Home » Modeling » EMF » Dynamic EMF: the feature 'xyz' is not a valid feature
Dynamic EMF: the feature 'xyz' is not a valid feature [message #430563] |
Wed, 27 May 2009 10:11  |
Originally posted by: htran.infosys.tuwien.ac.at
--------------050105010405060008080605
Dear all,
I'm sorry to bring you back to the problem of "IllegalArgumentException:
The feature 'xyz' is not a valid feature" that have been sometimes
investigated before.
I try to make a small example concerning the problem I met.
The ecore model I used is named test.ecore.
test: EPackage (prefix=test, URI=http://test)
+-- A (EClass)
+--- b (EReference, EType=B)
+---B (EClass)
Before, I used Genmodel to generate model code in Java, then used these
Java code to create/serialize/de-serialize my model instance. This
worked perfectly, but no "schemaLocation" included in the serialization.
Therefore, I want to use EMF dynamic feature to create the model
instance without code generated by the Genmodel.
The code for dynamically creating a model instance is given below:
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put(
"ecore", new XMIResourceFactoryImpl());
URI ecoreURI = URI.createFileURI("test.ecore");
ResourceSet resourceSet = new ResourceSetImpl();
Resource resource = resourceSet.getResource(ecoreURI, true);
EPackage mm = (EPackage) resource.getContents().get(0);
// get the meta-class A
EClass A = (EClass) mm.getEClassifier("A");
// create an instance of A
EObject a = mm.getEFactoryInstance().create(A);
// get the EStructuralFeature between A and B
Object a_b = A.eGet(A.getEStructuralFeature(0)); //(1)
boolean isSet = A.eIsSet(A.getEStructuralFeature(0)); //(2)
Unfortunately, I confronted with the well-known exception at either (1)
or (2) (if remove (1)).
Exception in thread "main" java.lang.IllegalArgumentException: The
feature 'b' is not a valid feature
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eOpenGet(BasicEO bjectImpl.java:1062)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1016)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1004)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:999)
at test.TestEMF.main(TestEMF.java:34)
I guessed the exception is raised because the test.ecore package was not
properly registered. Then, I did a lot of searching around and tried a
number of similar hints/guidances for registering an Ecore package but
the problem is not solved.
Could you please give me some hints?
Thanks in advance for your time.
Huy
PS: For your convenience, I attach the test.ecore and the Java code.
Content-Type: text/xml;
name="test.ecore"
Content-Disposition: inline;
filename="test.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="test"
nsURI="http://test" nsPrefix="test">
<eClassifiers xsi:type="ecore:EClass" name="A">
<eStructuralFeatures xsi:type="ecore:EReference" name="b" upperBound="-1" eType="#//B"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="B"/>
</ecore:EPackage>
Content-Type: text/x-java;
name="TestEMF.java"
filename="TestEMF.java"
package test;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl;
public class TestEMF {
Object a_b = A.eGet(A.getEStructuralFeature(0)); // IllegalArgumentException here
boolean isSet = A.eIsSet(A.getEStructuralFeature(0)); // and here
--------------050105010405060008080605--
Re: Dynamic EMF: the feature 'xyz' is not a valid feature [message #430564 is a reply to message #430563] |
Wed, 27 May 2009 10:22   |
Huy,
Comments below.
Huy Tran wrote:
> Dear all,
> "IllegalArgumentException: The feature 'xyz' is not a valid feature"
> that have been sometimes investigated before.
> +-- A (EClass)
> +---B (EClass)
> these Java code to create/serialize/de-serialize my model instance.
> This worked perfectly, but no "schemaLocation" included in the
> serialization.
It's not difficult to have serialization produce one if you like.
You'd use OPTION_SCHEMA_LOCATION to serialize and you'd specialize the
XyzPackageImpl to override createResource to use the schemaLocation
rather than the nsURI for the package's resource.
Shouldn't this be "a" not "A"?
> (1) or (2) (if remove (1)).
> at
> at
> at
> at
> not properly registered.
