Home » Modeling » EMF » use another attribute for cross-references instead of "href"
use another attribute for cross-references instead of "href" [message #429392] Wed, 22 April 2009 02:41 Go to next message
is it possible to override the loading of external references instead of
using the href attribute.
<WizardPage library="" path="">
We have already attributes which defines where the external page is
located.
The path attribute is also not a correct URI.
Thanks and best regards,
Robert
Re: use another attribute for cross-references instead of "href" [message #429395 is a reply to message #429392] Wed, 22 April 2009 07:08 Go to previous messageGo to next message
Robert,
Comments below.
Robert Driesner wrote:
> of using the href attribute.
Where there's a will there's a way, but not necessarily an easy way.
Pretty much anything is possible if you specialize the XMLHandler and
XMLSaveImpl.
> located.
Is there a schema for your syntax?
> Robert
Re: use another attribute for cross-references instead of "href" [message #429398 is a reply to message #429395] Wed, 22 April 2009 07:45 Go to previous messageGo to next message
Hi Ed,
I?m using XML schema to create the genmodel and this two attributes are also
defined for the complexType.
Robert
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:gsmtqk$2dh$1@build.eclipse.org...
> Robert,
> Comments below.
>> Hi,
> XMLSaveImpl.
>> located.
>> Robert
Re: use another attribute for cross-references instead of "href" [message #429403 is a reply to message #429398] Wed, 22 April 2009 09:12 Go to previous messageGo to next message
--------------040509010205050300040205
Robert,
I can imagine taking the approach of defining a getter that behaves like
an EReference feature but looks at the library and path values to
navigate to the right wizard page. You could even have a setter that
sets the library and path attributes when a wizard page instance is set,
but of course you then have a tricky problem if these value depend on
attributes on the referenced wizard page, which could change
independently. But maybe that's fine.
> Hi Ed,
> Best regards,
> Robert
>> Robert,
>> Comments below.
>>> Hi,
>> XMLSaveImpl.
>>> located.
>>> Robert
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Robert,<br>
<br>
like an EReference feature but looks at the library and path values to
navigate to the right wizard page.&nbsp; You could even have a setter that
set, but of course you then have a tricky problem if these value depend
on attributes on the referenced wizard page, which could change
independently.&nbsp; But maybe that's fine. <br>
<br>
<br>
<blockquote cite="mid:gsn01k$kr6$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
Robert
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com">&lt;Ed.Merks@gmail.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:gsmtqk$2dh$1@build.eclipse.org">news:gsmtqk$2dh$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Robert,
Comments below.
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
<pre wrap="">Where there's a will there's a way, but not necessarily an easy way.
XMLSaveImpl.
</pre>
<pre wrap="">&lt;WizardPage library="" path=""&gt;
located.
</pre>
</blockquote>
<pre wrap="">Is there a schema for your syntax?
</pre>
<pre wrap="">Thanks and best regards,
Robert
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------040509010205050300040205--
Re: use another attribute for cross-references instead of "href" [message #429405 is a reply to message #429403] Wed, 22 April 2009 09:36 Go to previous messageGo to next message
------=_NextPart_000_010B_01C9C360.12DDC3D0
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Ed,
the <WizardPage> tag can be an internal object or an external. If the =
path and library attribute is defined then the WizardPage is external =
and the content has to be readed from referenced file. External objects =
should be only be shown in readonly mode. The attributes library and =
path are only in the file which references the external file. Library =
attribute is only filled in if the file is located in another project.
File1
<Wizard>
<WizardPage>
<WizardContainer/>
</WizardPage>
<WizardPage library=3D"lib" path=3D"File2"/>
</Wizard>
File2
<WizardPage>
<WizardContainer/>
<WizardContainer/>
</WizardPage>
Regards, Robert
"Ed Merks" <Ed.Merks@gmail.com> wrote in message =
news:gsn54f$eqs$1@build.eclipse.org...
Robert,
I can imagine taking the approach of defining a getter that behaves =
like an EReference feature but looks at the library and path values to =
navigate to the right wizard page. You could even have a setter that =
sets the library and path attributes when a wizard page instance is set, =
but of course you then have a tricky problem if these value depend on =
attributes on the referenced wizard page, which could change =
independently. But maybe that's fine.=20
Robert Driesner wrote:=20
Hi Ed,
I?m using XML schema to create the genmodel and this two attributes are =
also=20
Robert
"Ed Merks" <Ed.Merks@gmail.com> wrote in message=20
Robert,
Comments below.
is it possible to override the loading of external references instead of =
Where there's a will there's a way, but not necessarily an easy =
way.=20
Pretty much anything is possible if you specialize the XMLHandler and=20
XMLSaveImpl.
