Home » Modeling » EMF » Problem creating XML model with model editor
Problem creating XML model with model editor [message #427352] Fri, 13 February 2009 06:15 Go to next message
I have created an Eclipse EMF model from a XSD file (concretely from XML
Schema of SCXML).
I generated the editor, and when I use it, the file created doesn't
conform tho the metamodel. It puts scxml: before each model element. The
file looks like:
<scxml:scxml xmlns:scxml="http://www.w3.org/2005/07/scxml"
initialstate="idle">
<scxml:state id="on">
<scxml:transition/>
<scxml:transition/>
</scxml:state>
<scxml:state id="off">
<scxml:transition/>
</scxml:state>
<scxml:state id="idle">
<scxml:transition/>
</scxml:state>
</scxml:scxml>
instead of looking like that:
<scxml xmlns="http://www.w3.org/2005/07/scxml" initialstate="idle">
<state id="on">
<transition/>
<transition/>
</state>
<state"off">
<transition/>
</state>
</scxml>
Does anybody know what could I do to solve this problem?
Re: Problem creating XML model with model editor [message #427356 is a reply to message #427352] Fri, 13 February 2009 09:46 Go to previous messageGo to next message
Ander,
Comments below.
Ander Zubizarreta wrote:
> Hello,
> Schema of SCXML).
> file looks like:
> <scxml:transition/>
> <scxml:transition/>
> </scxml:state>
> <scxml:transition/>
> </scxml:state>
> <scxml:transition/>
> </scxml:state>
> </scxml:scxml>
> <state id="on">
> <transition/>
> <transition/>
> </state>
> <state"off">
> <transition/>
> </state>
> </scxml>
These two serializations are 100% equivalent so both are presumably
correct. You can control the prefix with
documentRoot.getXMLNSPrefixMap().put("", SCXMLPackage.eNS_URI)...
Re: Problem creating XML model with model editor [message #427358 is a reply to message #427356] Fri, 13 February 2009 10:40 Go to previous messageGo to next message
Ok, how could I do that, if I am creating the model with the wizard?
Ander
Ed Merks wrote:
> Ander,
> Comments below.
>> Hello,
>> Schema of SCXML).
>> file looks like:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <scxml:transition/>
>> <scxml:transition/>
>> </scxml:state>
>> <scxml:transition/>
>> </scxml:state>
>> <scxml:transition/>
>> </scxml:state>
>> </scxml:scxml>
>> <state id="on">
>> <transition/>
>> <transition/>
>> </state>
>> <state"off">
>> <transition/>
>> </state>
>> </scxml>
Re: Problem creating XML model with model editor [message #427363 is a reply to message #427358] Fri, 13 February 2009 15:57 Go to previous message
Ander,
If you look in the wizard, you'll see where it creates the document root
and the root element. You could specialize that. Of course you'll want
to change it to not do it reflectively. Probably more like what you see
in SCXMLExample.java that's in the *.tests project when you invoke
generate test code.
> Ander
> Ed Merks wrote:
>> Ander,
>> Comments below.
>>> Hello,
>>> XML
>>> Schema of SCXML).
>>> The
>>> file looks like:
>>> <scxml:transition/>
>>> <scxml:transition/>
>>> </scxml:state>
>>> <scxml:transition/>
>>> </scxml:state>
>>> <scxml:transition/>
>>> </scxml:state>
>>> </scxml:scxml>
>>> <state id="on">
>>> <transition/>
>>> <transition/>
>>> </state>
>>> <state"off">
>>> <transition/>
>>> </state>
>>> </scxml>
Previous Topic:XMI serialization of data type to external file and CDO
Next Topic:Coding Practices: auto-renaming children
Current Time: Sun Jul 20 07:13:54 EDT 2025
Powered by FUDForum. Page generated in 0.03773 seconds
