Home » Modeling » EMF » Abstract methods
Abstract methods [message #429626] |
Tue, 28 April 2009 02:45  |
Hi all,
I've seen some discussions on this topic but not quite what I'm after.
If I have an abstract class with abstract methods I would like to have those
abstract methods implemented in subclasses. However, it seems ecore does not
support abstract methods. This is not necessarily a problem, all methods
defined in the abstract class can just be generated in the sub-class.
We currently have written some of our own JET templates to alter the code
generation so that methods defined in the model get generated with a line of
code that calls a static method where our custom code is:
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @model
* @generated
public void abstractMethod() {
TestModel.TestModel.AbstractClassBridge.abstractMethod(this) ;
So I think my ideal solution would be just to have this method also
generated in the subclasses, but by default the method isn't. I guess my
question is therefore quite simple, how do I alter my jet/code generation
templates to also generate the above method in the subclass?
Lionel.
Re: Abstract methods [message #429667 is a reply to message #429633] |
Tue, 28 April 2009 19:05   |
Hi Ed,
I've got to digest/understand what you are saying.
In the mean time some clarification, the reason for the modified generators
is to separate generated code from hand written code.
Some responses follow.
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:gt6ngc$tud$1@build.eclipse.org...
> Bob,
> Comments below.
> Bob wrote:
>> Hi all,
>> those abstract methods implemented in subclasses. However, it seems ecore
>> does not support abstract methods. This is not necessarily a problem, all
>> methods defined in the abstract class can just be generated in the
>> sub-class.
> EMF will always generate a stub implementation of the method. Of course
> you can change it to @generated NOT and mark it as abstract instead of
> implementing it.
Yes, in the abstract class it will, but I don't want to be editing generated
code. I'm surprised still that the model wouldn't provide support for
abstract methods, what is the reasoning behind this?
>> of code that calls a static method where our custom code is:
>> * @model
>> * @generated
> Did you know you can specify a method body as an EAnnotation on the
> EOperation? GenOperationImpl accesses it like this:
> protected String getBody()
> EOperation eOperation = getEcoreOperation();
> EAnnotation eAnnotation =
> eOperation.getEAnnotation(GenModelPackage.eNS_URI);
> return eAnnotation == null ? null :
> (String)eAnnotation.getDetails().get("body");
> If all the subclasses have the same method, why have copies everywhere?
They have the same method (signature) but not the same implementation.
Particularly if it was an abstract method in the super class this makes
perfect sense.
> Subclasses that want an override could define the operation again with a
> body EAnnotation and could suppress the redundant declaration from the
> interface using another EAnnotation
> (EcoreUtil.setSuppressedVisibility(EOperation, boolean)).
> This way you'd not need specialized templates...
I'll follow this up, I don't understand it but have the EMF book version 2
so I'm sure this is explained in there.
Lionel.
Re: Abstract methods [message #429668 is a reply to message #429667] |
Tue, 28 April 2009 19:18   |
--------------020804030503030201030200
Bob,
Comments below.
Bob wrote:
> Hi Ed,
I've been accused of being like a fire hose....
Separation of hand written and generated code seems to be one of those
"religious" types of things. Personally, I'm more of a peanut butter
cup kind of guy: if chocolate and peanut butter go good together, why
separate them?
Annotations can help by capturing the hand written code in the model
itself...
>> Bob,
>> Comments below.
>> Bob wrote:
>>> Hi all,
>>> sub-class.
>> implementing it.
> code.
It goes again the religion which says: never the twain shall meet...
Because Ecore is a high level abstraction for defining the API. It's
not just simplified Java...
>>> * @model
>>> * @generated
Ecore is more about defining the API and much less about defining the
implementation, which is typically better done in a programming language
like Java.
> perfect sense.
From a Java perspective. An implementation that throws an exception
"this isn't implemented" isn't logically all that much different, other
than the Java compile time constraints associated with it...
Dave is very meticulous. He rarely misses a detail...
