Home » Modeling » EMF » "Resolve Proxies" property
"Resolve Proxies" property [message #427623] Tue, 24 February 2009 12:12 Go to next message
What exactly does "Resolve Proxies" property mean for a reference?
I thought that this simply means that on a get call the object won't be
resolved automatically by EMF generated code and you have to resolve it
manually.
Recently, I heard a different interpretation of "Resolve Proxies".
If "Resolve Proxies" is false this means that the reference is never
expected to be a proxy. True means that proxy objects can be referenced.
Which one of these is true?
Thanks!
Alex
Re: "Resolve Proxies" property [message #427626 is a reply to message #427623] Tue, 24 February 2009 12:45 Go to previous messageGo to next message
Alex,
Comments below.
Alex Boyko wrote:
Didn't you buy the EMF book? :-P
> be resolved automatically by EMF generated code and you have to
> resolve it manually.
Yes, it definitely won't automatically be resolved.
They both sound true to me. If your expecting proxies you ought to have
generated logic for resolving them. Of course you can choose not to
have such logic though you could tell your clients that it's up to them
to resolve proxies, but that seems strange. So generally it's better to
think of a proxy resolving reference as one that supports cross document
references while references that don't support proxy resolution should
be thought of as being restricted to reside with the same resource.
> Thanks!
> Cheers,
> Alex
Re: "Resolve Proxies" property [message #427664 is a reply to message #427626] Wed, 25 February 2009 10:15 Go to previous messageGo to next message
Hi Ed,
One problem that we are noticing with this is that the resolveProxy()
mechanism in the ECrossReferenceAdapter doesn't work in the case where a
feature is set to resolveAll=false, is single valued, the value is a
proxy, and both resources are loaded. The reason for this is that the
call to setting.eGet(true) does not force the proxy to be resolved,
which is required in order for the reverse reference lookup to succeed
in finding this particular referencer.
Does this mean that the ECrossReferenceAdapter needs to be fixed? Or
perhaps is this an indication that EMF doesn't really support a feature
with resolveAll=false but at the same time have cross-resource
references? If so, maybe there should be some sort of a warning logged
when an EObject has a cross-resource reference in such a feature?
Chris
Re: "Resolve Proxies" property [message #427671 is a reply to message #427664] Wed, 25 February 2009 11:10 Go to previous messageGo to next message
Chris,
Comments below.
Chris McGee wrote:
> Hi Ed,
> a feature is set to resolveAll=false, is single valued, the value is a
When proxy resolve is off for a feature it really ought not to contain a
proxy and if it does you ought not to expect it to be resolve
automatically. Note also my comments about cross document references so
the fact that you're talking about "both resources" sound to me like a
case where proxy resolve ought to be true.
> feature with resolveAll=false but at the same time have cross-resource
> references?
Yes I believe that's what I've said in my previous reply.
> If so, maybe there should be some sort of a warning logged when an
Some resource implementations (perhaps repository backed ones backed by
CDO) might not even use proxies so I'm not so sure about producing
warnings about it when validating.
> Chris
Re: "Resolve Proxies" property [message #427823 is a reply to message #427671] Mon, 02 March 2009 09:11 Go to previous messageGo to next message
Hi Ed,
Thanks for the information.
Maybe this property should be renamed to avoid confusion? I was thinking
that there should be more emphasis on the proxy than on the resolution.
Something like "canContainProxies" perhaps?
Chris
Re: "Resolve Proxies" property [message #427825 is a reply to message #427823] Mon, 02 March 2009 09:33 Go to previous messageGo to next message
Chris,
Rename something that's been in its current form for 7 years and is
documented this way in the just-published book and refcard? There's an
idea! :-P
Chris McGee wrote:
> Hi Ed,
> thinking that there should be more emphasis on the proxy than on the
> resolution. Something like "canContainProxies" perhaps?
> Chris
Re: "Resolve Proxies" property [message #427827 is a reply to message #427825] Mon, 02 March 2009 09:42 Go to previous message
True :-)
But I've seen this property misused about two or three times over the
years and often after the schema has been published and there's little
that can be done about it.
That's why I was thinking that a logged warning somewhere would help
someone to discover their mistake earlier. Of course, they should have
read the book but many do not take the time. :-)
Chris
Ed Merks wrote:
> Chris,
> idea! :-P
> Chris McGee wrote:
>> Hi Ed,
>> Chris
Previous Topic:Get the markup name associated with an EObject
Next Topic:User-friendly GUI to instantiate EMF classes
Current Time: Sat Jul 19 14:51:12 EDT 2025
Powered by FUDForum. Page generated in 0.09117 seconds
