Home » Modeling » EMF » [Validation Framework] Validating extended models.
[Validation Framework] Validating extended models. [message #430596] Thu, 28 May 2009 14:08 Go to next message
Hi everybody.
I'm trying to use the validation framework through invariant operations
included in the ecore models (as described in the EMF book, second
edition, chapter 18), and launching the validation from within the
generated editor (runtime workbench).
I'm working on an extended EMF model, in a similar way to what is
described in the "Generating an Extended EMF Model" tutorial.
My problem is that if i run the validation on the root element (instance
of a meta-class declared on the base metamodel), the child elements
which are instances of the extension metamodel are not validated.
If the validation is run while selecting an element instance of a
meta-class declared on the extension metamodel, those constraints are
correctly evaluated. Most probably the cause is that the base model
validator is not aware of the extension model validator, and therefore
this one is not called at all.
The question would be, is there a way to make the validation of the base
metamodel include the extension metamodel constraints?. Ideally, without
the base model/code knowing about it. If not, perhaps modifying the base
metamodel generated code. I believe I will have to get the base
metamodel diagnostician or context or similar, and pass it to the
extension validator, but I don't know exactly what to pass and where to
pass it.
Any help will be greatly appreciated.
Juan Pedro
Re: [Validation Framework] Validating extended models. [message #430597 is a reply to message #430596] Thu, 28 May 2009 16:48 Go to previous messageGo to next message
Juan Pedro,
Comments below.
Juan Pedro Silva wrote:
> Hi everybody.
> operations included in the ecore models (as described in the EMF book,
> second edition, chapter 18), and launching the validation from within
> the generated editor (runtime workbench).
> (instance of a meta-class declared on the base metamodel), the child
> elements which are instances of the extension metamodel are not
> validated.
I wouldn't expect such a problem...
The EClass of each instance object should be considered and the package
for that class is determined, and the validator for that package is
used. Base classes are considered if the that package has no
validator. So goes the theory...
> base metamodel include the extension metamodel constraints?.
The validation should be dispatched to the right validator for the
derived model, but it's possible there's a bug I suppose.
> Ideally, without the base model/code knowing about it. If not, perhaps
> modifying the base metamodel generated code. I believe I will have to
> get the base metamodel diagnostician or context or similar, and pass
> it to the extension validator, but I don't know exactly what to pass
> and where to pass it.
Can you share an example illustrating the problem so I can analyze
what's going on... You've tried this with EMF 2.5?
If I can reproduce the problem I'll help...
> Best regards,
> Juan Pedro
Re: [Validation Framework] Validating extended models. [message #430603 is a reply to message #430597] Fri, 29 May 2009 06:44 Go to previous messageGo to next message
Ed, thanks for your interest.
I spent all morning trying to reproduce this behavior, regenerating the
project in different workbenches, tried Galileo and EMF 2.5 etc., only
to find that some containment reference in the base model had been
accidentally marked "derived", so no code was generated for it, and
therefore the validation chain was broken (I believe). Correcting this
fixed the problem. I don't know if this information is useful, but just
in case.
Once again, thanks for your help, for which I'm always grateful.
Juan Pedro
Ed Merks escribió:
> Juan Pedro,
> Comments below.
>> Hi everybody.
>> book, second edition, chapter 18), and launching the validation from
>> within the generated editor (runtime workbench).
>> validated.
>> therefore this one is not called at all.
> package for that class is determined, and the validator for that
> package is used. Base classes are considered if the that package has
> no validator. So goes the theory...
>> perhaps modifying the base metamodel generated code. I believe I will
>> have to get the base metamodel diagnostician or context or similar,
>> and pass it to the extension validator, but I don't know exactly what
>> to pass and where to pass it.
>> Best regards,
>> Juan Pedro
Re: [Validation Framework] Validating extended models. [message #430605 is a reply to message #430603] Fri, 29 May 2009 06:50 Go to previous message
Juan Pedro,
Thanks for letting me know. I would have been surprised if this was so
fundamentally broken...
> the project in different workbenches, tried Galileo and EMF 2.5 etc.,
> only to find that some containment reference in the base model had
> been accidentally marked "derived", so no code was generated for it,
> and therefore the validation chain was broken (I believe). Correcting
> this fixed the problem. I don't know if this information is useful,
> but just in case.
> Regards,
> Juan Pedro
> Ed Merks escribió:
>> Juan Pedro,
>> Comments below.
>>> Hi everybody.
>>> validated.
>>> are correctly evaluated. Most probably the cause is that the base
>>> model validator is not aware of the extension model validator, and
>>> will have to get the base metamodel diagnostician or context or
>>> similar, and pass it to the extension validator, but I don't know
>>> exactly what to pass and where to pass it.
>>> Best regards,
>>> Juan Pedro
Previous Topic:Strange exception when starting plug-in in new Eclipse instance
Next Topic:Generated Classes and Packages names
Current Time: Sat Jul 19 10:34:27 EDT 2025
Powered by FUDForum. Page generated in 0.07864 seconds