> Thanks
> Lionel.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Bob,<br>
<br>
Comments below.<br>
<br>
Bob wrote:
<blockquote cite="mid:gt823d$3gv$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
</pre>
</blockquote>
I've been accused of being like a fire hose....<br>
<pre wrap="">
</pre>
</blockquote>
separate them? <br>
<br>
itself...<br>
<pre wrap="">
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com"><Ed.Merks@gmail.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:gt6ngc$tud$1@build.eclipse.org">news:gt6ngc$tud$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Bob,
Comments below.
Bob wrote:
</pre>
<pre wrap="">Hi all,
sub-class.
</pre>
</blockquote>
<pre wrap="">EMF will always generate a stub implementation of the method. Of course
implementing it.
</pre>
</blockquote>
<pre wrap=""><!---->
code. </pre>
</blockquote>
It goes again the religion which says: never the twain shall meet...<br>
<pre wrap="">I'm surprised still that the model wouldn't provide support for
</pre>
</blockquote>
not just simplified Java...<br>
<pre wrap="">
</pre>
<pre wrap="">We currently have written some of our own JET templates to alter the code
* @model
* @generated
</pre>
</blockquote>
<pre wrap="">Did you know you can specify a method body as an EAnnotation on the
</pre>
<pre wrap="">
</pre>
</blockquote>
<pre wrap="">If all the subclasses have the same method, why have copies everywhere?
</pre>
</blockquote>
</pre>
</blockquote>
language like Java.<br>
<pre wrap="">Particularly if it was an abstract method in the super class this makes
perfect sense.
</pre>
</blockquote>
than the Java compile time constraints associated with it...<br>
<pre wrap="">
</pre>
<pre wrap="">Subclasses that want an override could define the operation again with a
</pre>
</blockquote>
</pre>
</blockquote>
Dave is very meticulous. He rarely misses a detail...<br>
<pre wrap="">
Lionel.
</pre>
</blockquote>
</body>
</html>
--------------020804030503030201030200--
Re: Abstract methods [message #429669 is a reply to message #429668] |
Tue, 28 April 2009 20:14   |
------=_NextPart_000_0049_01C9C8B3.404F9BB0
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Ed,
Unfortunately OE is being an absolute pain and so I can't easily respond =
inline. I also can't remember username ans password so I can't setup =
Thunderbird :(. So bear with me while I try to respond.
I'm not going to get into the hand written code separation argument. =
Let's just say that it's a requirement of my project, and leave it =
there.
>> Particularly if it was an abstract method in the super class this =
makes=20
>> perfect sense.
> From a Java perspective. An implementation that throws an exception =
> that much different, other than the Java compile time constraints =
But the implementation is/should be much different from that in my case.
Anyway, I shall follow up with these annotations and see if I can work =
them to do what I need.
Lionel.
"Ed Merks" <Ed.Merks@gmail.com> wrote in message =
news:49F78EA8.20201@gmail.com...
Bob,
Comments below.
Bob wrote:=20
Hi Ed,
In the mean time some clarification, the reason for the modified =
generators=20
Separation of hand written and generated code seems to be one of those =
"religious" types of things. Personally, I'm more of a peanut butter =
cup kind of guy: if chocolate and peanut butter go good together, why =
separate them? =20
Annotations can help by capturing the hand written code in the model =
itself...
"Ed Merks" <Ed.Merks@gmail.com> wrote in message=20
Bob,
Comments below.
Bob wrote:
Hi all,
If I have an abstract class with abstract methods I would like to have=20
those abstract methods implemented in subclasses. However, it seems =
ecore=20
does not support abstract methods. This is not necessarily a problem, =
all=20
methods defined in the abstract class can just be generated in the=20
sub-class.
EMF will always generate a stub implementation of the method. Of =
course=20
you can change it to @generated NOT and mark it as abstract instead of=20
implementing it.
=20
Yes, in the abstract class it will, but I don't want to be editing =
generated=20
code. It goes again the religion which says: never the twain shall =
meet...
