Home » Modeling » EMF » [CDO] Launching a CDO server and connecting immediately to it from the client fails...
[CDO] Launching a CDO server and connecting immediately to it from the client fails... [message #429340] Mon, 20 April 2009 10:05 Go to next message
I am launching a CDO repository from my Java application using
"ProcessBuilder.start()" with a port number as argument, but when trying
to connect to the same port from the Client it fails after 10 seconds
with a TimeoutRuntimeException (see stack below).
If the client waits by sleeping a couple of seconds before connecting it
succeeds.
Why is this so and, how can I handle this without Thread.sleep from the
client ?
Anders
org.eclipse.net4j.channel.ChannelException:
org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Registration
timeout after 10000 milliseconds
at
org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(Channel Multiplexer.java:171)
at
org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(Channel Multiplexer.java:1)
at
org.eclipse.net4j.signal.failover.NOOPFailOverStrategy.handl eOpen(NOOPFailOverStrategy.java:53)
at org.eclipse.net4j.signal.SignalProtocol.open(SignalProtocol. java:165)
at
org.eclipse.emf.internal.cdo.net4j.protocol.CDOClientProtoco l.openSession(CDOClientProtocol.java:76)
at
org.eclipse.emf.internal.cdo.session.CDOSessionImpl.doActiva te(CDOSessionImpl.java:619)
at
org.eclipse.emf.internal.cdo.net4j.CDONet4jSessionImpl.doAct ivate(CDONet4jSessionImpl.java:82)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycl e.java:62)
at
org.eclipse.emf.internal.cdo.session.CDOSessionConfiguration Impl.openSession(CDOSessionConfigurationImpl.java:125)
at
org.eclipse.emf.internal.cdo.net4j.CDONet4jSessionConfigurat ionImpl.openSession(CDONet4jSessionConfigurationImpl.java:62 )
Re: [CDO] Launching a CDO server and connecting immediately to it from the client fails... [message #429341 is a reply to message #429340] Mon, 20 April 2009 10:43 Go to previous messageGo to next message
hi Anders,
how many time do you allow your server to bootstrap before starting your
client ? basically does your server is ready before starting your client ?
> succeeds.
> client ?
Don`t know yet. :-)
Simon
> Anders
> at
> at
> at
> at
> at
> at
> at
> at
Re: [CDO] Launching a CDO server and connecting immediately to it from the client fails... [message #429343 is a reply to message #429341] Mon, 20 April 2009 14:58 Go to previous messageGo to next message
To clarify:
The client is first editing a model using an XMLResource. Then the
client starts a new CDO server/repository (if necessary) so that the
model can be moved to it. Thus the client need to wait until the server
is up and running. I thought that I could let the client try to connect
immediately after launching the server process, but it turned out that
doing so generated the exception below. Strangely enough the client
needs to wait for a few seconds before trying to connect, then it works...
Anders
Simon Mc Duff wrote:
> hi Anders,
>> trying to connect to the same port from the Client it fails after 10
>> seconds with a TimeoutRuntimeException (see stack below).
>> it succeeds.
>> the client ?
> Don`t know yet. :-)
> Simon
>> Anders
>> Registration timeout after 10000 milliseconds
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: [CDO] Launching a CDO server and connecting immediately to it from the client fails... [message #429348 is a reply to message #429343] Tue, 21 April 2009 03:27 Go to previous messageGo to next message
Anders,
is there a particular reason why you are using the TCP connection CDO
server on the same machine instead of strating the CDO Server in the
same JVM using the IPluginContainer as discussed in the "[CDO] Starting
a CDO server programatically" thread? With the IPluginContainer, startup
and communication should be faster than with starting a new Process and
talking over TCP...
But regarding your question: With TCP you usually get a "connection
refused" error on the networking layer if you try to contact a port
which is not open.
So you have to wait until the port is open before you try to connect.
What you could do is to follow the messages of the child process running
the server and wait for the message saying that the server has been
started, before you connect.
Stefan
> server is up and running. I thought that I could let the client try to
> connect immediately after launching the server process, but it turned
> out that doing so generated the exception below. Strangely enough the
> client needs to wait for a few seconds before trying to connect, then
> it works...
