Teneo/Hibernate NonUniqueObjectException resolving [message #427492] |
Thu, 19 February 2009 10:42  |
I have next method:
public static Serializable getId(Session session, Object object) {
Serializable id = null;
try {
session.lock(object, LockMode.NONE);
id = session.getIdentifier(object);
} catch (NonUniqueObjectException e) {
throw new RuntimeException(e);
} catch (TransientObjectException e2) {
id = session.save(object);
return id;
I want to change catcher for NonUniqueObjectException to return valid
value, not just chain exception on top level. I have to return my object's
id:
id = object.getId();
But as I understand Teneo adds id field dynamically, and I don't have it
in EMF model, so I cannot access it in a regular way. How can I get id of
my object in this situation?
Re: Teneo/Hibernate NonUniqueObjectException resolving [message #427519 is a reply to message #427492] |
Thu, 19 February 2009 14:42   |
Hi Mikhail,
For virtual/synthetic id's Teneo keeps the Id's in a separate cache. So you can also do this:
Serializable id = (Serializable) IdentifierCacheHandler.getInstance().getID(object);
Note that for live/production software it is recommended to have a real id-attribute and not to use synthetic id's.
gr. Martin
Mikhail Kadan wrote:
> I have next method:
> try {
> return id;
> object's id:
> of my object in this situation?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo/Hibernate NonUniqueObjectException resolving [message #427525 is a reply to message #427524] |
Fri, 20 February 2009 02:51  |
Hi Mikhail,
It depends a bit on your specific case. The main thing is that the synthetic id will not work if you serialize and
deserialize objects. As the Teneo synthetic id works using weak references and object equality.
Before we had some problems with memory leaks in the synthetic id part but that is solved.
And as a last remark overall I find it easier if the id of the object travels with the object itself. (but that's just
my personal opinion)
So if you don't serialize/deserialize then there are no obstacles in using synthetic id's.
Note that next to the synthetic id there is also the synthetic version which is kept behind the scenes if you don't have
an explicit version eattribute.
gr. Martin
> Can you explain this part a bit more? Why it is not recommended to use
> synthetic id's? Or maybe you can give a link which explains this?
> Thanks.
The Netherlands
FUDForum. Page generated in 0.03168 seconds
