Home » Modeling » EMF » [CDO] Locks management behavior.
[CDO] Locks management behavior. [message #428718] |
Fri, 27 March 2009 10:06  |
I'm testing the lock mechanism and I need some explanations.
Here is my scenario :
1) Start an eclipse SDK
2) Open a CDOEditor from the CDO Session view on an existing resource
(res1) with data.
3) Lock (writeLock)an object, let's say the root object 'A'.
4) Start another eclipse SDK
5) Open a CDOEditor from the CDO Session view on the same resource (res1).
6) Try locking (writeLock) the root object 'A', as expected it is not
possible you should have a NPE (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=270139).
7) Lock an object 'B'
8) Modify a B attribute whatever.
9) Save the resource res1.
10) Go back to the first Eclipse sdk (first client)
11) Right click on object 'A', the writeLock is released.
Is it a normal behavior ?
If you lock an object A in a resource, any save operations from other open
sessions release all locked objects ?
I would think, only the locked objects owned by the session (which has
performed the save operation) are released !
Stephane.
Re: [CDO] Locks management behavior. [message #428737 is a reply to message #428735] |
Sat, 28 March 2009 07:38   |
Hi Simon,
I'm not sleeping but I will be back to CDO stuff on Monday ;)
Thank you, Simon, for the quick fix. I will test that on Monday morning.
Stéphane.
On 28/03/2009 02:23, Simon McDuff wrote:
> You are probably sleeping: :-)
> Here the bugzilla:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=270345
> Simon
> Simon McDuff wrote:
>> I fixed it... just waiting for the bugzilla !
>> Simon
>> Simon McDuff wrote:
>>> You are absolutely right. We have a problem in the core.
>>> Can you file a bugzilla please ?
>>> Simon
>>> Simon Mc Duff wrote:
>>>> Stéphane Fournier wrote:
>>>>> Hi,
>>>>> resource (res1) with data.
>>>>> (res1).
>>>>> not possible you should have a NPE (see
>>>> No it is not the normal behavior.
>>>>> other open sessions release all locked objects ? I would think,
>>>>> only the locked objects owned by the session (which has performed
>>>> Not exactly. Locks are attached to views/transactions.
>>>> I will check our testcases first... after if I don`t see anything I
>>>> will look at the Ui of CDO to see what is happenning. Thank you for
>>>> the steps.
>>>>> Stephane.
Re: [CDO] Locks management behavior. [message #428767 is a reply to message #428737] |
Mon, 30 March 2009 03:58   |
Hi Simon,
Are you back from the Con ? How was it ?
I've tested your fix, and it works :).
Stéphane.
> Hi Simon,
> Stéphane.
>> Here the bugzilla:
>> Simon
>>> Simon
>>>> Simon
>>>>>> Hi,
>>>>>> (res1).
>>>>> the steps.
>>>>>> Stephane.
Re: [CDO] Locks management behavior. [message #428805 is a reply to message #428767] |
Mon, 30 March 2009 21:25  |
> Hi Simon,
Yes I'm back.. and so many things to do.
Eclipse Con (my first one) was very very good! I think I will go each
year now!! :-) I meet many people... Eike and I meet for the first
time!! It was memorable!! :-) It is good to put face on name !! Maybe
you will be there next year.
Simon
Good!!
> Stéphane.
>> Hi Simon,
>> Stéphane.
>>> Here the bugzilla:
>>> Simon
>>>> Simon
>>>>> Simon
>>>>>>> Hi,
>>>>>>> (res1).
>>>>>> the steps.
>>>>>>> Stephane.
Current Time: Sat Jul 19 09:44:34 EDT 2025
Powered by FUDForum. Page generated in 0.08433 seconds
