Home » Modeling » EMF » [CDO] closing down a database
[CDO] closing down a database [message #429421] |
Wed, 22 April 2009 16:55  |
I have a simple application in which I am storing large models into individual
databases. I am using HSQLDB for this purpose. The target application is an
Eclipse plugin, and because each model has its own (smallish) database (rather
than storing everything in one large database), I'm starting up the databases
using the JVM acceptor.
My problem is basically the following: there are times when I would like to
delete the databases that have been created. So, I basically want to close down
all connections, and delete the database files. But, I'm not able to do this. No
matter what I do, the log file for the database stays locked, and I can't delete
it. I'm using CDO version 1.0.8, and here are some code snippets for how the
databases are set up:
Any help would be greatly appreciated.
private void init() throws CoreException {
IManagedContainer container = IPluginContainer.INSTANCE;
if (acceptor == null) {
acceptor = JVMUtil.getAcceptor(container, "default");
if (repository == null) {
repository = createRepository();
CDOServerUtil.addRepository(container, repository);
if (connector == null) {
connector = JVMUtil.getConnector(container, "default");
if (session == null) {
CDOSessionConfiguration config = CDOUtil.createSessionConfiguration();
config.setConnector(connector);
config.setRepositoryName(databasePath.toPortableString());
config.setLegacySupportEnabled(false);
config.setDemandPopulatingPackageRegistry();
session = config.openSession();
private IRepository createRepository() throws CoreException {
Map<String, String> props = new HashMap<String, String>();
props.put(Props.PROP_SUPPORTING_REVISION_DELTAS, "false");
props.put(Props.PROP_CURRENT_LRU_CAPACITY, "10000");
props.put(Props.PROP_REVISED_LRU_CAPACITY, "10000");
IRepository repository =
CDOServerUtil.createRepository(databasePath.toPortableString (),
createStore(databasePath), props);
return repository;
private IStore createStore(IPath databaseAlias) throws CoreException {
HSQLDBDataSource dataSource = new HSQLDBDataSource();
dataSource.setUser("sa");
dataSource.setPassword("");
dataSource.setDatabase(getDBName());
IMappingStrategy mappingStrategy = CDODBUtil.createHorizontalMappingStrategy();
IDBStore store = CDODBUtil.createStore(
mappingStrategy,
DBUtil.getDBAdapter("hsqldb"),
DBUtil.createConnectionProvider(dataSource));
mappingStrategy.setStore(store);
this.dataSource = dataSource;
return store;
public void close() {
if (view != null) {
view.close();
if (session != null) {
CDOView[] views = session.getViews();
for (CDOView view : views) {
view.close();
session.close();
if (connector != null) {
connector.disconnect();
if (dataSource != null) {
try {
if (!dataSource.getConnection().isClosed()) {
dataSource.getConnection().close();
} catch (SQLException e) {
DBPlugin.getDefault().log(e);
Re: [CDO] closing down a database [message #429525 is a reply to message #429421] |
Fri, 24 April 2009 05:55   |
Del,
Like Stefan, I would have recommended to deactivate the repository with:
LifecycleUtil.deactivate(repository);
If anything inside stays active after this, I guess we'd need a running
code example to reproduce it...
Cheers
/Eike
Del Myers schrieb:
> individual databases. I am using HSQLDB for this purpose. The target
> application is an Eclipse plugin, and because each model has its own
> (smallish) database (rather than storing everything in one large
> database), I'm starting up the databases using the JVM acceptor.
> like to delete the databases that have been created. So, I basically
> want to close down all connections, and delete the database files.
> But, I'm not able to do this. No matter what I do, the log file for
> the database stays locked, and I can't delete it. I'm using CDO
> version 1.0.8, and here are some code snippets for how the databases
> are set up:
> return repository;
> mappingStrategy,
> return store;
> if (view != null) {
> view.close();
> view.close();
> session.close();
> try {
Re: [CDO] closing down a database [message #429526 is a reply to message #429421] |
Fri, 24 April 2009 06:02   |
Forgot to mention that cdoSession.close() automatically closes all views
and their possible queries ;-)
Cheers
/Eike
Del Myers schrieb:
> are set up:
> return repository;
> mappingStrategy,
> return store;
> if (view != null) {
> view.close();
> view.close();
> session.close();
> try {
Re: [CDO] closing down a database [message #429538 is a reply to message #429526] |
Fri, 24 April 2009 07:09   |
IIRC hsql needs a special sql-command send at the end to release all
locks immediately on the files. Closing the db-connection is not enough!
I'm going to look up some old old project code.
