Home » Modeling » EMF » Overriding the default resource factory for .ecore files
Overriding the default resource factory for .ecore files [message #428518] |
Tue, 24 March 2009 11:08  |
I want to register a resource factory for .ecore files that loads Ecore
files represented in a text syntax rather than XMI.
I did the following:
<extension point="org.eclipse.emf.ecore.content_parser">
<parser class="org.company.CustomizedEcoreResourceFactory"
contentTypeIdentifier="org.eclipse.emf.ecore.textual">
</parser>
</extension>
<extension point="org.eclipse.core.contenttype.contentTypes">
<file-association content-type="org.ecore.textual"
file-extensions="ecore">
</file-association>
</extension>
<extension point="org.eclipse.core.runtime.contentTypes" id="someID">
<content-type id="org.eclipse.emf.ecore.textual"
name="Ecore Textual Syntax"
<describer class="org.company.TextualEcoreContentDescriber"/>
</content-type>
</extension>
However, the default resource factory (defined in plug-in
org.eclipse.emf.ecore.xmi) is always preferred, because extension
parsers have a higher priority than content parsers.
As a result, my (textual) Ecore files are not loaded using my resource
factory (CustomizedEcoreResourceFactory), but the default factory
(EcoreResourceFactoryImpl), which fails.
If I manually de-register the default factory, the whole thing works,
but this is somewhat ugly:
Registry registry = Resource.Factory.Registry.INSTANCE;
registry.getExtensionToFactoryMap().remove("ecore");
Is there a way to do this more clever?
Mirko
P.S. I've read http://www.eclipsezone.com/eclipse/forums/t107605.html
but this is not a solution, because I do not have access to the editing
domain that loads my textual ecore models.
Re: Overriding the default resource factory for .ecore files [message #428523 is a reply to message #428518] |
Tue, 24 March 2009 11:25   |
Mirko,
Comments below.
Mirko Seifert wrote:
> Ecore files represented in a text syntax rather than XMI.
Like Emphatic...
> </parser>
> </extension>
> </file-association>
> </extension>
Reusing the same extension seems like a bad idea...
> </content-type>
> </extension>
Yes. That was to avoid having content type registrations affect all
clients who were previously getting along fine without them.
Don't do that!
Here's a good technique:
resourceSet.getResourceFactoryRegistry.getContentTypeToFacto ryMap().putAll(Resource.Factory.Registry.INSTANCE.getContent TypeToFactoryMap());
Now all content type registrations will be considered first in this
resource set. I think reusing the same extension for a different format
is probably a bad idea though....
> Cheers,
> Mirko
> editing domain that loads my textual ecore models.
Re: Overriding the default resource factory for .ecore files [message #428528 is a reply to message #428523] |
Tue, 24 March 2009 11:54   |
Hi Ed,
Ed Merks wrote:
> Mirko,
> Comments below.
>> Hi,
> Like Emphatic...
Exactly. They use a different extension and let users convert between
the two formats (XMI vs. text), which is time-consuming when metamodels
change a lot.
>> </parser>
>> </extension>
>> </file-association>
>> </extension>
I know, but using a different extension (e.g. 'tecore') does not work
because I can't create generator models for such files. As generating
code is the most usual task that is performed on the ecore models, this
is desperately needed.
>> </content-type>
>> </extension>
> Don't do that!
Unfortunately I do not have access to the resourceSet. It is hidden
somewhere in the EMF code generation classes.
Do you have any other idea/comment?
Mirko
Re: Overriding the default resource factory for .ecore files [message #428531 is a reply to message #428528] |
Tue, 24 March 2009 12:47   |
Mirko,
comments below.
> Hi Ed,
> Ed Merks wrote:
>> Mirko,
>> Comments below.
>>> Hi,
>> Like Emphatic...
> metamodels change a lot.
Yes, it's a pain to sync them manually.
>>> </parser>
>>> </extension>
>>> </file-association>
>>> </extension>
I know the file dialog makes it hard and the workspace dialog only shows
matching extension, but I'm pretty sure you could enter a URI with any
extension...
> As generating code is the most usual task that is performed on the
> ecore models, this is desperately needed.
It's worth trying to enter URIs with different extension manually and
see how much of all this will "just works". Maybe all of it.
