Problems getting content of loaded resource [message #430550] |
Wed, 27 May 2009 04:10  |
I'm having a strange problem regarding demand-loading resources. I use
getResourceSet().getResource(uri, true); to load a resource identified
by a platform:/plugin/ resource. In some other part of the code I'm
listening to additions to the resources feature of the same resource
set. When a new resource appears, I look at the content of the newly
added resource using resource.getContents().size() and
resource.getContents().get(0); For some reason the contents is empty
because the platform:/plugin/ uri cannot be found.
However, the same resourceSet (actually an editingDomain) is used by an
Ecore editor, and if I asyncExec the code doing
resource.getContents().size() and resource.getContents().get(0), it
works! It's as if the editor get's a chance to load the contents using
some extra tricks for handling platform:/plugin/ uri's. If I knew this
trick I could use it myself, instead of having to wait for the editor to
do it for me!
Hallvard
Re: Problems getting content of loaded resource [message #430557 is a reply to message #430555] |
Wed, 27 May 2009 07:02   |
Ed Merks wrote:
> Hallvard,
> Did you determine this reason by looking at Resource.getErrors()?
I caught an exception saying the resource pointed at by the URI couldn't
be found. For me it looked like the resource had been loaded, but that
the content wasn't filled due to the above error. From looking at the
ResourceImpl code, I gathered that this is normal: A resource is
considered loaded also when it has tried, but failed?
> Keep in mind that when a resource is added to the resource set, it
> generally isn't loaded yet. I.e., this logic creates it and then later
> loads it:
OK, so first the resource is demand created, then adapters are notified
that it has been added, and then it is loaded? I thought it was loaded
before it was added.
But I still wonder about the URI not resolving or finding the the
resource. Perhaps I have misinterpreted the exception? Is there
something that triggers activation of the platform URI handler and this
is done by the editor and not by my code?
> So it sounds like you should really be listening to the resource set for
> resources being added, check if the added resource's isLoaded is true,
> and also listen to the new resource to see when it's loaded, unloaded,
> or otherwise has it's getContents modified...
I will.
Hallvard
Re: Problems getting content of loaded resource [message #430561 is a reply to message #430557] |
Wed, 27 May 2009 08:50  |
Hallvard,
Comments below.
Hallvard Trætteberg wrote:
> Ed Merks wrote:
>> Hallvard,
> couldn't be found. For me it looked like the resource had been loaded,
> but that the content wasn't filled due to the above error. From
> looking at the ResourceImpl code, I gathered that this is normal: A
> resource is considered loaded also when it has tried, but failed?
Yes, this prevents repeated (expensive) attempts to load the resource.
>> later loads it:
> notified that it has been added, and then it is loaded?
Yes.
> I thought it was loaded before it was added.
No.
> resource.
Yes, that seems odd. A platform:/plugin URI is handled just as a "plain
old java.net.URL" for which the Eclipse platform registers a URL handler.
Perhaps.
> Is there something that triggers activation of the platform URI
> handler and this is done by the editor and not by my code?
I think these handlers are registered during startup. Try creating just
a URL and calling openStream on it to see if that's working... That's
basically all the URIConverter will do...
>> for resources being added, check if the added resource's isLoaded is
>> true, and also listen to the new resource to see when it's loaded,
>> unloaded, or otherwise has it's getContents modified...
> I will.
> Hallvard
FUDForum. Page generated in 0.05815 seconds