I'm surprised still that the model wouldn't provide support for=20
Because Ecore is a high level abstraction for defining the API. It's =
We currently have written some of our own JET templates to alter the =
code=20
generation so that methods defined in the model get generated with a =
line=20
* @model
* @generated
Did you know you can specify a method body as an EAnnotation on =
the=20
EOperation eOperation =3D getEcoreOperation();
EAnnotation eAnnotation =3D=20
return eAnnotation =3D=3D null ? null :=20
So I think my ideal solution would be just to have this method also=20
If all the subclasses have the same method, why have copies =
everywhere?
=20
They have the same method (signature) but not the same implementation.=20
Ecore is more about defining the API and much less about defining the =
implementation, which is typically better done in a programming language =
like Java.
Particularly if it was an abstract method in the super class this makes=20
perfect sense.
"this isn't implemented" isn't logically all that much different, other =
Subclasses that want an override could define the operation again with =
a=20
body EAnnotation and could suppress the redundant declaration from the=20
interface using another EAnnotation=20
=20
I'll follow this up, I don't understand it but have the EMF book version =
2=20
Lionel.=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.6000.16825" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Unfortunately OE is being an absolute =
pain and so I=20
can't easily respond inline. I also can't remember username ans password =
so I=20
can't setup Thunderbird :(. So bear with me while I try to =
respond.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I'm not going to get into the hand =
written code=20
separation argument. Let's just say that it's a requirement of my =
project, and=20
leave it there.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV><FONT face=3DArial =
size=3D2>
<BLOCKQUOTE cite=3Dmid:gt823d$3gv$1@build.eclipse.org type=3D"cite"><PRE =
wrap=3D"">>> Particularly if it was an abstract method in the =
>> perfect sense.
</PRE></BLOCKQUOTE>
<DIV>> From a Java perspective. An implementation that throws an =
exception=20
"this isn't implemented" isn't logically all</DIV>
<DIV>> that much different, other than the Java compile time =
constraints=20
associated with it...</DIV>
<DIV> </DIV>
<DIV>But the implementation is/should be much different from that =
in my=20
case.</DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV>Anyway, I shall follow up with these annotations and see if I can =
work them=20
to do what I need.</DIV>
<DIV> </DIV>
<DIV>Thanks</DIV>
<DIV> </DIV>
<DIV>Lionel.</DIV>
<DIV></FONT> </DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A=20
href=3D"mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</A>> wrote in =
message=20
<A=20
href=3D"news:49F78EA8.20201@gmail.com">news:49F78EA8.20201@gmail.com</A>.=
...</DIV>Bob,<BR><BR>Comments=20
below.<BR><BR>Bob wrote:=20
<BLOCKQUOTE cite=3Dmid:gt823d$3gv$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Hi Ed,
</PRE></BLOCKQUOTE>I've been accused of being like a fire hose....<BR>
type=3D"cite"><PRE wrap=3D"">In the mean time some clarification, the =
reason for the modified generators=20
</PRE></BLOCKQUOTE>Separation of hand written and generated code seems =
to be=20
one of those "religious" types of things. Personally, I'm more =
of a=20
peanut butter cup kind of guy: if chocolate and peanut butter go good=20
together, why separate them? <BR><BR>Annotations can help by =
capturing=20
the hand written code in the model itself...<BR>
type=3D"cite"><PRE wrap=3D"">Some responses follow.
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:Ed.Merks@gmail.com"><Ed.Merks@gmail.com></A> wrote =
in message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:gt6ngc$tud$1@build.eclipse.org">news:gt6ngc$tud$1@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Bob,
Comments below.
Bob wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi all,
ecore=20
all=20
sub-class.
</PRE></BLOCKQUOTE><PRE wrap=3D"">EMF will always generate a stub =
implementation of the method. Of course=20
implementing it.