<WizardPage library=3D"" path=3D"">
We have already attributes which defines where the external page is=20
located.
Robert
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2900.3492" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>the &lt;WizardPage&gt; tag can be an =
internal=20
object or an external. If the path and library attribute is defined then =
the=20
WizardPage is external and the content has to be readed from referenced =
file.=20
External objects should be only be shown in readonly mode. The =
attributes=20
library and path are only in the file which references the external =
file.=20
Library attribute is only filled in if the file is located in another=20
project.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>File1</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&lt;Wizard&gt;</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; =
&lt;WizardPage&gt;</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;=20
&lt;WizardContainer/</FONT><FONT face=3DArial size=3D2>&gt;</FONT></DIV>
&lt;/WizardPage&gt;</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; &lt;WizardPage =
library=3D"lib"=20
path=3D"File2"/&gt;</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&lt;/Wizard&gt;</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>File2</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&lt;WizardPage&gt;</FONT></DIV>
&lt;WizardContainer/<FONT=20
face=3DArial size=3D2>&gt;</FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&lt;/WizardPage&gt;</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Regards, Robert</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" &lt;<A=20
href=3D"mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</A>&gt; wrote in =
message=20
<A=20
href=3D"news:gsn54f$eqs$1@build.eclipse.org">news:gsn54f$eqs$1@build.ecli=
pse.org</A>...</DIV>Robert,<BR><BR>I=20
can imagine taking the approach of defining a getter that behaves like =
an=20
navigate to the=20
right wizard page.&nbsp; You could even have a setter that sets the =
library=20
and path attributes when a wizard page instance is set, but of course =
you then=20
have a tricky problem if these value depend on attributes on the =
referenced=20
wizard page, which could change independently.&nbsp; But maybe that's =
fine.=20
<BR><BR><BR>Robert Driesner wrote:=20
<BLOCKQUOTE cite=3Dmid:gsn01k$kr6$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Hi Ed,
also=20
Robert
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:Ed.Merks@gmail.com">&lt;Ed.Merks@gmail.com&gt;</A> wrote =
in message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:gsmtqk$2dh$1@build.eclipse.org">news:gsmtqk$2dh$1@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Robert,
Comments below.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi,
</PRE></BLOCKQUOTE><PRE wrap=3D"">Where there's a will there's a =
way, but not necessarily an easy way.=20
XMLSaveImpl.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">&lt;WizardPage =
library=3D"" path=3D""&gt;
located.
</PRE></BLOCKQUOTE><PRE wrap=3D"">Is there a schema for your =
syntax?
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Thanks and best regards,
Robert
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_010B_01C9C360.12DDC3D0--
Re: use another attribute for cross-references instead of "href" [message #429410 is a reply to message #429403] Wed, 22 April 2009 10:14 Go to previous messageGo to next message
------=_NextPart_000_013A_01C9C365.66BEBFE0
Hi Ed,
I have overriden the getChildren from the corresponding ItemProvider. =
There I=B4m looking for the features path and library, load the =
referenced file and return the object from referenced file. It seems to =
work. Maybe you have a better idea.
Robert
Robert,
Hi Ed,
also=20
Robert
Robert,
Comments below.
way.=20
XMLSaveImpl.
located.
Robert
=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Hi Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I have overriden the getChildren from =
the=20
corresponding ItemProvider. There I=B4m looking for the features path =
and library,=20
load the referenced file and return the object from referenced file. It =
seems to=20
work. Maybe you have a better idea.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Best regards,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Robert</FONT></DIV>
message=20
<A=20
an=20
navigate to the=20
library=20
you then=20
referenced=20
fine.=20
also=20
Robert
in message=20
pse.org</A>...
</PRE>
Comments below.
</PRE>
XMLSaveImpl.
</PRE>
located.
syntax?
