Home » Modeling » EMF » Re: modelling associations
Re: modelling associations [message #427595] Mon, 23 February 2009 17:00 Go to next message
Hi RJ,
There is no more detailed article available then what is available on elver.org or the hibernate manual (or posts on the
newsgroup).
In this case there is a many-to-many present in the mapping, but it has the special attribute unique="true", which means
it is in fact a one-to-many. A OneToMany annotation can still be mapped with a many-to-many in hbm (as long as it has
unique="true"). See these parts of the hibernate manual:
http://www.hibernate.org/hib_docs/reference/en/html/assoc-un idirectional-join.html
http://www.hibernate.org/hib_docs/reference/en/html/assoc-bi directional-join.html
Note that support for Teneo is given on the EMF newsgroup which I cc-ed.
gr. Martin
RJDAG wrote:
> Hello
> I am new to Teneo and Emf.
> The modeling associations article on the elever website did give me some
> overview. (http://www.elver.org/hibernate/hibernate_relations.html) But Is
> there a more detailed article available anywhere?
> I am working with the library example
> I am trying to map the Writer to books relationshp as OneToMany
> relationship.
> <eStructuralFeatures xsi:type="ecore:EReference" name="books"
> upperBound="-1"
> eType="#//Book" eOpposite="#//Book/author">
> <eAnnotations source="teneo.jpa">
> <details key="appinfo" value="@OneToMany(mappedBy=&quot;author&quot;,
> indexed=false)"/>
> </eAnnotations>
> </eStructuralFeatures>
> But the mapping generated is always of type many-to-many.
> What am I doing wrong?
> Thanks
> RJ
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: modelling associations [message #427600 is a reply to message #427595] Mon, 23 February 2009 19:10 Go to previous messageGo to next message
Thank you for the quick response.
I found the cascadenotall example on the elver website:
http://www.elver.org/hibernate/ejb3_examples.html
I wish to generate an hbm like
CascadeNotallAction_mysql_a_o_hibernate.hbm.xml but when i generate it
I get hibernate.hbm.xml.
I do not want to use the write_books table to store theWriter to books
relationship.
RJ
"Martin Taal" <mtaal@elver.org> wrote in message
news:gnv6a3$7ld$1@build.eclipse.org...
> Hi RJ,
> newsgroup).
> gr. Martin
> RJDAG wrote:
>> Hello
>> Is
>> relationship.
>> upperBound="-1"
>> indexed=false)"/>
>> </eAnnotations>
>> Thanks
>> RJ
> The Netherlands
Re: modelling associations [message #427601 is a reply to message #427600] Tue, 24 February 2009 00:17 Go to previous messageGo to next message
Hi RJ,
As a default Teneo will use join tables for non-containment relations. You can disable this by setting this persistence
option to false:
PersistenceOptions.JOIN_TABLE_FOR_NON_CONTAINED_ASSOCIATIONS
When this option is false then you can set a join table for a an association by setting the @JoinTable annotation.
As you are new to EMF, a containment relation is a parent-child relation whereby the child depends on the parent for its
existence. In the library example, a writer and book are contained in a library. The writer and book relationship in
this model is non-containment.
The reason that Teneo (as a default) uses join tables for non-containment relations is that this is safer (less change
on name clashes) when having very complex models with multiple inheritance.
gr. Martin
> relationship.
> Thanks
> RJ
>> Hi RJ,
>> newsgroup).
>> gr. Martin
>> RJDAG wrote:
>>> Hello
>>> Is
>>> relationship.
>>> upperBound="-1"
>>> indexed=false)"/>
>>> </eAnnotations>
>>> Thanks
>>> RJ
>> The Netherlands
The Netherlands
Re: modelling associations [message #427627 is a reply to message #427601] Tue, 24 February 2009 14:04 Go to previous message
Thanks a lot , that was very helpful.
news:gnvvt8$2nq$1@build.eclipse.org...
> Hi RJ,
> can disable this by setting this persistence option to false:
> whereby the child depends on the parent for its existence. In the library
> relationship in this model is non-containment.
> relations is that this is safer (less change on name clashes) when having
> gr. Martin
>> relationship.
>> Thanks
>> RJ
>>> Hi RJ,
>>> newsgroup).
>>> gr. Martin
>>> RJDAG wrote:
>>>> Hello
>>>> some
>>>> Is
>>>> relationship.
>>>> upperBound="-1"
>>>> indexed=false)"/>
>>>> </eAnnotations>
>>>> Thanks
>>>> RJ
>>> The Netherlands
> The Netherlands
Previous Topic:EMF validation with OCL in MetaModel
Next Topic:How to create custom constructors of model objects ?
Current Time: Sun Jul 20 02:39:55 EDT 2025
Powered by FUDForum. Page generated in 0.03647 seconds
