Home » Modeling » EMF » Re: modelling associations
Re: modelling associations [message #427595] |
Mon, 23 February 2009 17:00  |
Hi RJ,
There is no more detailed article available then what is available on elver.org or the hibernate manual (or posts on the
newsgroup).
In this case there is a many-to-many present in the mapping, but it has the special attribute unique="true", which means
it is in fact a one-to-many. A OneToMany annotation can still be mapped with a many-to-many in hbm (as long as it has
unique="true"). See these parts of the hibernate manual:
http://www.hibernate.org/hib_docs/reference/en/html/assoc-un idirectional-join.html
http://www.hibernate.org/hib_docs/reference/en/html/assoc-bi directional-join.html
Note that support for Teneo is given on the EMF newsgroup which I cc-ed.
gr. Martin
RJDAG wrote:
> Hello
> I am new to Teneo and Emf.
> The modeling associations article on the elever website did give me some
> overview. (http://www.elver.org/hibernate/hibernate_relations.html) But Is
> there a more detailed article available anywhere?
> I am working with the library example
> I am trying to map the Writer to books relationshp as OneToMany
> relationship.
> <eStructuralFeatures xsi:type="ecore:EReference" name="books"
> upperBound="-1"
> eType="#//Book" eOpposite="#//Book/author">
> <eAnnotations source="teneo.jpa">
> <details key="appinfo" value="@OneToMany(mappedBy="author",
> indexed=false)"/>
> </eAnnotations>
> </eStructuralFeatures>
> But the mapping generated is always of type many-to-many.
> What am I doing wrong?
> Thanks
> RJ
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: modelling associations [message #427601 is a reply to message #427600] |
Tue, 24 February 2009 00:17   |
Hi RJ,
As a default Teneo will use join tables for non-containment relations. You can disable this by setting this persistence
option to false:
PersistenceOptions.JOIN_TABLE_FOR_NON_CONTAINED_ASSOCIATIONS
When this option is false then you can set a join table for a an association by setting the @JoinTable annotation.
As you are new to EMF, a containment relation is a parent-child relation whereby the child depends on the parent for its
existence. In the library example, a writer and book are contained in a library. The writer and book relationship in
this model is non-containment.
The reason that Teneo (as a default) uses join tables for non-containment relations is that this is safer (less change
on name clashes) when having very complex models with multiple inheritance.
gr. Martin
RJDAG wrote:
> Thank you for the quick response.
> I found the cascadenotall example on the elver website:
> http://www.elver.org/hibernate/ejb3_examples.html
> I wish to generate an hbm like
> CascadeNotallAction_mysql_a_o_hibernate.hbm.xml but when i generate it
> I get hibernate.hbm.xml.
> I do not want to use the write_books table to store theWriter to books
> relationship.
> Thanks
> RJ
> "Martin Taal" <mtaal@elver.org> wrote in message
> news:gnv6a3$7ld$1@build.eclipse.org...
>> Hi RJ,
>> newsgroup).
>> gr. Martin
>> RJDAG wrote:
>>> Hello
>>> Is
>>> relationship.
>>> upperBound="-1"
>>> indexed=false)"/>
>>> </eAnnotations>
>>> Thanks
>>> RJ
>> The Netherlands
The Netherlands
Re: modelling associations [message #427627 is a reply to message #427601] |
Tue, 24 February 2009 14:04  |
Thanks a lot , that was very helpful.
news:gnvvt8$2nq$1@build.eclipse.org...
> Hi RJ,
> can disable this by setting this persistence option to false:
> whereby the child depends on the parent for its existence. In the library
> relationship in this model is non-containment.
> relations is that this is safer (less change on name clashes) when having
> gr. Martin
>> relationship.
>> Thanks
>> RJ
>>> Hi RJ,
>>> newsgroup).
>>> gr. Martin
>>> RJDAG wrote:
>>>> Hello
>>>> some
>>>> Is
>>>> relationship.
>>>> upperBound="-1"
>>>> indexed=false)"/>
>>>> </eAnnotations>
>>>> Thanks
>>>> RJ
>>> The Netherlands
> The Netherlands
Current Time: Sat Jul 19 14:00:14 EDT 2025
Powered by FUDForum. Page generated in 0.08546 seconds
