Home » Modeling » EMF » [CDO] Locks management behavior.
[CDO] Locks management behavior. [message #428718] Fri, 27 March 2009 10:06 Go to next message
I'm testing the lock mechanism and I need some explanations.
Here is my scenario :
1) Start an eclipse SDK
2) Open a CDOEditor from the CDO Session view on an existing resource
(res1) with data.
3) Lock (writeLock)an object, let's say the root object 'A'.
4) Start another eclipse SDK
5) Open a CDOEditor from the CDO Session view on the same resource (res1).
6) Try locking (writeLock) the root object 'A', as expected it is not
possible you should have a NPE (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=270139).
7) Lock an object 'B'
8) Modify a B attribute whatever.
9) Save the resource res1.
10) Go back to the first Eclipse sdk (first client)
11) Right click on object 'A', the writeLock is released.
Is it a normal behavior ?
If you lock an object A in a resource, any save operations from other open
sessions release all locked objects ?
I would think, only the locked objects owned by the session (which has
performed the save operation) are released !
Stephane.
Re: [CDO] Locks management behavior. [message #428730 is a reply to message #428718] Fri, 27 March 2009 18:28 Go to previous messageGo to next message
Stéphane Fournier wrote:
> (res1) with data.
No it is not the normal behavior.
Not exactly. Locks are attached to views/transactions.
I will check our testcases first... after if I don`t see anything I will
look at the Ui of CDO to see what is happenning.
Thank you for the steps.
> Stephane.
Re: [CDO] Locks management behavior. [message #428733 is a reply to message #428730] Fri, 27 March 2009 20:41 Go to previous messageGo to next message
You are absolutely right. We have a problem in the core.
Can you file a bugzilla please ?
Simon
>> Hi,
>> (res1) with data.
>> (res1).
>> open sessions release all locked objects ? I would think, only the
>> locked objects owned by the session (which has performed the save
> look at the Ui of CDO to see what is happenning. Thank you for the steps.
>> Stephane.
Re: [CDO] Locks management behavior. [message #428734 is a reply to message #428733] Fri, 27 March 2009 21:12 Go to previous messageGo to next message
I fixed it... just waiting for the bugzilla !
Simon
> Simon
>>> Hi,
>>> (res1) with data.
>>> (res1).
>> will look at the Ui of CDO to see what is happenning. Thank you for
>> the steps.
>>> Stephane.
Re: [CDO] Locks management behavior. [message #428735 is a reply to message #428734] Fri, 27 March 2009 21:23 Go to previous messageGo to next message
You are probably sleeping: :-)
Here the bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=270345
Simon
> Simon
>> Simon
>>>> Hi,
>>>> resource (res1) with data.
>>>> (res1).
>>>> not possible you should have a NPE (see
>>>> other open sessions release all locked objects ? I would think, only
>>>> the locked objects owned by the session (which has performed the
>>> the steps.
>>>> Stephane.
Re: [CDO] Locks management behavior. [message #428737 is a reply to message #428735] Sat, 28 March 2009 07:38 Go to previous messageGo to next message
Hi Simon,
I'm not sleeping but I will be back to CDO stuff on Monday ;)
Thank you, Simon, for the quick fix. I will test that on Monday morning.
Stéphane.
> Here the bugzilla:
> Simon
>> Simon
>>> Simon
>>>>> Hi,
>>>>> (res1).
>>>>> only the locked objects owned by the session (which has performed
>>>> the steps.
>>>>> Stephane.
Re: [CDO] Locks management behavior. [message #428767 is a reply to message #428737] Mon, 30 March 2009 03:58 Go to previous messageGo to next message
Hi Simon,
Are you back from the Con ? How was it ?
I've tested your fix, and it works :).
Stéphane.
> Hi Simon,
> Stéphane.
>> Here the bugzilla:
>> Simon
>>> Simon
>>>> Simon
>>>>>> Hi,
>>>>>> (res1).
>>>>> the steps.
>>>>>> Stephane.
Re: [CDO] Locks management behavior. [message #428805 is a reply to message #428767] Mon, 30 March 2009 21:25 Go to previous message
> Hi Simon,
Yes I'm back.. and so many things to do.
Eclipse Con (my first one) was very very good! I think I will go each
year now!! :-) I meet many people... Eike and I meet for the first
time!! It was memorable!! :-) It is good to put face on name !! Maybe
you will be there next year.
Simon
Good!!
> Stéphane.
>> Hi Simon,
>> Stéphane.
>>> Here the bugzilla:
>>> Simon
>>>> Simon
>>>>> Simon
>>>>>>> Hi,
>>>>>>> (res1).
>>>>>> the steps.
>>>>>>> Stephane.
Previous Topic:Nested Notification Question
Next Topic:Modeling 'Equation' Data Structure in EMF
Current Time: Sat Jul 19 14:50:16 EDT 2025
Powered by FUDForum. Page generated in 0.05566 seconds
