Home » Modeling » EMF » Generated editor loads content too early
Generated editor loads content too early [message #428825] Tue, 31 March 2009 09:15 Go to next message
for our project we're still using the editor generated by the EMF code
generation tools. Now we're faced with the following problem:
In order to get notified about a reference being added to an EList
object we changed the getter of the EList to
public EList getHasNContexts() {
if (hasNContexts == null) {
// was: hasNContexts = new EObjectResolvingEList(...
hasNContexts = new NotifyingList(
Context.class,
this,
SbqPackage.QUERY_NODE__HAS_NCONTEXTS);
return hasNContexts;
where NotifyingList is a local class extending EObjectResolvingEList
like so:
private class NotifyingList extends EObjectResolvingEList {
protected void didAdd(int index, Object newObject) {
// Get runtime representation of the context
RuntimeContext ctx = Registry.obtain(
(Context)newObject
// do something with ctx
i.e. we replaced the EList implementation with our own version and that
overrides the didAdd method.
What we want to achieve is to obtain some object from a Registry in the
course of the didAdd() method being called and thats the point where the
problem arises:
The Registry is supposed to be filled through another plugin in the
course of running its IStartup.earlyStartup() method. This method gets
called independent of a Bundle activator because we extend the
org.eclipse.ui.startup
extension point and specify the class that implements the IStartup
interface.
Everything is fine when I start the editor and then open a file in the
generated editor. Things go wrong when I terminate the editor with the
file being opened and then restart it. Now the file apparently gets
deserialized and the didAdd() method gets called. And this happens
*before* the IStartup.earlyStartup() gets called.
This seems weird to me as I explicitely asked the
IStartup.earlyStartup() to be called upon eclipse starting up but the
loading of the file still happens before that.
Anybody any ideas?
Dirk
Re: Generated editor loads content too early [message #428827 is a reply to message #428825] Tue, 31 March 2009 09:49 Go to previous messageGo to next message
Some things to add:
Tried to detect that the didAdd() method is called in the course of
deserializing. Retrieved the Resource object from the passed in
newObject argument and debugging revealed two protected member variables
"isLoading" and "isLoaded". Both have the value true which appears quite
contradictous to me. isLoading = true may be a candidate to find out
whether we are in the course of deserializing but unfortunately this
variable has no getter. isLoaded has a getter but its value is useless.
Is there any other simple method to distinct getter/setter calls that
happen during deserialisation from those caused by editing actions?
Dirk
Dirk Hoffmann schrieb:
> Context.class,
> this,
> like so:
> (Context)newObject
> problem arises:
> interface.
> Anybody any ideas?
> Regards,
> Dirk
Re: Generated editor loads content too early [message #428832 is a reply to message #428827] Tue, 31 March 2009 10:21 Go to previous messageGo to next message
Dirk,
Comments below.
Dirk Hoffmann wrote:
> Some things to add:
> deserializing.
It will happen during copying as well...
> Retrieved the Resource object from the passed in newObject argument
> quite contradictous to me.
The variable is set early to eliminate the possibility that you might
recursively cause the resource to be loaded while it's loading. The
notification doesn't go out until the loading is complete though, so
external observers should generally see the actual loaded resource.
> isLoading = true may be a candidate to find out whether we are in the
> course of deserializing but unfortunately this variable has no getter.
You didn't notice Resource.Internal.
If you have an object that's in a resource, you can definitely expect
this value to be true, so it will not serve your purpose at all.
The nature of the question seems problematic because EcoreUtil.copy will
generally be much like deserialization, so whatever problem you fix is
likely to resurface.
> Regards,
> Dirk
>> Hi,
>> code generation tools. Now we're faced with the following problem:
>> Context.class,
>> this,
>> like so:
>> (Context)newObject
>> that overrides the didAdd method.
>> the course of the didAdd() method being called and thats the point
>> where the problem arises:
>> gets called independent of a Bundle activator because we extend the
>> interface.
Of course it's generally bad to do early startup as well...
>> the generated editor. Things go wrong when I terminate the editor
>> with the file being opened and then restart it. Now the file
>> apparently gets deserialized and the didAdd() method gets called. And
>> this happens *before* the IStartup.earlyStartup() gets called.