</PRE></BLOCKQUOTE><PRE wrap=3D""><!---->
generated=20
code. </PRE></BLOCKQUOTE>It goes again the religion which says: never =
the=20
twain shall meet...<BR>
type=3D"cite"><PRE wrap=3D"">I'm surprised still that the model wouldn't =
</PRE></BLOCKQUOTE>Because Ecore is a high level abstraction for =
defining=20
the API. It's not just simplified Java...<BR>
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">We currently have written =
some of our own JET templates to alter the code=20
line=20
* @model
* @generated
</PRE></BLOCKQUOTE><PRE wrap=3D"">Did you know you can specify a =
method body as an EAnnotation on the=20
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">So I think my ideal =
</PRE></BLOCKQUOTE><PRE wrap=3D"">If all the subclasses have the =
</PRE></BLOCKQUOTE>Ecore is more about defining the API and much less =
about=20
defining the implementation, which is typically better done in a =
programming=20
language like Java.<BR>
type=3D"cite"><PRE wrap=3D"">Particularly if it was an abstract method =
perfect sense.
</PRE></BLOCKQUOTE>From a Java perspective. An implementation that =
throws an=20
exception "this isn't implemented" isn't logically all that much =
different,=20
other than the Java compile time constraints associated with it...<BR>
type=3D"cite"><PRE wrap=3D""> </PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Subclasses that want an =
override could define the operation again with a=20
2=20
</PRE></BLOCKQUOTE>Dave is very meticulous. He rarely misses a=20
detail...<BR>
type=3D"cite"><PRE wrap=3D"">Thanks
Lionel.=20
</PRE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0049_01C9C8B3.404F9BB0--
Re: Abstract methods [message #429704 is a reply to message #429693] |
Wed, 29 April 2009 23:14   |
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:gta32r$k0$1@build.eclipse.org...
> Bob wrote:
>> Ed,
> You can use your Eclipse Bugzilla account to access the newsgroups. If
> you've forgotten your Bugzilla password, you can request a reset here:
> https://bugs.eclipse.org/bugs/index.cgi?GoAheadAndLogIn=1
I only made a bugzilla account yesterday and even though I can login on the
web interface to the Eclipse Bugzilla I get an authentication error in
Thunderbird :(. My OE account is using the exquisitus username + password
but the information doesn't appear to be available anymore.
>> Let's just say that it's a requirement of my project, and leave it there.
> That's for the best; I've tried before to convince Ed that not all
> projects and developers want to (or are able to) edit the EMF-generated
> code; his EMF glasses are just too dark to allow him to see that dim truth
I'm happy for there to be differing opinions on this matter, but there seems
to be enough demand to warrant having some support for separating manually
written code.
> I just wanted to point out that, unless something has changed in the most
> recent versions, the EAnnotation that allows you to specify a method
> implementation in the model only works for EOperations. In most cases that
> is enough but my most recent project did find a couple of places where we
> wished we could have done it for generated property/reference getters or
> setters. Of course there is always the @generated NOT option but that gets
> back to the "religious" issue that neither you nor Ed want to talk about
I see your point. After having read the book I now understand what the
intention is, though I haven't got it to work with the UML diagram editor
I'm using in TopCased and I don't think it is a solution anyway. There is an
additional problem too, in the UML editor if I define an operation in an
abstract class, then define the same operation in a subclass, when I try to
reload the genmodel it complains of a duplicate method! Otherwise that would
have been a suitable hack to solve my issue :(.
Thanks for you help
Lionel.
Re: Abstract methods [message #429712 is a reply to message #429704] |
Thu, 30 April 2009 06:43   |
--------------090106040409020701050005
Bob,
Comments below.
>> Bob wrote:
>>> Ed,
> written code.
What you see is what you get. The fact that what you're seeing you're
also getting for free means that demand is effectively irrelevant. Of
course I don't generally treat the community as irrelevant, but anyone
under the illusion that they can "demand" things and expect they're
simply going happen as a result is living in a dream world. Of course
I'm stating the obvious. :-P
A more interesting problem to me, because it adds power rather than
panders to what I consider a fetish (we're all entitled to opinions and
I'm doing the work) is supporting precisely the types of things that
require modifying generated code in dynamic models.
