
Leiter l = Modelpackage.eInstance.createLeiter;
l.setPerson(p);
If i assosiate this two things I execute the command:
(1 Gruppe : N Leiter)
Leiter le = ZlvpFactory.eINSTANCE.createLeiter();
le.setPerson(person);
Command cmd = AddCommand.create(p.getEditingDomain(), gruppe,
ZlvpPackage.Literals.GRUPPEN__LEITER, le);
if (cmd.canExecute()) {
p.getEditingDomain().getCommandStack().execute(cmd);
All works fine, but in the database a Person is added and not updated.
A list of persons I got on this way:
SessionController.registerSessionController("testsc", sc);
String uriStr2 = "hibernate://?" +
HibernateResource.SESSION_CONTROLLER_PARAM + "="
+ "testsc&query1=FROM Person";
final URI uri2 = URI.createURI(uriStr2);
resPerson = getResourceSet().createResource(uri2);
resPerson.load(Collections.EMPTY_MAP);
In my opinion no data of a person should be change, and if they change,
its ok but dont add someone.
Re: [TENEO] EMF, Association, Update and Resources [message #430830 is a reply to message #430828] |
Thu, 11 June 2009 10:11   |
Hi Waldi,
How is the id or version of the Person type mapped to hibernate? (call dataStore.getMappingXML() to get to the mapping xml).
Hibernate will typically create a new record/instance in the database if the id or version of the object is not set.
Only if the id is set it can detect/query for an existing object in the database and update it. Your example code below
does not show how the id is set so I wonder if the issue may be related to that.
gr. Martin
> l.setPerson(p);
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [TENEO] EMF, Association, Update and Resources [message #430833 is a reply to message #430832] |
Thu, 11 June 2009 11:02   |
Hi Waldi,
Before looking at version first lets be sure that not something else is in the way.
I am sorry but as there are different code snippets I don't know what is done is in which order. What is p1 in the last
example?
I assume what you mean is after you do this:
leiter.setPerson(p);
session.save(leiter);
that p is present twice in the db. Is the value of p.id set when p is added to the leiter (and it has the correct value?)?
gr. Martin
> Hi Martin,
> if i inspect the Person object in the debug mode, the id is set. The
> version I don't see. Is the Version important in this case? I can
> implement it in the Model. My guess is that the AddCommand always create
> a new Object.
> The mapping is attached.
> If I have a look on the table a Person who i create on this way
> Person p2 = ZlvpFactory.eINSTANCE.createPerson();
> p2.setVorname("TestN");
> p2.setNachname("TestV");
> Anrede a2 = ZlvpFactory.eINSTANCE.createAnrede();
> a2.setName("Herr");
> Geschlecht ge2 = ZlvpFactory.eINSTANCE.createGeschlecht();
> ge2.setName("Männlich");
> p2.setAnrede(a2);
> p2.setGeschlecht(ge2);
> tx.begin();
> session.save(p1);
> session.save(p2);
> tx.commit();
> 11;"Person";0;"TestN";"TestV";"";"";"";"";"";""; "";"";12;13;;;"";"";""
> After the association it is:
> 5;"Person";6;"TestN";"TestV";"";"";"";"";"";"";" ";"";6;7;;;"Leiter";"4";"http://zlvp/1.0_;_Leiter_;_http://zlvp/1.0_;_Leiter_;_person"
> Martin Taal schrieb:
>> Hi Waldi,
>> if the id or version of the object is not set. Only if the id is set
>> it. Your example code below does not show how the id is set so I
>> gr. Martin
>>> l.setPerson(p);
>>> change, its ok but dont add someone.
The Netherlands
Re: [TENEO] EMF, Association, Update and Resources [message #430835 is a reply to message #430833] |
Thu, 11 June 2009 12:18   |
Ok, sorry for this a little bit strange things. In order I do:
1. Create some example data's - all is ok
2. Load all Persons from the Table - like: - all is ok
3. Then I take the selecten of the ListViewer and add the selected
person to the model on this way:
4. And now in my Database are two same persons. The difference is:
11;"Person";0;"TestN";"TestV";"";"";"";"";"";""; "";"";12;13;;;"";"";"" -
Create Person on the normal way like in you qick start example
- This Person is created by the AddCommand.....
I delete the database and recreate it. When I have a look on the
variables.... All ID's are setted and correct: The Gruppe ID is 3, The
Leiter ID is null (because its new) the Person ID in the Leiter is 8 and
the Person id is 8
Hope this helps
> Hi Waldi,
> in the way.
> done is in which order. What is p1 in the last example?
> gr. Martin
>> Hi Martin,
>> create a new Object.
