Home » Modeling » EMF » Ecore2Java Generation task
Ecore2Java Generation task [message #427112] Mon, 02 February 2009 10:46 Go to next message
Hi there,
I am using an ant script to generate the java code from an ecore model but
the model, edit and editor projects have dependencies issues.
Does anybody have an idea how to resolve this since I want to fully
automate the process?
Achilleas
Re: Ecore2Java Generation task [message #427114 is a reply to message #427112] Mon, 02 February 2009 11:33 Go to previous messageGo to next message
Actually the model project is not generated as a Java project and
therefore its classes cannot be imported by the edit and editor projects!
Any ideas why is that happening? The script is the following:
<project name="Ecore2Java Generation" default="GenerateJava" basedir=".">
<property name="model" value="./model/cpetypes.ecore"/>
<property name="genmodel" value="./model/cpetypes.genmodel"/>
<taskdef name="emfGen"
classname="org.eclipse.emf.importer.ecore.taskdefs.EcoreGeneratorTask "/>
<target name="GenerateJava">
<echo message="Generate the model,edit and editor Java code from the
ecore model"/>
<emf.Ecore2Java model="${model}"
genModel="${genmodel}"
modelProject="bt.com.cpetypes.model"
reconcileGenModel="keep"
generateJavaCode="true"
generateModelProject="true"
generateEditProject="true"
generateEditorProject="true"
modelProjectFragmentPath="src">
</emf.Ecore2Java>
</target>
</project>
Achilleas
Re: Ecore2Java Generation task [message #427116 is a reply to message #427114] Mon, 02 February 2009 12:02 Go to previous messageGo to next message
Achilleas,
That probably means there was an existing folder in the file system. If
there is already a project, EMF won't change it to become a Java
project, it needs to be one already...
Achilleas wrote:
> from the ecore model"/>
> </emf.Ecore2Java>
> </target>
> </project>
> Achilleas
Re: Ecore2Java Generation task [message #427117 is a reply to message #427116] Mon, 02 February 2009 12:44 Go to previous messageGo to next message
Hi Ed,
Actually what i found out is that the properties Model directory, edit
directory and editor directory generated in the genmodel are not as
supposed. They are generated like this:
Edit Directory /Borland.edit/src
Editor Directory /Borland.editor/src
Model Directory
D:/Borland/Together/workspace/bt.com.cpemss.plugin/bt.com.cp etypes.model/./src/.
So, i am trying first to resolve this! Any suggestions are welcomed!
Achilleas
Re: Ecore2Java Generation task [message #427120 is a reply to message #427117] Mon, 02 February 2009 13:19 Go to previous messageGo to next message
Achilleas,
The last guy that had odd problems like this found it was related to an
error in the paths he gave for the ecore/genmodel. Perhaps your files
exist with a different case. I don't know much about Ant, so it's hard
to guess...
Achilleas wrote:
> Hi Ed,
> Model Directory
> Achilleas
Re: Ecore2Java Generation task [message #427121 is a reply to message #427120] Mon, 02 February 2009 13:47 Go to previous messageGo to next message
Yes,
It is related to the paths given for the genmodel, since if I manually
edit these properties in the genmodel and then generate the java code the
resulting projects are just fine!
I am trying to change the paths so that this problem does not arise. I
hope someone that has more experience with ant can give an input on this.
Thanks Ed for the valuable inputs. At least we identified the problem:)
Achilleas
Re: Ecore2Java Generation task [message #427123 is a reply to message #427121] Mon, 02 February 2009 14:49 Go to previous messageGo to next message
Anyone has any ideas how to set this paths?
I tried also what it is advised at:
http://wiki.eclipse.org/EMF/FAQ#How_can_I_use_the_EMF_Ant_ta sks.3F
to set the editProject and editorProject:
<arg line="-editProject bt.com.cpetypes.model.edit src"/>
<arg line="-editorProject bt.com.cpetypes.model.editor src"/>
But still the model, edit and editor directory properties are set to
something else?
Some help by anyone will be appreciated. I am running the ant file from
eclipse. Should i set anything else?
Achilleas
Re: Ecore2Java Generation task [message #427124 is a reply to message #427123] Mon, 02 February 2009 15:26 Go to previous messageGo to next message
Sorry for posting so many times but i don't seem to find a solution on how
to set the following properties that are set inside the genmodel:
Edit Directory D:/Borland/Together/bt.com.cpetypes.model.edit/./src/.
Editor Directory D:/Borland/Together/bt.com.cpetypes.model.editor/./src/.
Model Directory
Once the genmodel is generated if i change those properties to the correct
ones then the generation of the code is just fine.
Still looking for ideas how to do that!!
Achilleas
Re: Ecore2Java Generation task [message #427127 is a reply to message #427124] Tue, 03 February 2009 01:13 Go to previous messageGo to next message
--------------040308040709090005060503
Hi Achilleas,
I've put together a very simple example that, starting from a .ecore
file, creates a generator model and also generate the java files. All
you will need to do to try it is to edit the .bat file (ECLIPSE_DIR,
WORKSPACE_DIR, and MODEL_DIR variables) before running it. This script
uses the Eclipse Ant runner to execute the build.xml also included in
the zip.