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=148992>
https://bugs.eclipse.org/bugs/show_bug.cgi?id=255469
https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786
In terms of pandering to fetishes... Imagine applying the JMerge sweep
rules to a generated Java file when merging in an empty
class/interface. All that would be left would be the hand written code,
without generated code. Any file that's only an empty class/interface
could be discarded. What's left is your separate hand written code.
Run the generator against that and the result is what you get today.
The point is that it wouldn't be that hard to build some tools to manage
this, but it won't be me that's building it because I have more
important things to do.
A base class and a derived class can have duplicate operations. Only a
given class can't have two exactly the same operations. I.e., exactly
the same rules as for Java should apply. There's probably something
else going on here (faulty mapping onto Ecore) that you might be
misinterpreting as a limitation on Ecore. You might consider using the
Ecore Tools graphical editor directly. It's very nice. I like it a lot.
> Thanks for you help
> Lionel.
<html>
<head>
</head>
Bob,<br>
<br>
Comments below.<br>
<br>
Bob wrote:
<blockquote cite="mid:gtb52s$q5v$1@build.eclipse.org" type="cite">
<pre wrap="">"Eric Rizzo" <a class="moz-txt-link-rfc2396E" href="mailto:eclipse-news@rizzoweb.com"><eclipse-news@rizzoweb.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:gta32r$k0$1@build.eclipse.org">news:gta32r$k0$1@build.eclipse.org</a>...
</pre>
<pre wrap="">Bob wrote:
</pre>
<pre wrap="">Ed,
</pre>
</blockquote>
<pre wrap="">You can use your Eclipse Bugzilla account to access the newsgroups. If
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/index.cgi?GoAheadAndLogIn=1">https://bugs.eclipse.org/bugs/index.cgi?GoAheadAndLogIn=1</a>
</pre>
</blockquote>
</pre>
<pre wrap="">I'm not going to get into the hand written code separation argument.
</pre>
</blockquote>
<pre wrap="">That's for the best; I've tried before to convince Ed that not all
</pre>
</blockquote>
written code.
</pre>
</blockquote>
I'm stating the obvious. :-P<br>
<br>
require modifying generated code in dynamic models.<a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=148992"><br>
</a>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=148992">https://bugs.eclipse.org/bugs/show_bug.cgi?id=148992</a><br>
<a href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=255469">https://bugs.eclipse.org/bugs/show_bug.cgi?id=255469</a><br>
<a href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786">https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786</a><br>
</blockquote>
code, without generated code. Any file that's only an empty
class/interface could be discarded. What's left is your separate hand
written code. Run the generator against that and the result is what
you get today. The point is that it wouldn't be that hard to build
some tools to manage this, but it won't be me that's building it
because I have more important things to do.<br>
<pre wrap="">
</pre>
<pre wrap="">Anyway, I shall follow up with these annotations and see if I can work
</pre>
</blockquote>
<pre wrap="">I just wanted to point out that, unless something has changed in the most
</pre>
</blockquote>
</pre>
</blockquote>
lot.<br>
<pre wrap="">
Thanks for you help
Lionel.
</pre>
</blockquote>
</body>
</html>
--------------090106040409020701050005--
Re: Abstract methods [message #429778 is a reply to message #429712] |
Thu, 30 April 2009 21:47   |
------=_NextPart_000_000A_01C9CA52.89E1DEA0
Argh, OE sux.
Anyway, with reference to the below, I didn't mean demand in the sense =
of forcefully asking for it, but rather there are a lot of people who =
desire it. I understand, it's free and maybe EMF wasn't the appropriate =
choice for my project given our requirements.
There are still a lot of unanswered questions about how generated models =
should be, and can be used we are just trying to make it work for us at =
the moment and sadly there are some elements that make this difficult =
(sorry, I'm not highlighting the benefits at the moment, and there are =
some good ones).