>>> </content-type>
>>> </extension>
>>> resource factory (CustomizedEcoreResourceFactory), but the default
>>> factory (EcoreResourceFactoryImpl), which fails.
>>> works, but this is somewhat ugly:
>> Don't do that!
I see that now.
>> format is probably a bad idea though....
I think it's mostly a problem that the dialogs are too smart about
encouraging the use of a known extension. Try it and let me know...
> Mirko
Re: Overriding the default resource factory for .ecore files [message #428600 is a reply to message #428531] |
Wed, 25 March 2009 06:29   |
Hi Ed,
as it seems that my problem boils down to getting the EMF generator
model wizard accept files other than '.ecore' I'll shorten the previous
discussion a little.
I followed your suggestion, used a different extension (.tecore) and
directly entered a URI to my textual Ecore model
(/projectname/new.tecore), which is then indeed loaded by the wizard.
However, after clicking "Next" the wizard correctly shows the packages
defined in new.tecore, but complains "The Ecore model file name for
package 'someEPackageName' must end in '.ecore' or '.emof'". So I can't
continue.
Maybe there is a way to tell the wizard to accept other extensions?
Mirko
Ed Merks schrieb:
> Mirko,
> comments below.
>> Hi Ed,
>> Ed Merks wrote:
>>> Mirko,
>>> Comments below.
>>>> Hi,
> extension...
>> Thanks,
>> Mirko
Re: Overriding the default resource factory for .ecore files [message #428607 is a reply to message #428600] |
Wed, 25 March 2009 07:58   |
Mirko,
We probably should be more forgiving but I suppose if we wanted to get
fancy, we'd have an extension point that would allow one to specify
additional extensions for resource types that will transparently be
treated as containing Ecore models during import. I'd certainly be
willing to entertain that, but I'll need help with verifying that the
design works for you, and I'm not at my most productive best these days
for personal reasons. Are you developing against 2.5. Will this help?
> Hi Ed,
> previous discussion a little.
> can't continue.
> Cheers,
> Mirko
> Ed Merks schrieb:
>> Mirko,
>> comments below.
>>> Hi Ed,
>>> Ed Merks wrote:
>>>> Mirko,
>>>> Comments below.
>>>>> Hi,
>>> work because I can't create generator models for such files.
>> shows matching extension, but I'm pretty sure you could enter a URI
>> with any extension...
>>> Thanks,
>>> Mirko
Re: Overriding the default resource factory for .ecore files [message #428648 is a reply to message #428607] |
Wed, 25 March 2009 16:23   |
Hi Ed,
I think adding such an extension point could certainly solve the problem
at hand. I currently build against EMF 2.4.2, but could use 2.5 as well.
I'm also willing to verify and support the design of the feature.
However, before we start to do so I'd like to go back one step and bring
up the discussion about the extension parsers and the content parsers
again. I'm sorry, because you might be tired of that discussion, but I
just want to understand this more deeply:
I'm aware that you do not want to change the priorities to make sure
existing clients still get the behavior they expect. I agree with that.
But, for a second let's suppose the EcoreResourceFactoryImpl would not
be registered as extension parser, but as content parser. What are the
implications?
I think functionally it would be the same, because all Ecore files saved
as XMI could still be loaded. Non-functionally (in terms of performance)
there would obviously be a difference, because the content parser needs
to have a look into every '.ecore' file to decide whether it is an XMI
file or not. However, this happens only when files change and it
requires looking at the first (four?) bytes in the file only (to check
whether the XMI header is there). The question is, whether this is
really significant for a reasonable number of .ecore files in a
workspace. Am I missing something here?
Since EMF provides this powerful content parsing extension point that
allows to save different content types in files with the same extension
then why should we not make use of it for ecore itself.
Again, sorry for bringing this up again, but I want to make sure that we
are not adding something here that solves only the (small) problem with
the generator model wizard, but is actually about something else. Other
tools might also ask for .ecore files and face the same problem.
Mirko
Ed Merks wrote:
> Mirko,
>> Hi Ed,
>> can't continue.
>> Cheers,
>> Mirko
>> Ed Merks schrieb:
>>> Mirko,
>>> comments below.