Tom
> Cheers
> /Eike
> http://thegordian.blogspot.com
> Del Myers schrieb:
>> Hi,
>> are set up:
>> return repository;
>> mappingStrategy,
>> return store;
>> if (view != null) {
>> view.close();
>> view.close();
>> session.close();
>> try {
Re: [CDO] closing down a database [message #429542 is a reply to message #429538] |
Fri, 24 April 2009 07:26   |
Tom,
Thanks for the hint!
In this case I suggest to file a Bugzilla against CDO so that we can fix
this (Del!).
Cheers
/Eike
> Tom
>> Cheers
>> /Eike
>> Del Myers schrieb:
>>> Hi,
>>> are set up:
>>> return repository;
>>> mappingStrategy,
>>> return store;
>>> if (view != null) {
>>> view.close();
>>> view.close();
>>> session.close();
>>> try {
Re: [CDO] closing down a database [message #429545 is a reply to message #429538] |
Fri, 24 April 2009 07:36   |
[Disclaimer] Maybe this is not true any more because I haven't used HSQL
since about 2 years.
When disconnecting from HSQL you need to execute.
---------8<---------
connection.executeQuery("SHUTDOWN");
=> Looks this can be controled in 1.8 with a connection property [1]
Another special thing is that HSQL while running collects all executed
statements in a log-File and to write it back to the final condensed
format you need to execute
connection.executeQuery("CHECKPOINT");
at a given point or setting the size of the hsqldb.log_size-property a
SHUTDOWN will automatically execute a CHECKPOINT.
Tom
[1]http://hsqldb.org/doc/guide/ch01.html#N101DB
> Tom
>> Cheers
>> /Eike
>> Del Myers schrieb:
>>> Hi,
>>> are set up:
>>> return repository;
>>> mappingStrategy,
>>> return store;
>>> if (view != null) {
>>> view.close();
>>> view.close();
>>> session.close();
>>> try {
Re: [CDO] closing down a database [message #429548 is a reply to message #429545] |
Fri, 24 April 2009 07:48   |
Darn, I can remember that I added this line to our test framework:
org.eclipse.emf.cdo.tests.config.impl.RepositoryConfig.DB.Hs qldb.shutDownHsqldb()
But doesn't this shutdown *all* connections, or worse: the server itself?
This could be something that wedon't want to trigger from inside CDO,
i.e. the repository or store...
You mean, in addition to the commit?
Should we have a problem here and no test uncovered it so far.
I never herad complaints about lost data after restarts...
Cheers
/Eike
> Tom
>> Tom
>>> Cheers
>>> /Eike
>>> Del Myers schrieb:
>>>> Hi,
>>>> are set up:
>>>> return repository;
>>>> mappingStrategy,
>>>> return store;
>>>> if (view != null) {
>>>> view.close();
>>>> view.close();
>>>> session.close();
>>>> try {
Re: [CDO] closing down a database [message #429551 is a reply to message #429548] |
Fri, 24 April 2009 08:10   |
>> Hi,
I think this property is the correct one not?
Well this checkpoint is something different than what you might think it
is. It's not like a checkpoint you know from JDBC and has nothing to do
with transactions, ... .
Let's start with an empty database:
..script like this:
CREATE TABLE a ( .... )
..log like this:
<Empty>
When you execute a SEQUENCE of SQL-Statement in a transaction on an
HSQL-Database they are at first stored inside a log-File.
Say you execute the following statements:
INSERT IGNORE INTO a (a,b) VALUES (1,1);
UPDATE a SET b = 2 WHERE a = 1;
..script like this:
..log like this:
START TRANSACTION;
COMMIT;
now when you stop the database with out a shutdown the next time the
HSQL-DB first reads the .script and then in sequence execute the
SQL-Statements found in .log.
If you called CHECKPOINT after the above the situation is different and
when shutting down it looks like this:
..script like this:
INSERT IGNORE INTO a (a,b) VALUES (1,2);
..log like this:
<Empty>
So it's not necessarily needed to execute CHECKPOINT but normally ones
better when its acceptable to execute such a condense command instead of
relying on the log_size. IIRC we also had corruption problems with the
..log-File and so we called CHECKPOINT at some given points in the
application.
Tom
Re: [CDO] closing down a database [message #429561 is a reply to message #429545] |
Fri, 24 April 2009 14:14   |
Thanks, executing SHUTDOWN does work after I close the session.
It works for my purposes because each of my models is stored in a separate
database, and I want to delete all of the database files. I'm not sure that I
want to file a bug about this because I imagine that, in most cases, client's
aren't going to want to shut down the database after closing their sessions.
Most of the time, I would expect, users would just want to clear their resource
and commit the transaction.
