Home » Modeling » EMF » use another attribute for cross-references instead of "href"
use another attribute for cross-references instead of "href" [message #429392] |
Wed, 22 April 2009 02:41  |
is it possible to override the loading of external references instead of
using the href attribute.
<WizardPage library="" path="">
We have already attributes which defines where the external page is
located.
The path attribute is also not a correct URI.
Thanks and best regards,
Robert
Re: use another attribute for cross-references instead of "href" [message #429403 is a reply to message #429398] |
Wed, 22 April 2009 09:12   |
--------------040509010205050300040205
Robert,
I can imagine taking the approach of defining a getter that behaves like
an EReference feature but looks at the library and path values to
navigate to the right wizard page. You could even have a setter that
sets the library and path attributes when a wizard page instance is set,
but of course you then have a tricky problem if these value depend on
attributes on the referenced wizard page, which could change
independently. But maybe that's fine.
Robert Driesner wrote:
> Hi Ed,
> I?m using XML schema to create the genmodel and this two attributes are also
> defined for the complexType.
> Best regards,
> Robert
> "Ed Merks" <Ed.Merks@gmail.com> wrote in message
> news:gsmtqk$2dh$1@build.eclipse.org...
>> Robert,
>> Comments below.
>>> Hi,
>> Where there's a will there's a way, but not necessarily an easy way.
>> Pretty much anything is possible if you specialize the XMLHandler and
>> XMLSaveImpl.
>>> located.
>> Is there a schema for your syntax?
>>> Robert
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Robert,<br>
<br>
like an EReference feature but looks at the library and path values to
set, but of course you then have a tricky problem if these value depend
on attributes on the referenced wizard page, which could change
independently. But maybe that's fine. <br>
<br>
<br>
<blockquote cite="mid:gsn01k$kr6$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
Robert
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com"><Ed.Merks@gmail.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:gsmtqk$2dh$1@build.eclipse.org">news:gsmtqk$2dh$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Robert,
Comments below.
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
<pre wrap="">Where there's a will there's a way, but not necessarily an easy way.
XMLSaveImpl.
</pre>
<pre wrap=""><WizardPage library="" path="">
located.
</pre>
</blockquote>
<pre wrap="">Is there a schema for your syntax?
</pre>
<pre wrap="">Thanks and best regards,
Robert
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------040509010205050300040205--
Re: use another attribute for cross-references instead of "href" [message #429405 is a reply to message #429403] |
Wed, 22 April 2009 09:36   |
------=_NextPart_000_010B_01C9C360.12DDC3D0
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Ed,
the <WizardPage> tag can be an internal object or an external. If the =
path and library attribute is defined then the WizardPage is external =
and the content has to be readed from referenced file. External objects =
should be only be shown in readonly mode. The attributes library and =
path are only in the file which references the external file. Library =
attribute is only filled in if the file is located in another project.
File1
<Wizard>
<WizardPage>
<WizardContainer/>
</WizardPage>
<WizardPage library=3D"lib" path=3D"File2"/>
</Wizard>
File2
<WizardPage>
<WizardContainer/>
<WizardContainer/>
</WizardPage>
Regards, Robert
"Ed Merks" <Ed.Merks@gmail.com> wrote in message =
news:gsn54f$eqs$1@build.eclipse.org...
Robert,
I can imagine taking the approach of defining a getter that behaves =
like an EReference feature but looks at the library and path values to =
navigate to the right wizard page. You could even have a setter that =
sets the library and path attributes when a wizard page instance is set, =
but of course you then have a tricky problem if these value depend on =
attributes on the referenced wizard page, which could change =
independently. But maybe that's fine.=20
Robert Driesner wrote:=20
Hi Ed,
I?m using XML schema to create the genmodel and this two attributes are =
also=20
Robert
"Ed Merks" <Ed.Merks@gmail.com> wrote in message=20
Robert,
Comments below.
is it possible to override the loading of external references instead of =
Where there's a will there's a way, but not necessarily an easy =
way.=20
Pretty much anything is possible if you specialize the XMLHandler and=20
XMLSaveImpl.