>>>> Hi Ed,
>>>> Ed Merks wrote:
>>>>> Mirko,
>>>>> Comments below.
>>>>>> Hi,
>>>> Thanks,
>>>> Mirko
Re: Overriding the default resource factory for .ecore files [message #428656 is a reply to message #428648] |
Wed, 25 March 2009 19:39   |
Mirko,
Comments below.
> Hi Ed,
> problem at hand. I currently build against EMF 2.4.2, but could use
> 2.5 as well. I'm also willing to verify and support the design of the
> feature.
> bring up the discussion about the extension parsers and the content
> parsers again. I'm sorry, because you might be tired of that
> discussion, but I just want to understand this more deeply:
> implications?
The file has to be opened and analyzed to be sure that it's really XML
content with a root element from the Ecore namespace; and expense not
incurred in the past.
> saved as XMI could still be loaded.
People care about more than function, they also care about performance.
> Non-functionally (in terms of performance) there would obviously be a
> difference, because the content parser needs to have a look into every
> '.ecore' file to decide whether it is an XMI file or not.
Indeed.
> However, this happens only when files change and it requires looking
> at the first (four?) bytes in the file only (to check whether the XMI
> header is there).
No, it has to look at the namespace of the root element. Outside of the
workspace, this information isn't cached and certainly isn't free to
compute.
> The question is, whether this is really significant for a reasonable
> number of .ecore files in a workspace. Am I missing something here?
It's indeed a question and I'll assure you that it's significant
compared to syntactically matching an extension on a URI. IO verses a
simple syntactic check...
> extension then why should we not make use of it for ecore itself.
From a content type point fo view, one could imagine specifying Ecore
content, but the hiearchy for text content verses XML content would be
parallel and content type hierarchies don't support multiple inheritance...
> we are not adding something here that solves only the (small) problem
> with the generator model wizard, but is actually about something else.
> Other tools might also ask for .ecore files and face the same problem.
Content types are all fine and cool, but I'm always taken aback by how
poorly the overall concepts are considered. Imagine 1000 parsers all
looking at the same *.xml file to decide if it's content they
recognized. Each one duplicates an full XML parse of the start of the
file. Does that really scale well? I imagine not.
> Cheers,
> Mirko
> Ed Merks wrote:
>> Mirko,
>> get fancy, we'd have an extension point that would allow one to
>> specify additional extensions for resource types that will
>> transparently be treated as containing Ecore models during import.
>> I'd certainly be willing to entertain that, but I'll need help with
>> verifying that the design works for you, and I'm not at my most
>> productive best these days for personal reasons. Are you developing
>>> Hi Ed,
>>> wizard. However, after clicking "Next" the wizard correctly shows
>>> the packages defined in new.tecore, but complains "The Ecore model
>>> file name for package 'someEPackageName' must end in '.ecore' or
>>> '.emof'". So I can't continue.
>>> Cheers,
>>> Mirko
>>> Ed Merks schrieb:
>>>> Mirko,
>>>> comments below.
>>>>> Hi Ed,
>>>>> Ed Merks wrote:
>>>>>> Mirko,
>>>>>> Comments below.
>>>>>>> Hi,
>>>>>>> loads Ecore files represented in a text syntax rather than XMI.
>>>> and see how much of all this will "just works". Maybe all of it.
>>>>>> this resource set. I think reusing the same extension for a
>>>>>> different format is probably a bad idea though....
>>>>> Thanks,
>>>>> Mirko
Re: Overriding the default resource factory for .ecore files [message #428664 is a reply to message #428656] |
Thu, 26 March 2009 04:58   |
Hi Ed,
thanks for explaining the implications. I'm convinced now that added the
extension point is the better choice.
I'll set up a workspace with the current head revision of EMF and try to
come up with an initial patch. Shall we track this in bugzilla rather
than the newsgroup?
Mirko
Ed Merks schrieb:
> Mirko,
> Comments below.
>> Hi Ed,
>> feature.
>> implications?
> Indeed.
>> header is there).
> compute.
>> Cheers,
>> Mirko
>> Ed Merks wrote:
>>> Mirko,
>>>> Hi Ed,
>>>> Cheers,
>>>> Mirko
>>>> Ed Merks schrieb:
>>>>> Mirko,
>>>>> comments below.