</PRE>
Robert
------=_NextPart_000_013A_01C9C365.66BEBFE0--
Re: use another attribute for cross-references instead of "href" [message #429412 is a reply to message #429410] Wed, 22 April 2009 11:00 Go to previous messageGo to next message
--------------050203050804010601030003
Robert,
I thought you wanted to do this directly on the model, not just in the
view, but if you only need it in the view, that approach you've outlined
sounds reasonable, though I wonder what should happen if the user
directly edits the attributes that indirectly would change the
referenced page...
> Hi Ed,
> There I
Re: use another attribute for cross-references instead of "href" [message #429428 is a reply to message #429412] Thu, 23 April 2009 02:21 Go to previous message
------=_NextPart_000_017B_01C9C3EC.8794BDA0
Ed,
if I edit this attributes then changes will be stored in the referenced =
file. But I want provide only a readonly mode where the=20
attributes of external files cannot be change.
news:gsnbe8$sr8$2@build.eclipse.org...
Robert,
I thought you wanted to do this directly on the model, not just in the =
view, but if you only need it in the view, that approach you've outlined =
sounds reasonable, though I wonder what should happen if the user =
directly edits the attributes that indirectly would change the =
referenced page...
Hi Ed,
I have overriden the getChildren from the corresponding =
ItemProvider. There I=B4m looking for the features path and library, =
seems to work. Maybe you have a better idea.
Robert
Robert,
I can imagine taking the approach of defining a getter that =
behaves like an EReference feature but looks at the library and path =
values to navigate to the right wizard page. You could even have a =
setter that sets the library and path attributes when a wizard page =
instance is set, but of course you then have a tricky problem if these =
value depend on attributes on the referenced wizard page, which could =
change independently. But maybe that's fine.=20
Hi Ed,
also=20
Robert
Robert,
Comments below.
way.=20
XMLSaveImpl.
located.
Robert
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.3492" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>if I edit this attributes then changes =
will be=20
stored in the referenced file. But I want provide only a readonly mode =
where the=20
</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>attributes of external files cannot be=20
change.</FONT></DIV>
message=20
<A=20
href=3D"news:gsnbe8$sr8$2@build.eclipse.org">news:gsnbe8$sr8$2@build.ecli=
view, but=20
if you only need it in the view, that approach you've outlined sounds=20
reasonable, though I wonder what should happen if the user directly =
edits the=20
attributes that indirectly would change the referenced=20
page...<BR><BR><BR>Robert Driesner wrote:=20
<BLOCKQUOTE cite=3Dmid:gsn8o1$2jm$1@build.eclipse.org type=3D"cite">
<STYLE></STYLE>
<DIV><FONT face=3DArial size=3D2>I have overriden the getChildren =
from the=20
corresponding ItemProvider. There I=B4m looking for the features =
path and=20
library, load the referenced file and return the object from =
referenced=20
file. It seems to work. Maybe you have a better idea.</FONT></DIV>
<DIV>&nbsp;</DIV>
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" &lt;<A href=3D"mailto:Ed.Merks@gmail.com"=20
moz-do-not-send=3D"true">Ed.Merks@gmail.com</A>&gt; wrote in =
message <A=20
href=3D"news:gsn54f$eqs$1@build.eclipse.org"=20
moz-do-not-send=3D"true">news:gsn54f$eqs$1@build.eclipse.org</A>...</DIV>=
Robert,<BR><BR>I=20
like an=20
navigate to=20
the right wizard page.&nbsp; You could even have a setter that =
sets the=20
but of=20
attributes=20
independently.&nbsp; But=20
maybe that's fine. <BR><BR><BR>Robert Driesner wrote:=20
also=20
Robert
href=3D"mailto:Ed.Merks@gmail.com" =
moz-do-not-send=3D"true">&lt;Ed.Merks@gmail.com&gt;</A> wrote in message =
href=3D"news:gsmtqk$2dh$1@build.eclipse.org" =
moz-do-not-send=3D"true">news:gsmtqk$2dh$1@build.eclipse.org</A>...
</PRE>
Comments below.
</PRE>
XMLSaveImpl.
</PRE>
located.
syntax?
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Thanks and best =
regards,
Robert
</PRE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE ></BODY></HTML>
------=_NextPart_000_017B_01C9C3EC.8794BDA0--
Previous Topic:[EMF Databinding]
Next Topic:HowTo model initializers
Current Time: Sun Jul 20 09:14:58 EDT 2025
Powered by FUDForum. Page generated in 0.05964 seconds
