Home » Modeling » EMF » XSD to Ecore <xsd:choise> management
XSD to Ecore <xsd:choise> management [message #427267] Tue, 10 February 2009 04:19 Go to next message
Hello everyone,
I have seen a lot of posts speaking about this question, but I don't find
a solution to resolve it.
Indeed, I have in my XSD :
<xsd:choice>
<xsd:element name="element1" type="xsd:string" />
<xsd:element name="element2" type="xsd:string" />
<xsd:element name="element3" type="xsd:string" />
</xsd:choice>
but I have nothing in the ecore to manage this constraint. In in my editor
I can add the tree element in the same time, but when I validate, it find
that there is a problem as only one element must be present.
How can I resolve it?
Thx,
David.
Re: XSD to Ecore <xsd:choise> management [message #427268 is a reply to message #427267] Tue, 10 February 2009 07:37 Go to previous messageGo to next message
David,
Comments below.
David wrote:
> Hello everyone,
> find a solution to resolve it.
> Indeed, I have in my XSD : <xsd:choice>
> </xsd:choice>
> editor I can add the tree element in the same time, but when I
> validate, it find that there is a problem as only one element must be
> present.
Don't add more than one element. :-P
Even if you add a constraint, the editor will still let you add/set it,
but at least it will complain when you invoke "Validate...". You can
add a constraint via an ecore:constraints="Blah" on the containing
complex type Abc. This will generate a method validateAbc_Blah in the
XyzValidator that you can use to enforce the mutual exclusiveness.
You'll still need to make specializations in the commands produced by
the AbcItemProvider. You might for example create a compound command
that unsets the other feature or you might disable the command forcing
the other feature to be unset first.
> Thx,
> David.
Re: XSD to Ecore <xsd:choise> management [message #427272 is a reply to message #427268] Tue, 10 February 2009 10:13 Go to previous messageGo to next message
Thanks for your help.
But I generate Ecore with my XSD file, and I don't have to modify my
generated Ecore. Nevertheless, I can modify the
"generateCreateChildActions" method in the generated class
XXXActionBarContributor, to set enable the adds when an other element of
the choice is present.
Thx,
David.
Re: XSD to Ecore <xsd:choise> management [message #427273 is a reply to message #427272] Tue, 10 February 2009 11:34 Go to previous messageGo to next message
David,
Comments below.
> generated Ecore.
The suggestion was to add an annotation to the XSD itself so it
generates the right Ecore and that only helps with a validation
constraint...
> Nevertheless, I can modify the "generateCreateChildActions" method in
> the generated class XXXActionBarContributor, to set enable the adds
> when an other element of the choice is present.
Yes, though it's likely easier/cleaner to do this in the individual item
provider's createCreateChildCommand...
> Thx,
> David.
Re: XSD to Ecore <xsd:choise> management [message #427291 is a reply to message #427273] Wed, 11 February 2009 04:45 Go to previous messageGo to next message
Thanks Ed,
What kind of annotations can I add to the XSD to manage my constraint?
If I modify the item provider's class CreateChildCommand, the action is
not add to the new child actions. And I would like to have the action
present in the context menu and that it is grayed.
David.
Re: XSD to Ecore <xsd:choise> management [message #427294 is a reply to message #427291] Wed, 11 February 2009 07:52 Go to previous message
--------------090403070706090109010709
David,
Comments below.
David wrote:
> Thanks Ed,
Using ecore:constraints as I suggested already:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/references/overview/EMF.Validation.html
> is not add to the new child actions. And I would like to have the
> action present in the context menu and that it is grayed.
I had something like this in mind:
protected Command createCreateChildCommand
(EditingDomain domain, EObject owner, EStructuralFeature
feature, Object value, int index, Collection<?> collection)
return
new CreateChildCommand(domain, owner, feature, value, index,
collection, this)
protected boolean prepare()
return super.prepare() && shouldItReallyBeAllowed();
> David.
<html>
<head>
http-equiv="Content-Type">
</head>
David,<br>
<br>
Comments below.<br>
<br>
<br>
David wrote:
<blockquote
cite="mid:962dc662bb5c4d7c7d4da915e8d28faf$1@www.eclipse.org"
type="cite">Thanks Ed,
<br>
<br>
<br>
</blockquote>
Previous Topic:EMF.edit: Filtering list objects in the tree
Next Topic:Metamodel Evolution
Current Time: Sat Jul 19 23:14:56 EDT 2025
Powered by FUDForum. Page generated in 0.06721 seconds