If analyzing these files and the generated .genmodel doesn't help
solving your problem, send me your .ecore file and the directory
structure you would like to end up with. I will see if I can make it work.
FYI, I've used eclipse-SDK-3.4.1 and emf-sdo-xsd-SDK-2.4.1 to test the
files.
Marcelo
> how to set the following properties that are set inside the genmodel:
> Model Directory
> correct ones then the generation of the code is just fine.
> Achilleas
Content-Type: application/octet-stream;
name="files.zip"
filename="files.zip"
UEsDBBQAAAAIABUHQzqcWm96/AAAANcBAAAJAAAAYnVpbGQueG1sbZHPTsMw DMbPReIdIovr
EkBC4pB0F5gEAmkHeICs9UpGmiI3rUCId8dN96fTdov8/b7Y/qzn37UXPVLr mmDgRl6DwFA0
pQuVgfe3xewe5vnlhf6iZoNFFCWubeejAWawwgBiZVssHRmQwGCmo6UKowi2 xj2VlExjvZaP
RUN4+2x7O5SymgFvwLsVWfqROKiQFLa9juLVb6Ikd/lT6al2PEOpAIfPluOk x7ZTfUG2qjHE
pY0fBloqpojvKheeHvZzjdqm/HzBfpjojnPKU03ztsK7wLvOOIa4/V1Mm0sO r3clkhjaqPPG
hs5aOzcxaXWcYMpbjYEPR1LbK+X/UEsDBBQAAAAIAEcHQzqT1U4WXAEAAHYC AAALAAAAY29k
ZUdlbi5iYXRtkUFrwkAQhe+B/Ie5BNpDAq09FTwUI0VUFC1IQSjrZjTbbnaW zaYh/74TjU0E
b7uzM2++99ZhAZ9UgUHMwBOU6MHnCNPJYrbeTr/S2QZ+hVPioBEOqKlOAGYe ypwqnYElZXw7
11DlAKVWtkTIlEPpyTVJGLDgUGycvu59YfdYHBNh/L4bibfpPB4lL8lTXCsz er7WwyAMWsQP
RqrJ/ZRWSISqZNg6V4x0QoNOeGVOZ+yCMtQgTAaST/BwwWRwrgEW1jc9XNvG vhXPORBghUP2
Yqi9SBbPBq107OX78mPnb7fazLfrt8ldhy0IU+46+htL/YIjr+03WEff/HBR X67S6eKeslYH
J1xzFZxKcvj8jmZ5CcFarSRHQyYMosEXRNdwJcSGtlaLModYauSI4kx4AdGN oYgfyZSkcUEn
iAe6QO6UdGItUcIE58OmMoZDjdOznYRtjqN/G1EY/AFQSwMEFAAAAAgAfHqq NL1Fx0n8AQAA
uAcAAA0AAABsaWJyYXJ5LmVjb3Jl3VVbb9owFH6v1P8Qec9gyl4mBK1GBxIS 1arSbns15hCs
JnZknzTk3+84N4hYp7JMqtQ85HJ8vs/fufhkfLOPo+AFrFNGT9hVf8AC0NJs lA4n7Olx3vvC
bq4vL8YgjYXR7F7IZxFCsI/VqEENCXV5EdBFZNqNaHHCdojJiPMsy/omDvvG hvzX3YLVLq7t
kn0uPIaDwRW5LVdyB7HoKe1QaAkt9kJJCwwyUomDggHirWcZ8pl3Y4EWMTlH am2FzSse7Z4e
Fg0DrxaJpkS4ewtbtT+grj1sDLeRcE5tFYUdkP4R5glRV4kpFuvtpsY8lyiP W6FNJaZWRHMQ
9IQ/wL8iWrVOsVGMCiP6gMdjr28ChTcEbwr+E+cz2psqyXg3MQmV3HUXs9Do K1BdG9iKNMIf
IkphqRBIEjXgYNBVrBQIobF5o5e29gW5rexn8j/AFiwdiYZfpLgzlgWRycBO Tao3JPsQ19Gu
P60Pi3R8TxLj6P3IytckyVVaxvy4uc5ut2XZpx07ju7v1XAnOc6KHFGAaZI0 Se79PcvSaBRK
x6BxwmhT6CrCV+htEorzfirg/1S3jO8DFffcvNbH52Dj5Rn85/zOdBrXalqj oQ6sHkiucrrL
HX03o+PUYSWVD3GuJNIvkQUvfqrRXHgdMVUmtCLZ5Y3z8LV4yND6+5LpN1BL AQIUABQAAAAI
ABUHQzqcWm96/AAAANcBAAAJAAAAAAAAAAAAIAAAAAAAAABidWlsZC54bWxQ SwECFAAUAAAA
CABHB0M6k9VOFlwBAAB2AgAACwAAAAAAAAAAACAAAAAjAQAAY29kZUdlbi5i YXRQSwECFAAU
AAAACAB8eqo0vUXHSfwBAAC4BwAADQAAAAAAAAAAACAAAACoAgAAbGlicmFy eS5lY29yZVBL
BQYAAAAAAwADAKsAAADPBAAAAAA=
--------------040308040709090005060503--
Re: Ecore2Java Generation task [message #427130 is a reply to message #427127] Tue, 03 February 2009 05:28 Go to previous messageGo to next message
Hi Marcelo,
Thanks for the example. I will try that and see if I can resolve my
problem. The problem is though that I am trying to run the ant script
within Borland together from a plug-in which I created.