<WizardPage library=3D"" path=3D"">
We have already attributes which defines where the external page is=20
located.
Robert
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2900.3492" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>the <WizardPage> tag can be an =
internal=20
object or an external. If the path and library attribute is defined then =
the=20
WizardPage is external and the content has to be readed from referenced =
file.=20
External objects should be only be shown in readonly mode. The =
attributes=20
library and path are only in the file which references the external =
file.=20
Library attribute is only filled in if the file is located in another=20
project.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>File1</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><Wizard></FONT></DIV>
<DIV><FONT face=3DArial size=3D2> =
<WizardPage></FONT></DIV>
<DIV><FONT face=3DArial size=3D2> =20
<WizardContainer/</FONT><FONT face=3DArial size=3D2>></FONT></DIV>
</WizardPage></FONT></DIV>
<DIV><FONT face=3DArial size=3D2> <WizardPage =
library=3D"lib"=20
path=3D"File2"/></FONT></DIV>
<DIV><FONT face=3DArial size=3D2></Wizard></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>File2</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><WizardPage></FONT></DIV>
<WizardContainer/<FONT=20
face=3DArial size=3D2>></FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2></WizardPage></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Regards, Robert</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A=20
href=3D"mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</A>> wrote in =
message=20
<A=20
href=3D"news:gsn54f$eqs$1@build.eclipse.org">news:gsn54f$eqs$1@build.ecli=
pse.org</A>...</DIV>Robert,<BR><BR>I=20
can imagine taking the approach of defining a getter that behaves like =
an=20
navigate to the=20
right wizard page. You could even have a setter that sets the =
library=20
and path attributes when a wizard page instance is set, but of course =
you then=20
have a tricky problem if these value depend on attributes on the =
referenced=20
wizard page, which could change independently. But maybe that's =
fine.=20
<BR><BR><BR>Robert Driesner wrote:=20
<BLOCKQUOTE cite=3Dmid:gsn01k$kr6$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Hi Ed,
also=20
Robert
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:Ed.Merks@gmail.com"><Ed.Merks@gmail.com></A> wrote =
in message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:gsmtqk$2dh$1@build.eclipse.org">news:gsmtqk$2dh$1@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Robert,
Comments below.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi,
</PRE></BLOCKQUOTE><PRE wrap=3D"">Where there's a will there's a =
way, but not necessarily an easy way.=20
XMLSaveImpl.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D""><WizardPage =
located.
</PRE></BLOCKQUOTE><PRE wrap=3D"">Is there a schema for your =
syntax?
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Thanks and best regards,
Robert
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_010B_01C9C360.12DDC3D0--
Re: use another attribute for cross-references instead of "href" [message #429410 is a reply to message #429403] |
Wed, 22 April 2009 10:14   |
------=_NextPart_000_013A_01C9C365.66BEBFE0
Hi Ed,
I have overriden the getChildren from the corresponding ItemProvider. =
There I=B4m looking for the features path and library, load the =
referenced file and return the object from referenced file. It seems to =
work. Maybe you have a better idea.
Robert
Robert,
Hi Ed,
also=20
Robert
Robert,
Comments below.
way.=20
XMLSaveImpl.
located.
Robert
=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Hi Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I have overriden the getChildren from =
the=20
corresponding ItemProvider. There I=B4m looking for the features path =
and library,=20
load the referenced file and return the object from referenced file. It =
seems to=20
work. Maybe you have a better idea.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Best regards,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Robert</FONT></DIV>
message=20
<A=20
an=20
navigate to the=20
library=20
you then=20
referenced=20
fine.=20
also=20
Robert
in message=20
pse.org</A>...
</PRE>
Comments below.
</PRE>
XMLSaveImpl.