Del
> Tom
>> Tom
>>> Cheers
>>> /Eike
>>> Del Myers schrieb:
>>>> Hi,
>>>> are set up:
>>>> return repository;
>>>> mappingStrategy,
>>>> return store;
>>>> if (view != null) {
>>>> view.close();
>>>> view.close();
>>>> session.close();
>>>> try {
Re: [CDO] closing down a database [message #429567 is a reply to message #429561] |
Fri, 24 April 2009 15:49   |
Del,
Good that it works!
Would you like to add a short explanation to
http://wiki.eclipse.org/FAQ_for_CDO_and_Net4j ?
Cheers
/Eike
> separate database, and I want to delete all of the database files. I'm
> not sure that I want to file a bug about this because I imagine that,
> in most cases, client's aren't going to want to shut down the database
> after closing their sessions. Most of the time, I would expect, users
> would just want to clear their resource and commit the transaction.
> Del
>> Hi,
>> Tom
>>> enough!
>>> Tom
>>>> views
>>>> Cheers
>>>> /Eike
>>>> Del Myers schrieb:
>>>>> Hi,
>>>>> are set up:
>>>>> return repository;
>>>>> CoreException {
>>>>> mappingStrategy,
>>>>> return store; }
>>>>> if (view != null) {
>>>>> view.close();
>>>>> view.close();
>>>>> session.close();
>>>>> try {
Re: [CDO] closing down a database [message #429648 is a reply to message #429567] |
Tue, 28 April 2009 14:21   |
Done!
Eike Stepper wrote:
> Del,
> Good that it works!
> Cheers
> /Eike
>> Del
>>> Hi,
>>> Tom
>>>> enough!
>>>> Tom
>>>>> views
>>>>> Cheers
>>>>> /Eike
>>>>> Del Myers schrieb:
>>>>>> Hi,
>>>>>> are set up:
>>>>>> return repository;
>>>>>> CoreException {
>>>>>> mappingStrategy,
>>>>>> return store; }
>>>>>> if (view != null) {
>>>>>> view.close();
>>>>>> view.close();
>>>>>> session.close();
>>>>>> try {
Re: [CDO] closing down a database [message #429652 is a reply to message #429648] |
Tue, 28 April 2009 15:04   |
Del Myers schrieb:
> Done!
Excellent!
Thanks a lot ;-)
One question though:
Do you think the connection that is *opened* on
store.getDBConnectionProvider().getConnection() should be closed to free
local resources?
Cheers
/Eike
> Eike Stepper wrote:
>> Del,
>> Good that it works!
>> Cheers
>> /Eike
>>> Del
>>>> HSQL
>>>> Hi,
>>>> Tom
>>>>> enough!
>>>>> Tom
>>>>>> views
>>>>>> Cheers
>>>>>> /Eike
>>>>>> Del Myers schrieb:
>>>>>>> Hi,
>>>>>>> target
>>>>>>> own
>>>>>>> basically
>>>>>>> databases
>>>>>>> are set up:
>>>>>>> return repository;
>>>>>>> CoreException {
>>>>>>> mappingStrategy,
>>>>>>> return store; }
>>>>>>> if (view != null) {
>>>>>>> view.close();
>>>>>>> view.close();
>>>>>>> session.close();
>>>>>>> try {
Re: [CDO] closing down a database [message #429658 is a reply to message #429652] |
Tue, 28 April 2009 16:49  |
Hmm... You are probably right that it should be closed, though I haven't needed
to. I'm guessing the HSQLDB frees everything up because it is shut down. The
connection is probably invalid from then on? I don't know though.
Del
Eike Stepper wrote:
> Del Myers schrieb:
>> Done!
> Excellent!
> Thanks a lot ;-)
> local resources?
> Cheers
> /Eike
>> Eike Stepper wrote:
>>> Del,
>>> Good that it works!
>>> Cheers
>>> /Eike
>>>> Del
>>>>> HSQL
>>>>> Hi,
>>>>> Tom
>>>>>> enough!
>>>>>> Tom
>>>>>>> views
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>> Del Myers schrieb:
>>>>>>>> Hi,
>>>>>>>> target
>>>>>>>> own
>>>>>>>> basically
>>>>>>>> databases
>>>>>>>> are set up:
>>>>>>>> return repository;
>>>>>>>> CoreException {
>>>>>>>> mappingStrategy,
>>>>>>>> return store; }
>>>>>>>> if (view != null) {
>>>>>>>> view.close();
>>>>>>>> view.close();
>>>>>>>> session.close();
>>>>>>>> try {
Current Time: Sun Jul 20 02:44:29 EDT 2025
Powered by FUDForum. Page generated in 0.14794 seconds