Thanks for your help, I'll continue to search for a way to solve this =
problem.
Lionel.
news:gtbvce$lvp$1@build.eclipse.org...
I'm happy for there to be differing opinions on this matter, but there =
seems=20
to be enough demand to warrant having some support for separating =
manually=20
written code.
What you see is what you get. The fact that what you're seeing you're =
also getting for free means that demand is effectively irrelevant. Of =
course I don't generally treat the community as irrelevant, but anyone =
under the illusion that they can "demand" things and expect they're =
simply going happen as a result is living in a dream world. Of course =
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Argh, OE sux.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Anyway, with reference to the below, I =
didn't mean=20
demand in the sense of forcefully asking for it, but rather there are a =
lot of=20
people who desire it. I understand, it's free and maybe EMF wasn't the=20
appropriate choice for my project given our requirements.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>There are still a lot of unanswered =
questions about=20
how generated models should be, and can be used we are just trying to =
make it=20
work for us at the moment and sadly there are some elements that make =
this=20
difficult (sorry, I'm not highlighting the benefits at the moment, and =
there are=20
some good ones).</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks for your help, I'll continue to =
search for a=20
way to solve this problem.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Lionel.</FONT></DIV>
<DIV> </DIV>
message=20
<A=20
href=3D"news:gtbvce$lvp$1@build.eclipse.org">news:gtbvce$lvp$1@build.ecli=
pse.org</A>...</DIV>
<BLOCKQUOTE cite=3Dmid:gtb52s$q5v$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D""><!---->
seems=20
manually=20
written code.
</PRE></BLOCKQUOTE>
<DIV>What you see is what you get. The fact that what you're =
seeing=20
you're also getting for free means that demand is effectively=20
irrelevant. Of course I don't generally treat the community as=20
irrelevant, but anyone under the illusion that they can "demand" =
things and=20
expect they're simply going happen as a result is living in a dream =
world. Of=20
course I'm stating the obvious. :-P</DIV></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_000A_01C9CA52.89E1DEA0--
Re: Abstract methods [message #429788 is a reply to message #429778] |
Fri, 01 May 2009 05:18  |
--------------010402080403060007030805
Bob,
Comments below.
Bob wrote:
> Argh, OE sux.
> desire it.
A lot would be an overstatement based on my experience. Yes there are
some, but they are by far the minority. In any case, the whole point is
that talk is cheap actions are not. Keeping them separate is not
without its drawbacks. I.e., you often end up with double the number of
classes and a stilted artificial looking hierarchy which are exactly the
kinds of things that given generators a bad name.
< http://ed-merks.blogspot.com/2008/10/hand-written-and-genera ted-code-never.html>
> I understand, it's free and maybe EMF wasn't the appropriate choice
Maybe. Or maybe some day someone will care enough to put actions behind
their words.
> models should be, and can be used we are just trying to make it work
> for us at the moment and sadly there are some elements that make this
> there are some good ones).
I suspect it's more of a marketing/perception/attitude problem; not
yours but I know well what it's like to deal with people who are adamant
that things simply must be a certain way even though their reasons are
flimsy at best.
> problem.
Note that there's even a bugzilla for this specific issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=181532
Some form of annotation to indicate the generated method in the Impl
should be abstract would do the trick.
Unfortunately, with 100 feature requests and two thinly stretched active
committers, not nearly as many things as I might like get done.
Now if someone actually coughed up $ to get some of the cool things they
want to see, more would get done. Of course with contributions, more
would get done and right now I have a few excellent contributions I need
to review so I can commit them. My priorities are to fix actual defects
immediately, do the cool things I think are important to get done (those
things that I believe will benefit the most people the most), process
contributions (to encourage more of them), and finally, in the
nonexistent spare time, pick over the growing 100 item long wish list
from the community.