I am not using a batch file to do that. Despite that fact your example
might give me a clue how to change those paths within Borland together.
I will let you know soon of the result.
Achilleas
Re: Ecore2Java Generation task [message #427186 is a reply to message #427130] Thu, 05 February 2009 07:10 Go to previous messageGo to next message
Hi Marcelo,
I have tried your example outside eclipse running the batch file with my
working paths and it has generated the code.
It does the same thing if I run it within eclipse, within borland, and via
the headless batch file. To be more precise the .genmodel that it is
generated contains invalid properties. These properties are the Model
directory, the Edit directory and the Editor directory.
It is always appended at the start something like:
If I run it within Eclipse:
Model Directory:D:/PhD/Development
Tools/iMDE/eclipse/workspace/bt.com.cpetypes.metamodel/bt.co m.cpetypes.metamodel/./src/.
Edit Directory: D:/PhD/Development
Tools/iMDE/eclipse/bt.com.cpetypes.metamodel.edit/./src/.
Editor Directory:D:/PhD/Development
Tools/iMDE/eclipse/bt.com.cpetypes.metamodel.editor/./src/.
instead of being the correct ones:
Model Directory: /bt.com.cpetypes.metamodel/src/
Edit Directory: /bt.com.cpetypes.metamodel.edit/src/
Editor Directory: /bt.com.cpetypes.metamodel.editor/src/
If I run it within Borland:
Model
Directory:D:/Borland/Together/bt.com.cpetypes.metamodel/bt.c om.cpetypes.metamodel/./src/.
Edit Directory: D:/Borland/Together/bt.com.cpetypes.metamodel.edit/./src/.
Editor
Directory:D:/Borland/Together/bt.com.cpetypes.metamodel.edit or/./src/.
instead of being again the correct ones:
While running the script the code is generated, the edit and editor
projects generated are not even set to be Java projects. Moreover the
genmodel includes this incorrect properties I mentioned above.
When correcting the properties manually from the properties view and
generating the code by right-click command on the .genmodel the code is
perfectly ok and I can run the editor as an eclipse instance.
I don't know why the path is appended and alters the properties. I tried
everything and searched everywhere to find a solution before bothering you
again! If you could provide me with a solution I will be grateful!
How can I attach a zip file while posting:)??
Achilleas
Re: Ecore2Java Generation task [message #427193 is a reply to message #427186] Thu, 05 February 2009 08:03 Go to previous messageGo to next message
Achilleas,
Comments below.
Achilleas wrote:
> Hi Marcelo,
> my working paths and it has generated the code.
> via the headless batch file. To be more precise the .genmodel that it
> is generated contains invalid properties. These properties are the
> Model directory, the Edit directory and the Editor directory.
This is simply the different behavior that you get between stand-alone
and Eclipse.
> Model
> Edit Directory:
> Editor
Again, if you aren't running in Eclipse you don't get all the nice
Eclipse effects.
> is perfectly ok and I can run the editor as an eclipse instance.
Generally what most people do is preserve their GenModel and reuse it.
The scripts allow you to reload the existing GenModel such that it's
up-to-date with respect to any model changes, but also preserves all the
settings within the *.genmodel.
> tried everything and searched everywhere to find a solution before
> bothering you again! If you could provide me with a solution I will be
> grateful!
The path of least resistance is to preserve your *.genmodel file, rather
than creating a new one from scratch...
I use Thunderbird for accessing the newsgroup. It's very nice.
> Achilleas
Re: Ecore2Java Generation task [message #427203 is a reply to message #427193] Thu, 05 February 2009 10:17 Go to previous message
Hi Ed and Marcelo,
Thanks to both of you guys for directing me to the solution to my problem.
I think the problem is not resolved completely, meaning that I have
manually created a .genmodel for which I only set manually these three
properties.
This is performed Ed since in any case either using a batch file, Eclipse
or Borland Together the path to the eclipse, borland or batch file is
appended to these three properties. I don't know if that is how the
impementation of the EcoreGeneratorTask works? I presume it is from the
result.
So, your suggestion Ed to preserve a .genmodel let me to the idea to
create a skeleton .genmodel and via the reconcileGenModel="reload"
property to reload the model changes from the .ecore metamodel by
executing the ant script.
Thanks for both your help,
Achilleas
Previous Topic:[EMF] How to create an instance of an ecore model
Next Topic:Philosophical Question
Current Time: Sun Jul 20 03:43:01 EDT 2025
Powered by FUDForum. Page generated in 0.46251 seconds
