Home » Modeling » EMF » Validation Framework
Validation Framework [message #427146] |
Wed, 04 February 2009 06:40  |
at the moment I try to work with the validation framework. I tried the
example from the tutorial and the EMF book.
But I have some problems to understand how to go into this:
if (diagnostics != null){
when we always call the function like this:
validator.validateItem_limitExceeded(eObject, null, null);
And diagnostics is always null!
And if I try to recreate everything with a new ecore model eclipse doesn't
create the packageValidator.java
And it doesn't create the code like in the example.
Thank you for your help. I am really frustrated...
Matthias
Re: Validation Framework [message #427149 is a reply to message #427146] |
Wed, 04 February 2009 07:20   |
--------------040000090402010107030507
Matthias,
Comments below.
Matthias wrote:
The validator returns true or false to indicate if something is valid.
*Optionally *it can also collect diagnostics describing the reason
something isn't valid. But in many cases, one isn't interested in the
reason, which typically is only useful to the human reader, so the
generated patterns are written to avoid producing diagnostics when they
aren't desired.
> doesn't create the packageValidator.java And it doesn't create the
Did you put any constraints in your model? If there are no constraints,
there won't be a generated validator.
> Matthias
<html>
<head>
http-equiv="Content-Type">
</head>
Matthias,<br>
<br>
Comments below.<br>
<br>
Matthias wrote:
<blockquote
cite="mid:c7e250c114a0a82335a2129e3e1e9718$1@www.eclipse.org"
type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
Re: Validation Framework [message #427150 is a reply to message #427149] |
Wed, 04 February 2009 07:48   |
Hi Ed,
thanks first! ;-)
> aren't desired.
But for output of the errors in the problems view I need this diagnostics,
or?
So how I can get the handle of the DiagnosticChain to add the errors like
in the example?
And about the other problem, I thought if I have a already modeled ecore
model, I just have to add Annotation with Source Ecore. And this is the
constraint. But now I am confused about this.
And I changed this to:
@model annotation="http://www.eclipse.org/emf/2002/Ecore
constraints='limitReached'"
Matthias
Ed Merks wrote:
> Matthias,
> Comments below.
> Matthias wrote:
>> Hi,
> aren't desired.
>> Matthias
Re: Validation Framework [message #427151 is a reply to message #427150] |
Wed, 04 February 2009 07:59   |
Matthias,
Comments below.
Matthias wrote:
> Hi Ed,
> thanks first! ;-)
>> valid. *Optionally *it can also collect diagnostics describing the
>> reason something isn't valid. But in many cases, one isn't
>> interested in the reason, which typically is only useful to the human
>> reader, so the generated patterns are written to avoid producing
>> diagnostics when they aren't desired.
> diagnostics, or?
Yes.
> like in the example?
Perhaps you'd like to be more specific so I know what you're referring
to... It's up to the caller to decide to pass in something to collect
diagnostics. As the implementer of a validator, you have to handle the
case where it's null and the case where it's not.
> ecore model, I just have to add Annotation with Source Ecore. And this
> is the constraint. But now I am confused about this.
It looks right. You reloaded your model so that this actually ended up
in your *.ecore?
> Matthias
> Ed Merks wrote:
>> Matthias,
>> Comments below.
>> Matthias wrote:
>>> Hi,
>>> the example from the tutorial and the EMF book.
>> constraints, there won't be a generated validator.
>>> Matthias
Re: Validation Framework [message #427154 is a reply to message #427151] |
Wed, 04 February 2009 08:42   |
Hi Ed,
> in your *.ecore?
This was the problem, the changes wasn't in the ecore model itself.
Now it works, thanks a lot.
Matthias
Ed Merks wrote:
> Matthias,
> Comments below.
> Matthias wrote:
>> Hi Ed,
>> thanks first! ;-)
>> diagnostics, or?
> Yes.
> in your *.ecore?
>> Matthias
>> Ed Merks wrote:
>>> Matthias,
>>> Comments below.
>>> Matthias wrote:
>>>> Hi,
>>>> Matthias
Re: Validation Framework [message #427155 is a reply to message #427154] |
Wed, 04 February 2009 09:14   |
The only question no is how to start the validation with a button.
I have a button as a extension and I can run my own classes with this
button, but not the validation process "validateAction".
Any ideas?
Matthias
Matthias wrote:
> Hi Ed,
>> in your *.ecore?
> Matthias
> Ed Merks wrote:
>> Matthias,
>> Comments below.
>> Matthias wrote:
>>> Hi Ed,
>>> thanks first! ;-)
>>> diagnostics, or?
>> Yes.
>> in your *.ecore?
>>> Matthias
>>> Ed Merks wrote:
>>>> Matthias,
>>>> Comments below.
>>>> Matthias wrote:
>>>>> Hi,
>>>>> Matthias
Re: Validation Framework [message #427156 is a reply to message #427155] |
Wed, 04 February 2009 09:23  |
Matthias,
It's done by ValidateAction. (Ctrl-Shift-T is very handy if you aren't
using it yet.)
> Any ideas?
> Thanks
> Matthias
> Matthias wrote:
>> Hi Ed,
>>> up in your *.ecore?
>> Matthias
>> Ed Merks wrote:
>>> Matthias,
>>> Comments below.
>>> Matthias wrote:
>>>> Hi Ed,
>>>> thanks first! ;-)
>>>>> the reason something isn't valid. But in many cases, one isn't
>>>>> human reader, so the generated patterns are written to avoid
>>>>> producing diagnostics when they aren't desired.
>>>> diagnostics, or?
>>> Yes.
>>>> errors like in the example?
>>> referring to... It's up to the caller to decide to pass in
>>> something to collect diagnostics. As the implementer of a
>>> validator, you have to handle the case where it's null and the case
>>> where it's not.
>>>> this is the constraint. But now I am confused about this.
>>> up in your *.ecore?
>>>> Matthias
>>>> Ed Merks wrote:
>>>>> Matthias,
>>>>> Comments below.
>>>>> Matthias wrote:
>>>>>> Hi,
>>>>>> tried the example from the tutorial and the EMF book.
>>>>>> eclipse doesn't create the packageValidator.java And it doesn't
>>>>>> Matthias
Current Time: Sat Jul 19 05:48:57 EDT 2025
Powered by FUDForum. Page generated in 0.04613 seconds
