The carriage-return (#xD) character saved as "
\r" [message #427929] |
Fri, 06 March 2009 05:28  |
Hello!
When I save resource using Default XML serialization and in that
resource some element with value e.g. "Hello\r\nWorld!" is contained, I
get XML like that: "Hello
\r\n". I know that
 is XML entity
representin Unicode character for CR, but why it's saved twice as xml
entity and as '\r' char? Can you clarify this point: how actually save
CR character correctly?
Thank you,
Alexey
Re: The carriage-return (#xD) character saved as "
\r" [message #427951 is a reply to message #427949] |
Fri, 06 March 2009 08:50   |
--------------010401000603070907050808
Alexey,
Comments below.
koloale wrote:
> Ed Merks wrote:
>> Guys,
>> I think if you see \r or \n in the serialization it's because you
>> have the two characters \ followed r or n in the string itself. I
>> can't imagine that serialization would ever convert a character into
>> a Java escape sequence. Some other aspect of the logic (not the
>> serialization log) must be doing that...
> Ed, what do mean by 'some other aspect of the logic must be doing that'?
> My code is:
> EObject config = EcoreUtil.create(someClass);
> config .eSet(ref, "Hello\r\nWorld");
> Resource resource = ;
> resource .getContents().add(config);
> ByteArrayOutputStream os = new ByteArrayOutputStream();
> resource.save(os, null);
> assertEquals("Hello
\r\nWorld", os.toString());
> So I think it is XMLResourceImpl that convert \r to
Well yes. Tom already mentioned that and why. If it didn't do that,
what you'd get back when reading it would be the value "Hello\nWorld"
because any XML parser will convert the system's line feed convention to
"\n". The serializer is written so it preserves *exactly *the sequence
of characters you specified. (I thought when you said \r\n you
literally meant those two letter escape sequence appeared in the XML file...
> Alexey
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Alexey,<br>
<br>
Comments below.<br>
<br>
koloale wrote:
<blockquote cite="mid:gor856$qmp$1@build.eclipse.org" type="cite">Ed
Merks wrote:
<br>
<blockquote type="cite">Guys,
<br>
<br>
I think if you see \r or \n in the serialization it's because you have
the two characters \ followed r or n in the string itself. I can't
imagine that serialization would ever convert a character into a Java
escape sequence. Some other aspect of the logic (not the serialization
<br>
</blockquote>
that'?
<br>
My code is:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
assertEquals("Hello&#xD;\r\nWorld", os.toString());
<br>
<br>
So I think it is XMLResourceImpl that convert \r to &#xD;
<br>
</blockquote>
to "\n". The serializer is written so it preserves <b>exactly </b>the
sequence of characters you specified. (I thought when you said \r\n
you literally meant those two letter escape sequence appeared in the
XML file...<br>
<blockquote cite="mid:gor856$qmp$1@build.eclipse.org" type="cite"><br>
Alexey
<br>
</blockquote>
</body>
</html>
--------------010401000603070907050808--
\r" [message #427960 is a reply to message #427933] |
Fri, 06 March 2009 13:57  |
I imagine the reason the \r still shows up is because the save()
function will turn \n into the current platform's new line characters,
which on windows is \r\n.
So first it was turned into "
\n" by the XML serialization and then
the function turned that last remaining \n into \r\n because that is the
current platform's new line characters.
Rich Kulp
FUDForum. Page generated in 0.04480 seconds