>> a2.setName("Herr");
>> p2.setAnrede(a2);
>> tx.begin();
>> session.save(p1);
>> session.save(p2);
>> tx.commit();
>>> Hi Waldi,
>>> gr. Martin
>>>> l.setPerson(p);
Re: [TENEO] EMF, Association, Update and Resources [message #430836 is a reply to message #430835] |
Thu, 11 June 2009 12:29   |
Hi Waldi,
Okay, is the person instance you load from the database the exact same object instance which is set in leiter (can you
check after the save has been done)? I ask because in your hibernate mapping you have a so-called 'synthetic version',
this is done by Teneo if there is no explicit version eattribute present. However, this version eattribute works only
with object instance equality.
I am not sure either what the AddCommand exactly performs, at what point does the actual save occur?
gr. Martin
> the Person id is 8
> Hope this helps
>> Hi Waldi,
>> is in the way.
>> is done is in which order. What is p1 in the last example?
>> gr. Martin
>>> Hi Martin,
>>> a2.setName("Herr");
>>> p2.setAnrede(a2);
>>> tx.begin();
>>> session.save(p1);
>>> session.save(p2);
>>> tx.commit();
>>>> Hi Waldi,
>>>> database if the id or version of the object is not set. Only if the
>>>> and update it. Your example code below does not show how the id is
>>>> gr. Martin
>>>>> l.setPerson(p);
The Netherlands
Re: [TENEO] EMF, Association, Update and Resources [message #430837 is a reply to message #430836] |
Thu, 11 June 2009 12:55   |
answers below
> Hi Waldi,
> object instance which is set in leiter (can you check after the save has
> been done)?
Yes it's the same object instance.
No, I can't check. I can check it till Command cmd =
Till this all attributes are the same as in the database.
> 'synthetic version', this is done by Teneo if there is no explicit
Ok that can be the failure. Now i should model a version attribute and
add a annotation on it that i can see on the runtime the actual version
of the object?
What mean it exactly?
I don't understand this question. The save is done with Strg+S and it
execute resource.save - this save all what is in the command stack.
> gr. Martin
>> - Create Person on the normal way like in you qick start example
>> and the Person id is 8
>> Hope this helps
>>> Hi Waldi,
>>> is in the way.
>>> gr. Martin
>>>> Hi Martin,
>>>> a2.setName("Herr");
>>>> p2.setAnrede(a2);
>>>> tx.begin();
>>>> session.save(p1);
>>>> session.save(p2);
>>>> tx.commit();
>>>>> Hi Waldi,
>>>>> database and update it. Your example code below does not show how
>>>>> gr. Martin
>>>>>> l.setPerson(p);
>>>>>> updated.
Re: [TENEO] EMF, Association, Update and Resources [message #430838 is a reply to message #430837] |
Thu, 11 June 2009 13:08   |
Hi Waldi,
Reaction inline, marked with MT>>
So after saving the resource, the id of the person has changed (in-memory)?
Yes it is best to have a version eattribute anyway, so if you can model that and annotate it with @Version.
Then let me know if the problem is still there (or not...hopefully).
gr. Martin
> answers below
>> Hi Waldi,
>> has been done)?
> of the object?
>> However, this version eattribute works only with object instance
>> equality.
MT>> The synthetic version logic is implemented in the IdentifierCacheHandler. That handler compares objects like this:
o1 == o2 to find the version of an eobject.
MT>> Okay when the resource is saved
>> gr. Martin
>>> The Leiter ID is null (because its new) the Person ID in the Leiter
>>> is 8 and the Person id is 8
>>> Hope this helps
>>>> Hi Waldi,
>>>> is in the way.
>>>> what is done is in which order. What is p1 in the last example?
>>>> gr. Martin
>>>>> Hi Martin,
>>>>> The version I don't see. Is the Version important in this case? I
>>>>> can implement it in the Model. My guess is that the AddCommand
>>>>> always create a new Object.
>>>>> a2.setName("Herr");
>>>>> p2.setAnrede(a2);
>>>>> tx.begin();
>>>>> session.save(p1);
>>>>> session.save(p2);
>>>>> tx.commit();
>>>>>> Hi Waldi,
>>>>>> gr. Martin
>>>>>>> l.setPerson(p);
>>>>>>> updated.
The Netherlands
Re: [TENEO] EMF, Association, Update and Resources [message #430840 is a reply to message #430838] |
Thu, 11 June 2009 14:45   |
--------------060302050205040805040905
ok, i've attach a snapshot. You can see the values... The problem is the
same. Hmm what can I do now? That you can understand the complete thing
I've attach the *.ecore. I think you can understand german ;-)
> Hi Waldi,
> gr. Martin
>> answers below
>>> Hi Waldi,
>>> same object instance which is set in leiter (can you check after the
>> version of the object?
>>> equality.
> IdentifierCacheHandler. That handler compares objects like this: o1 ==
>>> gr. Martin
>>>> Hope this helps
>>>>> Hi Waldi,
>>>>> else is in the way.
>>>>> gr. Martin
>>>>>> Hi Martin,
>>>>>> a2.setName("Herr");
>>>>>> ge2.setName("M
Re: [TENEO] EMF, Association, Update and Resources [message #430841 is a reply to message #430840] |
Thu, 11 June 2009 14:50   |
Yes I can read German no problem :-).