>>>>>> Hi Ed,
>>>>>> Ed Merks wrote:
>>>>>>> Mirko,
>>>>>>> Comments below.
>>>>>>>> Hi,
>>>>>> Thanks,
>>>>>> Mirko
Re: Overriding the default resource factory for .ecore files [message #428666 is a reply to message #428665] |
Thu, 26 March 2009 06:13   |
> thanks for the information. We ran into the same problems and solved them
> in similar way.
> I was wondering why you need an additional meta model (the EmfaticMM). We
> do directly create an instance of the EcoreMM. Could you explain that a
> little?
On the assumption that it would minimise development effort, we used
existing tools for the m2m (ATL), and t2m and m2t (both TCS)
transformations.
For TCS we found there were a few places in the Emfatic syntax were
we did not want to directly use the EcoreMM. These mainly occurred were
a collection of items are allowed. For example, the declarations within a
package. These can be subpackages, or classifiers and the EcoreMM
has separate attributes for both. With TCS, syntactically the values for two
attributes must be separated, so all subpackages would have to occur
before all classifiers (or visa versa). To allow them to be intermixed, we
needed a single attribute; hence, a different MM. We also had a change
for modifiers so that they could be used in any order. The differences
between the EmfaticMM and the EcoreMM are very slight and the m2m
transformations are almost 1:1. Had we been able to use the EcoreMM,
we would not have needed the m2m transformations.
Andy.
Re: Overriding the default resource factory for .ecore files [message #428667 is a reply to message #428664] |
Thu, 26 March 2009 07:29  |
Mirko,
Bugzilla is the best place to share patches.
> Hi Ed,
> the extension point is the better choice.
> to come up with an initial patch. Shall we track this in bugzilla
> rather than the newsgroup?
> Cheers,
> Mirko
> Ed Merks schrieb:
>> Mirko,
>> Comments below.
>>> Hi Ed,
>>> the feature.
>>> not be registered as extension parser, but as content parser. What
>>> are the implications?
>> XML content with a root element from the Ecore namespace; and expense
>> not incurred in the past.
>>> a difference, because the content parser needs to have a look into
>>> every '.ecore' file to decide whether it is an XMI file or not.
>> Indeed.
>> the workspace, this information isn't cached and certainly isn't free
>> to compute.
>> a simple syntactic check...
>>> that allows to save different content types in files with the same
>> Ecore content, but the hiearchy for text content verses XML content
>> would be parallel and content type hierarchies don't support multiple
>> inheritance...
>>> that we are not adding something here that solves only the (small)
>>> problem with the generator model wizard, but is actually about
>>> something else. Other tools might also ask for .ecore files and face
>>> the same problem.
>> how poorly the overall concepts are considered. Imagine 1000 parsers
>> all looking at the same *.xml file to decide if it's content they
>> the file. Does that really scale well? I imagine not.
>>> Cheers,
>>> Mirko
>>> Ed Merks wrote:
>>>> Mirko,
>>>> import. I'd certainly be willing to entertain that, but I'll need
>>>> help with verifying that the design works for you, and I'm not at
>>>> my most productive best these days for personal reasons. Are you
>>>>> Hi Ed,
>>>>> generator model wizard accept files other than '.ecore' I'll
>>>>> shorten the previous discussion a little.
>>>>> and directly entered a URI to my textual Ecore model
>>>>> Cheers,
>>>>> Mirko
>>>>> Ed Merks schrieb:
>>>>>> Mirko,
>>>>>> comments below.
>>>>>>> Hi Ed,
>>>>>>> Ed Merks wrote:
>>>>>>>> Mirko,
>>>>>>>> Comments below.
>>>>>>>>> Hi,
>>>>>> only shows matching extension, but I'm pretty sure you could
>>>>>> enter a URI with any extension...
>>>>>>> the ecore models, this is desperately needed.
>>>>>> about encouraging the use of a known extension. Try it and let
>>>>>> me know...
>>>>>>> Thanks,
>>>>>>> Mirko
Current Time: Sun Jul 20 07:52:20 EDT 2025
Powered by FUDForum. Page generated in 0.05716 seconds
