Home » Modeling » EMF » EMF -> EF, anyone?
Re: EMF -> EF, anyone? [message #430591 is a reply to message #430549] |
Thu, 28 May 2009 09:03   |
Easiest solution IMO:
Use Ecore with generated XML Schema serialization not with XMI. Then
export and save Ecore model in "plain" XML and...
Then try what fit best:
- generate C# classes from XSD and use LINQ to objects - typed, works
well, but you need to generate C# classes for all XSDs
- LINQ to XSD - it is typed so you use "Library" and "Book", but I am
not sure how stable this project is
( http://www.microsoft.com/downloads/details.aspx?FamilyID=A45 F58CD-FCFC-439E-B735-8182775560AF&displaylang=en)
- LINQ to XML(XLINQ) - it is not typed, so you use "Element" and
"Attribute", so not that cool, but supported out of the box and mature
Some less attractive solutions:
2) Read Ecore XMI in C# model and use LINQ to objects
Read XMI somehow and then use LINQ to objects or even customize LINQ for
used classes.
Have you checked EMF4NET?
"XML and XMI serialization
Next big milestone. The reflective EObject API is working and a simple
XMI serialization use case is implemented (EClass with attributes can
be serialized)."
It would be good for the community to have EMF4NET XMI (de)serialization
and LINQ for EMF4NET :)
3) Look for, or create LINQ to XMI
One comment below
> Today I was looking for a way to store Ecore models to be queried using
> Microsoft LINQ (as to why, that's another story). Having found no
> ready-made tool, I took a look at the API for retrieving (creating?)
> metadata for consumption by the Entity Framework,
> http://msdn.microsoft.com/en-us/library/bb399772.aspx
AFAIK with Entity Framework you would need new C# Class model for each
Ecore metamodel that you want to read. Hm, it is possible to use Teneo
and Hibernate, or CDO to generate database schema. Then store the EMF
model there. To read it you can then:
- use LINQ to SQL
- use Entity Framework to generate C# entities from generated database
schema and LINQ for Entities
but this is quite complicated.
Krzysztof Kowalczyk
Re: EMF -> EF, anyone? [message #430599 is a reply to message #430591] |
Fri, 29 May 2009 04:21   |
Krzysztof,
I browsed some more into the Ecore -> Entity Data Model scenario,
As per
http://social.msdn.microsoft.com/Forums/de-DE/adodotnetentit yframework/thread/b3ec1d1a-7a5c-4b7d-8277-3d6282777b41
the metadata API I was referring to gives read-only access.
The post above goes on to suggest creating an Entity Data Model in terms of
its XML representation.
There's even an XML schema for that represenation! :)
Which goes by the name of System.Data.Resources.CSDLSchema.xsd , and can be
found (after installing VS 2008 SP 1) at:
%VSInstallFolder%\Xml\Schemas
Miguel
Miguel Garcia miguel.garcia@tuhh.de
Institute for Software Systems (STS), E-16
Technische Universitaet Hamburg-Harburg
Harburger Schlossstr. 20, 21073 Hamburg Fax: (+49)40-42878-2515
http://www.sts.tu-harburg.de/people/mi.garcia
"Krzysztof Kowalczyk" <kowalczyk.krzysztof@gmail.com> wrote in message
news:gvm234$73g$1@build.eclipse.org...
> - LINQ to XSD - it is typed so you use "Library" and "Book", but I am not
> used classes.
> Next big milestone. The reflective EObject API is working and a simple XMI
> serialization use case is implemented (EClass with attributes can be
> serialized)."
> One comment below
> Ecore metamodel that you want to read. Hm, it is possible to use Teneo and
> Hibernate, or CDO to generate database schema. Then store the EMF model
> - use LINQ to SQL
> Regards,
> Krzysztof Kowalczyk
Re: EMF -> EF, anyone? [message #430609 is a reply to message #430599] |
Fri, 29 May 2009 08:32   |
Miguel,
Nice, so You just need to map ".ecore" model to Data Model? Then it
seems to be the solution.
Krzysztof Kowalczyk
> Krzysztof,
> As per
> of its XML representation.
> be found (after installing VS 2008 SP 1) at:
> Miguel
>> for used classes.
>> be serialized)."
>> (de)serialization and LINQ for EMF4NET :)
>> One comment below
>> - use LINQ to SQL
>> database schema and LINQ for Entities
>> Regards,
>> Krzysztof Kowalczyk
Current Time: Sun Jul 20 05:59:21 EDT 2025
Powered by FUDForum. Page generated in 0.04179 seconds