> Anders
>> hi Anders,
>> your client ? basically does your server is ready before starting
>> your client ?
>>> connecting it succeeds.
>>> the client ?
>> Don`t know yet. :-)
>> Simon
>>> Anders
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Re: [CDO] Launching a CDO server and connecting immediately to it from the client fails... [message #429351 is a reply to message #429348] Tue, 21 April 2009 05:05 Go to previous messageGo to next message
Hi Stefan,
See below
Stefan Winkler wrote:
> Anders,
> talking over TCP...
Yes, I have thought about that but prefer different processes so that
the repository would be alive even if the client crashes.
> which is not open.
Ok, I see.
I'll try that, thanks!
> Cheers,
> Stefan
>> it works...
>> Anders
>>> hi Anders,
>>> your client ?
>>>> the client ?
>>> Don`t know yet. :-)
>>> Simon
>>>> Anders
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: [CDO] Launching a CDO server and connecting immediately to it from the client fails... [message #429498 is a reply to message #429351] Fri, 24 April 2009 04:59 Go to previous messageGo to next message
Anders,
I don't really understand what you're trying to achieve, or better: why.
Maybe the problem is just that you start the TCPConnector asynchronously
and don't call waitForConnection()?
I have no clue what a ProcessBuilder is. Is it a question of how to
synchronize on it's progress?
Cheers
/Eike
Anders Forsell schrieb:
> Hi Stefan,
> See below
>> Anders,
>> talking over TCP...
>> which is not open.
> Ok, I see.
>> Cheers,
>> Stefan
>>> it works...
>>> Anders
>>>> hi Anders,
>>>> your client ?
>>>>> the client ?
>>>> Don`t know yet. :-)
>>>> Simon
>>>>> Anders
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
Re: [CDO] Launching a CDO server and connecting immediately to it from the client fails... [message #429706 is a reply to message #429498] Thu, 30 April 2009 02:01 Go to previous messageGo to next message
Hi Eike,
ProcessBuilder is a Java class used to launch child processes.
From my client application I am launching the CDO Server repository
process. When trying to connect to the repository immediately after
launching the child process using...
container = ContainerUtil.createContainer();
Net4jUtil.prepareContainer(container);
TCPUtil.prepareContainer(container);
CDOUtil.prepareContainer(container);
container.activate();
connector = TCPUtil.getConnector(container, "localhost:2036");
connector.waitForConnection(10000);
CDOSessionConfiguration configuration =
CDONet4jUtil.createSessionConfiguration();
configuration.setConnector(connector);
configuration.setRepositoryName("repo1");
session = configuration.openSession();
.... it fails with the "org.eclipse.net4j.channel.ChannelException:
timeout after 10000 milliseconds".
Stefan indicated that the port must be open so I solved this right now
by waiting for until a java.net.Socket.Socket class can be created on
the port without exception. A better solution would be to listen to the
output of the repository process as Stefan suggested.
Or, do you have an even better solution for this?
Anders
Eike Stepper wrote:
> Anders,
> Cheers
> /Eike
> http://thegordian.blogspot.com
>> Hi Stefan,
>> See below
>>> Anders,
>>> talking over TCP...
>>> which is not open.
>> Ok, I see.
>>> Cheers,
>>> Stefan
>>>> it works...
>>>> Anders
>>>>> hi Anders,
>>>>> your client ?
>>>>>> the client ?
>>>>> Don`t know yet. :-)
>>>>> Simon
>>>>>> Anders
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
Re: [CDO] Launching a CDO server and connecting immediately to it from the client fails... [message #429779 is a reply to message #429706] Fri, 01 May 2009 01:56 Go to previous message
> the output of the repository process as Stefan suggested.
No, I think this is exactly what I meant with my previous comment:
I have no clue what a ProcessBuilder is. Is it a question of how to synchronize on it's progress?
Should have said it in more and simpler words :P
Cheers
/Eike
Previous Topic:Show Ecore Datamodel in editor
Next Topic:[CDO] IllegalStateException while saving model
Current Time: Sun Jul 20 15:39:16 EDT 2025
Powered by FUDForum. Page generated in 0.20470 seconds
