Home » Modeling » EMF » [CDO] AuditSupport of MappingStrategy and Store does not match
[CDO] AuditSupport of MappingStrategy and Store does not match [message #430346] Sat, 16 May 2009 04:23 Go to next message
Hello.
I just updated to the current CDO 2.0 Milestone via the Update Manager.
When I start my application now, I get the error "AuditSupport of
MappingStrategy and Store does not match".
I am setting up the server myself and disabled audits with an Derby
store (please see full server startup code below).
Isn't that supported? It worked with M6 (or at least the property was
ignored).
What do I have to do to fix this? Must I enable audits?
Kai
if (debuggingMode) {
OMPlatform.INSTANCE.setDebugging(true);
OMPlatform.INSTANCE.addLogHandler(PrintLogHandler.CONSOLE);
OMPlatform.INSTANCE.addTraceHandler(PrintTraceHandler.CONSOL E);
EmbeddedDataSource dataSource = new EmbeddedDataSource();
dataSource.setDatabaseName(DATABASE_NAME);
dataSource.setCreateDatabase("create");
IDBConnectionProvider provider =
DBUtil.createConnectionProvider(dataSource);
IDBAdapter adapter = DBUtil.getDBAdapter("derby-embedded");
IMappingStrategy strategy =
CDODBUtil.createHorizontalMappingStrategy();
Map<String, String> mappingStrategyProperties = new HashMap<String,
String>();
mappingStrategyProperties.put(IMappingStrategy.PROP_QUALIFIE D_NAMES,
"true");
strategy.setProperties(mappingStrategyProperties);
IDBStore store = CDODBUtil.createStore(strategy, adapter, provider);
strategy.setStore(store);
Map<String, String> props = new HashMap<String, String>();
props.put(Props.SUPPORTING_AUDITS, "false");
props.put(Props.VERIFYING_REVISIONS, "false");
props.put(Props.CURRENT_LRU_CAPACITY, "10000");
props.put(Props.REVISED_LRU_CAPACITY, "10000");
IRepository repository =
CDOServerUtil.createRepository(REPOSITORY_NAME, store, props);
serverContainer = IPluginContainer.INSTANCE;
LifecycleUtil.activate(serverContainer);
CDOServerUtil.addRepository(serverContainer, repository);
TCPUtil.getAcceptor(serverContainer, "0.0.0.0:7679");
JVMUtil.getAcceptor(serverContainer, "default");
IEvaluationService evaluationService = (IEvaluationService)
PlatformUI.getWorkbench().getService(IEvaluationService.clas s);
evaluationService.requestEvaluation(ServerManagerPropertyTes ter.IS_LOCAL_SERVER_RUNNING);
fireServerEvent(new ServerEvent(this,
ServerEvent.LOCAL_SERVER_STARTED));
Re: [CDO] AuditSupport of MappingStrategy and Store does not match [message #430347 is a reply to message #430346] Sat, 16 May 2009 04:28 Go to previous messageGo to next message
The solution is
CDODBUtil.createHorizontalNonAuditMappingStrategy();
Sorry for bothering ;-)
Kai Schlamp wrote:
> Hello.
> ignored).
> Regards,
> Kai
> "true");
> adapter, provider);
> String>();
> repository);
Re: [CDO] AuditSupport of MappingStrategy and Store does not match [message #430348 is a reply to message #430347] Sat, 16 May 2009 04:43 Go to previous messageGo to next message
Kai,
Good that you found it ;-)
Maybe we should change that API to only one factory method to make this
distinction more obvious for migrators:
public static IMappingStrategy
createHorizontalMappingStrategy(boolean auditing)
Cheers
/Eike
Kai Schlamp schrieb:
> The solution is
> Kai Schlamp wrote:
>> Hello.
>> ignored).
>> Regards,
>> Kai
>> "true");
>> adapter, provider);
>> String>();
>> repository);
>> "0.0.0.0:7679");
Re: [CDO] AuditSupport of MappingStrategy and Store does not match [message #430350 is a reply to message #430346] Sat, 16 May 2009 05:35 Go to previous messageGo to next message
Kai,
I experienced the same while deploying the server (in Equinox).
The last milestone introduced an important refactor in the DBStore.
So it seems now that Horizontal with no audit is a mapping strategy
itself. In cdoserver.xml I had to add "horizontalNoAudit" (or something
similar, cant recall now).
So probably the problem is in:
IMappingStrategy strategy = CDODBUtil.createHorizontalMappingStrategy();
that creates an horizontal mapping, that only works with audit = true.
Could you submit a bug so we can create something lke
CDODBUtil.createHorzintalNoAuditMappingStrategy()?
Anyhow, this new mapping strategies with implicity audit support seems a
bit inconsistent to me...
Thoughts?
Kai Schlamp escribió:
> Hello.
> ignored).
> Regards,
> Kai
> "true");
> adapter, provider);
> String>();
> repository);
Re: [CDO] AuditSupport of MappingStrategy and Store does not match [message #430351 is a reply to message #430350] Sat, 16 May 2009 07:19 Go to previous messageGo to next message
Comments below.
Víctor Roldán Betancort wrote:
> Kai,
It already seems to be there (and works). Just did not find that
possibility in the first place.
> Thoughts?
Eike's suggestion sounds good.
Kai
Re: [CDO] AuditSupport of MappingStrategy and Store does not match [message #430352 is a reply to message #430351] Sat, 16 May 2009 07:43 Go to previous messageGo to next message
Please file an enhancement request ;-)
Cheers
/Eike
Re: [CDO] AuditSupport of MappingStrategy and Store does not match [message #430353 is a reply to message #430352] Sat, 16 May 2009 09:49 Go to previous message
Hey, it was your suggestion ... just kidding ;-)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=276595
Have a nice weekend,
Kai
Previous Topic:Modeling a Choice Group
Next Topic:invariant vs. constraint
Current Time: Sat Jul 19 12:24:35 EDT 2025
Powered by FUDForum. Page generated in 0.03687 seconds
