Home » Modeling » EMF » [CDO] Explicit Locking feature.
[CDO] Explicit Locking feature. [message #427335] Thu, 12 February 2009 09:03 Go to next message
I tested the "write lock" feature.
Does an API exist to check if an object is already locked (who (cdo
session ?) owns the lock, which lock type,...) ?
What is the purpose of the "read lock" ? I did not see the difference
with a write lock ...
Stephane.
Re: [CDO] Explicit Locking feature. [message #427337 is a reply to message #427335] Thu, 12 February 2009 09:58 Go to previous messageGo to next message
Stéphane,
in org.eclipse.emf.cdo.CDOObject you have:
* Returns the read lock associated with this object.
* @return Never <code>null</code>.
* @since 2.0
public CDOLock cdoReadLock();
* Returns the write lock associated with this object.
* @since 2.0
public CDOLock cdoWriteLock();
I believe there is nothing that specifies "who owns the lock".
In org.eclipse.emf.cdo.view.CDOView you also have:
* Reloads the given {@link CDOObject objects} from the repository.
public int reload(CDOObject... objects);
public void lockObjects(Collection<? extends CDOObject> objects,
RWLockManager.LockType lockType, long timeout)
throws InterruptedException;
* Unlocks the given locked objects of this view.
public void unlockObjects(Collection<? extends CDOObject> objects,
RWLockManager.LockType lockType);
* Unlocks all locked objects of this view.
* @since 2.0
public void unlockObjects();
I haven't tested much that new feature. I guess a "read lock" should
avoid others to retrieve certain CDOObject from the repository. Simon
McDuff developed this feature, maybe he can clarify better what is this
kind of lock supposed to do.
Víctor.
Re: [CDO] Explicit Locking feature. [message #427339 is a reply to message #427337] Thu, 12 February 2009 10:16 Go to previous messageGo to next message
Hi Stephane,
The difference between read and lock is the following:
- Many Read locks could happen at the same time (From different views)
- cdoWriteLock is successful only if they have no readlock and nowriteLock
- cdoWriteLock could only happen from the same views.
- If a clientA modify objectA and clientB have a readLock on it... the
commit of clientA will fail. Since the commit manager will automatically
writeLock every Dirty Objects.
Is that help you Stephane ?
Re: [CDO] Explicit Locking feature. [message #427342 is a reply to message #427339] Thu, 12 February 2009 13:02 Go to previous messageGo to next message
Simon & Victor,
Thanks for your helpful answers.
Simon, could you give me please an example of a typical usage of the
readLock.
If I clearly understood, a readLock allows its owner to avoid
modifications by another one.
Hence, multiples users reading an object can lock it to prevent other
ones to modify it while they are reading it.
The writeLock can be used to tell to other ones, the object is under
modifications.... A commit will happen...
Am I right Simon ?
Stéphane.
Simon Mc Duff wrote:
> Hi Stephane,
> - cdoWriteLock could only happen from the same views. - If a clientA
> modify objectA and clientB have a readLock on it... the commit of
Re: [CDO] Explicit Locking feature. [message #427343 is a reply to message #427342] Thu, 12 February 2009 13:42 Go to previous message
Stéphane Fournier wrote:
> Simon & Victor,
You are welcome!
> readLock.
If you want to calculates something on a bunch of objects.. and you do not
allow changes during that time..... otherwise your answer will not be
accurate. But you allo others to read them!! :-) I'm sure you can come up
with a better example.
Yes, it is exactly that.
Yes.
Yes this is one reason.
> Am I right Simon ?
Yes. Don't forget that each time you commit... the write lock is kicked-in
automatically.
> Stéphane.
>> Hi Stephane,
Previous Topic:Deploy EMF with Teneo in a servlet, ClassNotFoundException EPackage
Next Topic:CDO adding object from sub-model
Current Time: Sat Jul 19 16:40:17 EDT 2025
Powered by FUDForum. Page generated in 0.04318 seconds