A non-ideal solution to your problem is to produce a method with a body
that throws a not implemented exception. It doesn't give you the
immediate compile time feedback, but with proper testing, it should do
the trick almost as well...
Good luck. Sorry for the rant. It's not meant to be taken personally.
Hopefully it's good context to consider though...
> Lionel.
> "Ed Merks" <Ed.Merks@gmail.com <mailto:Ed.Merks@gmail.com>> wrote
> in message news:gtbvce$lvp$1@build.eclipse.org...
>> written code.
> things and expect they're simply going happen as a result is
> living in a dream world. Of course I'm stating the obvious. :-P
<html>
<head>
</head>
Bob,<br>
<br>
Comments below.<br>
<br>
Bob wrote:
<blockquote cite="mid:gtdkam$ro8$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.6000.16825" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Argh, OE sux.</font></div>
<div> </div>
<div><font face="Arial" size="2">Anyway, with reference to the below,
I didn't mean demand in the sense of forcefully asking for it, but
rather there are a lot of people who desire it.</font></div>
</blockquote>
is that talk is cheap actions are not. Keeping them separate is not
of classes and a stilted artificial looking hierarchy which are exactly
the kinds of things that given generators a bad name.<a
href=" http://ed-merks.blogspot.com/2008/10/hand-written-and-genera ted-code-never.html"><br>
</a>
<blockquote><a
href=" http://ed-merks.blogspot.com/2008/10/hand-written-and-genera ted-code-never.html"> http://ed-merks.blogspot.com/2008/10/hand-written-and-genera ted-code-never.html</a><br>
</blockquote>
<br>
<div><font face="Arial" size="2"> I understand, it's free and maybe
EMF wasn't the appropriate choice for my project given our requirements.</font></div>
</blockquote>
behind their words.<br>
<div> </div>
<div><font face="Arial" size="2">There are still a lot of unanswered
questions about how generated models should be, and can be used we are
just trying to make it work for us at the moment and sadly there are
some elements that make this difficult (sorry, I'm not highlighting the
benefits at the moment, and there are some good ones).</font></div>
</blockquote>
adamant that things simply must be a certain way even though their
reasons are flimsy at best.<br>
<div> </div>
<div><font face="Arial" size="2">Thanks for your help, I'll continue
to search for a way to solve this problem.</font></div>
</blockquote>
Note that there's even a bugzilla for this specific issue:<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=181532">https://bugs.eclipse.org/bugs/show_bug.cgi?id=181532</a><br>
</blockquote>
should be abstract would do the trick.<br>
<br>
active committers, not nearly as many things as I might like get done.<br>
<br>
they want to see, more would get done. Of course with contributions,
more would get done and right now I have a few excellent contributions
I need to review so I can commit them. My priorities are to fix actual
defects immediately, do the cool things I think are important to get
done (those things that I believe will benefit the most people the
most), process contributions (to encourage more of them), and finally,
in the nonexistent spare time, pick over the growing 100 item long wish
list from the community.<br>
<br>
the trick almost as well...<br>
<br>
personally. Hopefully it's good context to consider though...<br>
<div> </div>
<div><font face="Arial" size="2">Lionel.</font></div>
<div> </div>
<blockquote dir="ltr"
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" <<a moz-do-not-send="true"
href="mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</a>> wrote in
message <a moz-do-not-send="true"
href="news:gtbvce$lvp$1@build.eclipse.org">news:gtbvce$lvp$1@build.eclipse.org</a>...</div>
written code.
</pre>
</blockquote>
<div>What you see is what you get. The fact that what you're
seeing you're also getting for free means that demand is effectively
irrelevant, but anyone under the illusion that they can "demand" things
and expect they're simply going happen as a result is living in a dream
world. Of course I'm stating the obvious. :-P</div>
</blockquote>
</blockquote>
</body>
</html>
--------------010402080403060007030805--
Current Time: Sat Jul 19 08:00:31 EDT 2025
Powered by FUDForum. Page generated in 1.12184 seconds