</PRE>
located.
syntax?
</PRE>
Robert
------=_NextPart_000_013A_01C9C365.66BEBFE0--
Re: use another attribute for cross-references instead of "href" [message #429428 is a reply to message #429412] |
Thu, 23 April 2009 02:21  |
------=_NextPart_000_017B_01C9C3EC.8794BDA0
Ed,
if I edit this attributes then changes will be stored in the referenced =
file. But I want provide only a readonly mode where the=20
attributes of external files cannot be change.
news:gsnbe8$sr8$2@build.eclipse.org...
Robert,
I thought you wanted to do this directly on the model, not just in the =
view, but if you only need it in the view, that approach you've outlined =
sounds reasonable, though I wonder what should happen if the user =
directly edits the attributes that indirectly would change the =
referenced page...
Hi Ed,
I have overriden the getChildren from the corresponding =
ItemProvider. There I=B4m looking for the features path and library, =
seems to work. Maybe you have a better idea.
Robert
Robert,
I can imagine taking the approach of defining a getter that =
behaves like an EReference feature but looks at the library and path =
values to navigate to the right wizard page. You could even have a =
setter that sets the library and path attributes when a wizard page =
instance is set, but of course you then have a tricky problem if these =
value depend on attributes on the referenced wizard page, which could =
change independently. But maybe that's fine.=20
Hi Ed,
also=20
Robert
Robert,
Comments below.
way.=20
XMLSaveImpl.
located.
Robert
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.3492" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>if I edit this attributes then changes =
will be=20
stored in the referenced file. But I want provide only a readonly mode =
where the=20
</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>attributes of external files cannot be=20
change.</FONT></DIV>
message=20
<A=20
href=3D"news:gsnbe8$sr8$2@build.eclipse.org">news:gsnbe8$sr8$2@build.ecli=
view, but=20
if you only need it in the view, that approach you've outlined sounds=20
reasonable, though I wonder what should happen if the user directly =
edits the=20
attributes that indirectly would change the referenced=20
page...<BR><BR><BR>Robert Driesner wrote:=20
<BLOCKQUOTE cite=3Dmid:gsn8o1$2jm$1@build.eclipse.org type=3D"cite">
<STYLE></STYLE>
<DIV><FONT face=3DArial size=3D2>I have overriden the getChildren =
from the=20
corresponding ItemProvider. There I=B4m looking for the features =
path and=20
library, load the referenced file and return the object from =
referenced=20
file. It seems to work. Maybe you have a better idea.</FONT></DIV>
<DIV> </DIV>
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A href=3D"mailto:Ed.Merks@gmail.com"=20
moz-do-not-send=3D"true">Ed.Merks@gmail.com</A>> wrote in =
message <A=20
href=3D"news:gsn54f$eqs$1@build.eclipse.org"=20
moz-do-not-send=3D"true">news:gsn54f$eqs$1@build.eclipse.org</A>...</DIV>=
Robert,<BR><BR>I=20
like an=20
navigate to=20
sets the=20
but of=20
attributes=20
independently. But=20
maybe that's fine. <BR><BR><BR>Robert Driesner wrote:=20
also=20
Robert
href=3D"mailto:Ed.Merks@gmail.com" =
moz-do-not-send=3D"true"><Ed.Merks@gmail.com></A> wrote in message =
href=3D"news:gsmtqk$2dh$1@build.eclipse.org" =
moz-do-not-send=3D"true">news:gsmtqk$2dh$1@build.eclipse.org</A>...
</PRE>
Comments below.
</PRE>
XMLSaveImpl.
</PRE>
located.
syntax?
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Thanks and best =
regards,
Robert
</PRE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE ></BODY></HTML>
------=_NextPart_000_017B_01C9C3EC.8794BDA0--
Current Time: Sun Jul 20 10:51:17 EDT 2025
Powered by FUDForum. Page generated in 0.03664 seconds