Can you replicate the issue without resources or using AddCommand but just doing plain hibernate session.save etc.? If
you can then send me the test program then I can try it out myself. The ecore you attached is complete (I don't need
other ecores)?
gr. Martin
>> Hi Waldi,
>> (in-memory)?
>> gr. Martin
>>> answers below
>>>> Hi Waldi,
>>> and add a annotation on it that i can see on the runtime the actual
>>>> equality.
>>>> gr. Martin
>>>>> Hope this helps
>>>>>> Hi Waldi,
>>>>>> else is in the way.
>>>>>> gr. Martin
>>>>>>> Hi Martin,
>>>>>>> a2.setName("Herr");
>>>>>>> p2.setAnrede(a2);
>>>>>>> tx.begin();
>>>>>>> session.save(p1);
>>>>>>> session.save(p2);
>>>>>>> tx.commit();
>>>>>>>> Hi Waldi,
>>>>>>>> gr. Martin
>>>>>>>>> l.setPerson(p);
>>>>>>>>> updated.
The Netherlands
Re: [TENEO] EMF, Association, Update and Resources [message #430842 is a reply to message #430841] |
Thu, 11 June 2009 15:06   |
Yes its complete, you don't need more. For the example program I give
you a response on the next week. On this week I haven't time. The
Problem is that the complete program is a RCP EMF programm based on the
databinding example from Tom Schindl (Library example).... I will look
what i can do...
Can you set up a postgres DB? In this case i can send you the complete
program. Then you can change the login informations... But I think its a
lot of work...
> just doing plain hibernate session.save etc.? If you can then send me
> complete (I don't need other ecores)?
> gr. Martin
>> the same. Hmm what can I do now? That you can understand the complete
>> thing I've attach the *.ecore. I think you can understand german ;-)
>>> Hi Waldi,
>>> (in-memory)?
>>> gr. Martin
>>>> answers below
>>>>> Hi Waldi,
>>>>> equality.
>>>> it execute resource.save - this save all what is in the command stack.
>>>>> gr. Martin
>>>>>> Leiter is 8 and the Person id is 8
>>>>>> Hope this helps
>>>>>>> Hi Waldi,
>>>>>>> else is in the way.
>>>>>>> gr. Martin
>>>>>>>> Hi Martin,
>>>>>>>> I can implement it in the Model. My guess is that the AddCommand
>>>>>>>> a2.setName("Herr");
>>>>>>>> p2.setAnrede(a2);
>>>>>>>> tx.begin();
>>>>>>>> session.save(p1);
>>>>>>>> session.save(p2);
>>>>>>>> tx.commit();
>>>>>>>>> Hi Waldi,
>>>>>>>>> mapping xml).
>>>>>>>>> gr. Martin
>>>>>>>>>> l.setPerson(p);
>>>>>>>>>> updated.
>>>>>>>>>> they change, its ok but dont add someone.
Re: [TENEO] EMF, Association, Update and Resources [message #430843 is a reply to message #430842] |
Thu, 11 June 2009 17:25   |
Hi Waldi,
If you want you can enter a bugzilla for this then we have something to track this possible issue. If you can attach the
ecore and any other information you may have that would be helpfull.
gr. Martin
> what i can do...
> lot of work...
>> is complete (I don't need other ecores)?
>> gr. Martin
>>>> Hi Waldi,
>>>> (in-memory)?
>>>> gr. Martin
>>>>> answers below
>>>>>> Hi Waldi,
>>>>>> equality.
>>>>>> gr. Martin
>>>>>>> selected person to the model on this way:
>>>>>>> 3, The Leiter ID is null (because its new) the Person ID in the
>>>>>>> Hope this helps
>>>>>>>> Hi Waldi,
>>>>>>>> else is in the way.
>>>>>>>> gr. Martin
>>>>>>>>> Hi Martin,
>>>>>>>>> set. The version I don't see. Is the Version important in this
>>>>>>>>> case? I can implement it in the Model. My guess is that the
>>>>>>>>> AddCommand always create a new Object.
>>>>>>>>> a2.setName("Herr");
>>>>>>>>> p2.setAnrede(a2);
>>>>>>>>> tx.begin();
>>>>>>>>> session.save(p1);
>>>>>>>>> session.save(p2);
>>>>>>>>> tx.commit();
>>>>>>>>>> Hi Waldi,
>>>>>>>>>> mapping xml).
>>>>>>>>>> the database and update it. Your example code below does not
>>>>>>>>>> to that.
>>>>>>>>>> gr. Martin
>>>>>>>>>>> l.setPerson(p);
>>>>>>>>>>> updated.
The Netherlands
Current Time: Sun Jul 20 03:21:40 EDT 2025
Powered by FUDForum. Page generated in 0.07130 seconds