It seems odd to me that earlyStartup should happen so late. I also
don't understand why your bundle's regular start doesn't initialize the
registry. Given a dependency on such a bundle, the bundles
initialization should be done long before anyone depending on it can see it.
It's definitely weird. But I don't even understand why you need
earlyStartup. EMF has all kinds of registries that must be populated
before any other EMF-based plugins will work properly, yet we have no
need for early startup...
>> Anybody any ideas?
>> Regards,
>> Dirk
Re: Generated editor loads content too early [message #428889 is a reply to message #428832] Wed, 01 April 2009 09:26 Go to previous messageGo to next message
thanks to Ed for the prompt reply; I wonder how much time he spends each
day to answer all the questions from the EMF users.
See below for comments.
Ed Merks schrieb:
> Dirk,
> Comments below.
>> Some things to add:
>> deserializing.
Ah, never thought of this but I believe we can live with that.
Another "Ah". Meanwhile I had coded a cast to ResourceImpl but changed
that now to Resource.Internal; guess that's the official way to access
that piece of information. The isLoading attribute is the right one to
detect the deserialization context.
>> Regards,
>> Dirk
>>> Hi,
>>> Context.class,
>>> this,
>>> like so:
>>> (Context)newObject
>>> interface.
> it.
Tried that when running my feature from within the ide and also as a
feature built, packed and dropped into another Eclipse installation.
Observed the same effect in both situations. By the way: Using EMF 2.2.4
with Eclipse 3.2.2 for developing and also tested the feature with
Eclipse 3.3.2 and EMF 2.3.0.
The reason for the IStartup.earlyStartup() is that I want to be able to
simply drop that plugin into the plugins directory and have it register
some objects with a Registry provided by another plugin upon startup.
Maybe this is not the right approach; I guess the Registry plugin should
provide an extension point which the plugin that registers stuff would
then implement. It's just that I haven't got into that extension point
stuff up to date.
>>> Anybody any ideas?
>>> Regards,
>>> Dirk
Re: Generated editor loads content too early [message #428893 is a reply to message #428889] Wed, 01 April 2009 09:49 Go to previous message
--------------000509090902090606000208
Dirk,
Comments below.
> each day to answer all the questions from the EMF users.
A scary amount of time, though not as much as you might think. I have a
formula to speed it up as described at the end of this blog:
< http://ed-merks.blogspot.com/2008/10/service-and-support-fue l-for-your.html>
> Ed Merks schrieb:
>> Dirk,
>> Comments below.
>>> Some things to add:
>>> deserializing.
>>> the course of deserializing but unfortunately this variable has no
>>> getter.
Yes.
> The isLoading attribute is the right one to detect the deserialization
> context.
Yes, Kenn Hussey really wanted it for UML a long time ago.
>>> that happen during deserialisation from those caused by editing
>>> actions?
>> will generally be much like deserialization, so whatever problem you
>> fix is likely to resurface.
>>> Regards,
>>> Dirk
>>>> Hi,
>>>> Context.class,
>>>> this,
>>>> EObjectResolvingEList like so:
>>>> (Context)newObject
>>>> interface.
>>>> And this happens *before* the IStartup.earlyStartup() gets called.
>> the registry. Given a dependency on such a bundle, the bundles
>> see it.
> 2.2.4 with Eclipse 3.2.2 for developing and also tested the feature
> with Eclipse 3.3.2 and EMF 2.3.0.
> to simply drop that plugin into the plugins directory and have it
> register some objects with a Registry provided by another plugin upon
> startup.
Doesn't that other plugin have extension points?
> should provide an extension point which the plugin that registers
> stuff would then implement. It's just that I haven't got into that
> extension point stuff up to date.
Indeed. It's best for everything to be on-demand/lazy...
>>>> the loading of the file still happens before that.
>>>> Anybody any ideas?
>>>> Regards,
>>>> Dirk
<html>
<head>
http-equiv="Content-Type">
</head>
Dirk,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:gqvq2o$3tp$1@build.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
</blockquote>
Previous Topic:Generate 'final' operation parameters (EParameter)
Next Topic:Hide/Reorder Nodes/Properties in Editor
Current Time: Sat Jul 19 19:51:36 EDT 2025
Powered by FUDForum. Page generated in 0.04355 seconds