No, it's because you're trying to look up a feature of A in an EClass.
> Then, I did a lot of searching around and tried a number of similar
> hints/guidances for registering an Ecore package but the problem is
> not solved.
> Regards,
> Huy
Re: Dynamic EMF: the feature 'xyz' is not a valid feature [message #430570 is a reply to message #430569] |
Wed, 27 May 2009 11:09   |
Hi Ed,
Many thanks for your helps. I totally forgot the magic eClass() method.
Huy
Ed Merks wrote:
> Huy,
> Comments below.
> Huy Tran wrote:
>> Hi Ed,
>> Thanks for your very quick and precise response.
>> I quote the relevant code for readability:
>> You're right that I should look up a feature of "a", not "A" here.
>> That's my craziness ;(
>> Unfortunately, "a" is an EObject (more precisely, "a" is a
>> DynamicEObjectImpl instance). Is there any method to look up its
>> features like "getEStructuralFeature()" of an EClass.
> a.eClass().getEAllStructuralFeatures().
>> For instance, how can I exactly look up the feature "b" of "a" in this
>> case?
> a.eGet(a.eClass().getEStructuralFeature("b"))
>> Regards,
>> Huy
How to handle schemaLocation in case of subpackages [message #430578 is a reply to message #430564] |
Wed, 27 May 2009 13:29   |
Hi Ed,
Concerning you recommendation to modify XyzPackageImpl to override
createResource(), I successfully tried this option before. However, I
got stuck in case the ecore file contains many subpackages. For
instance, in the test.ecore:
Test (EPackage, nsURI: http://test)
+----eSubpackage---Sp1 (EPackage, nsURI: http://test/sp1)
| +---A (EClass)
+----eSubpackage---Sp2 (EPackage, nsURI: http://test/sp1)
+---B (EClass)
I used Genmodel to generate the Java code, then, overrode the
createResource() of TestPackageImpl, Sp1PackageImpl, Sp2PackageImpl,
etc., as following:
protected Resource createResource(String uri) {
return
super.createResource("platform:/resource/test-projtect/src/test.ecore ");
This approach worked well and correctly generated the schemaLocation
when I serialized an instance of the EPackage Test (i.e., the root) and
opened it using the "EMF Generic Editor" or the "Sample Reflective Ecore
Model Editor". The corresponding generated schemaLocation is:
xsi:schemaLocation="http://test/
platform:/resource/test-project/src/test/mm.ecore"
However, as I serialized an instance of any subpackage, let say, Sp1,
the schemaLocation is different at the namespace URI, but the location
is, of course, test.ecore.
xsi:schemaLocation="http://test/sp1
The above editors could not open the instance of Sp1 because they could
not find class A within the Sp1 subpackage.
org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'A' not found.
(platform:/resource/test-project/src/test/test.sp1.xmi, 5, 23)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObje ctFromFactory(XMLHandler.java:2229)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObje ctFromFactory(XMLHandler.java:2220)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1318)
Is this the problem of the editors or I did something wrong with the
schemaLocation?
Thanks in advance.
Huy
Re: How to handle schemaLocation in case of subpackages [message #430579 is a reply to message #430578] |
Wed, 27 May 2009 13:47  |
Huy,
Comments below.
Huy Tran wrote:
> Hi Ed,
> | +---A (EClass)
> +---B (EClass)
> etc., as following:
> @Override
> return
Shouldn't they have different locations? If they all point at the same
location, there can't be three different packages...
> and opened it using the "EMF Generic Editor" or the "Sample Reflective
> Ecore Model Editor". The corresponding generated schemaLocation is:
> could not find class A within the Sp1 subpackage.
> at
> at
> at
> schemaLocation?
I very much dislike nested packages and wish I'd never allowed them into
the model. They're a perfect example of syntactic sugar that turns out
to be syntactic rat poison.
> Thanks in advance.
> Regards,
> Huy
Current Time: Sun Jul 20 08:07:17 EDT 2025
Powered by FUDForum. Page generated in 0.04975 seconds
