Home » Modeling » EMF » Searchable Combobox for Features
Searchable Combobox for Features [message #429891] Wed, 06 May 2009 09:28 Go to next message
we're working with the generated .edit and .editor plug-ins which we
enhance step-by-step to get the functionality we need.
Our users are faced with quite large menus when they attempt to specify
reference features in the properties view. Then they need to scroll up
and down in order to find the right target item for the reference.
We would like to provide them with a search feature, maybe as a filter
that reduces the number of presented items as they type in some
substring of the desired item.
The default cell editor for references is implemented through the
ExtendedComboBoxCellEditor class I believe.
If we created our own CellEditor where would we have to hook that in so
that it gets called when the user click on the reference feature?
Does somebody know about a SearchableComboBoxCellEditor (or whatever it
maybe called)?
Thanks and Regards,
Dirk
Re: Searchable Combobox for Features [message #429892 is a reply to message #429891] Wed, 06 May 2009 09:32 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=210176
Tom
Dirk Hoffmann schrieb:
> maybe called)?
> Thanks and Regards,
> Dirk
Re: Searchable Combobox for Features [message #429895 is a reply to message #429891] Wed, 06 May 2009 09:35 Go to previous messageGo to next message
Dirk,
The existing cell editors already support filtering as you type...
Dirk Hoffmann wrote:
> specify reference features in the properties view. Then they need to
> scroll up and down in order to find the right target item for the
> reference.
> so that it gets called when the user click on the reference feature?
> it maybe called)?
> Thanks and Regards,
> Dirk
Re: Searchable Combobox for Features [message #429938 is a reply to message #429895] Thu, 07 May 2009 02:38 Go to previous messageGo to next message
Ah, thanks - didn't realize that.
Unfortunately it's not quite what we want for our customers.
The existing solution seems to match the character I type with the first
characters of the entries and if I repeat that character iterates
through them.
The ideal solution would be what you get when typing Ctrl-T in the
Java-Editor - you know that dialog that allows you to find java classes
and interfaces. Start with a "*" and you can match against substrings
embedded into the entries.
So still the question remains how to tune-up the combo box cell editor.
BTW: Ordered the book but it hasn't arrived yet.
Best Regards,
Dirk
Ed Merks schrieb:
> Dirk,
>> Hi,
>> reference.
>> it maybe called)?
>> Thanks and Regards,
>> Dirk
Re: Searchable Combobox for Features [message #429951 is a reply to message #429938] Thu, 07 May 2009 07:14 Go to previous message
--------------090202080506080502000400
Dirk,
The combo is already showing choices that are filtered so I suppose it's
just a matter of supporting patterns rather than only direct matching...
You can create your own cell editor using this recipe. Perhaps the
FeatureEditorDialog will make you happier. It does use a pattern...
< http://wiki.eclipse.org/EMF/Recipes#Recipe:_Create_your_own_ property_editor_in_a_generated_application>
> first characters of the entries and if I repeat that character
> iterates through them.
> classes and interfaces. Start with a "*" and you can match against
> substrings embedded into the entries.
> Best Regards,
> Dirk
> Ed Merks schrieb:
>> Dirk,
>>> Hi,
>>> reference.
>>> filter that reduces the number of presented items as they type in
>>> some substring of the desired item.
>>> it maybe called)?
>>> Thanks and Regards,
>>> Dirk
<html>
<head>
http-equiv="Content-Type">
</head>
Dirk,<br>
<br>
it's just a matter of supporting patterns rather than only direct
matching...<br>
<br>
Previous Topic:[CDO] New Documentation for Custom Store Developers
Next Topic:Error in Using Teneo Hibernate with GMF
Current Time: Sun Jul 20 18:33:32 EDT 2025
Powered by FUDForum. Page generated in 0.10373 seconds
