Home » Modeling » EMF » problem customizing edit plugin, PropertyDescriptor
problem customizing edit plugin, PropertyDescriptor [message #426979] Tue, 27 January 2009 10:45 Go to next message
in the properties view, when I want to select an element from a large list of choices, it is very helpful that I can
start typing, e.g. "EPac..." to find the element "EPackage" more quickly.
In my edit plug-in, I have customized an addXXXPropertyDecriptor method to filter out values which are unnecessary in a
particular context. When still large Lists of choices remain, I start typing "EPac..." and select the EPackage, but then
I end up having another element selected.
Any idea how to avoid this?
Thanks for helping
Joel
Re: problem customizing edit plugin, PropertyDescriptor [message #426983 is a reply to message #426979] Tue, 27 January 2009 11:40 Go to previous messageGo to next message
Joel,
Comments below.
Joel Greenyer wrote:
> list of choices, it is very helpful that I can start typing, e.g.
> method to filter out values which are unnecessary in a particular
> "EPac..." and select the EPackage, but then I end up having another
> element selected.
I don't get this part about another element being selected. The first
thing in the filtered result is selected and hitting enter should choose
it...
> Thanks for helping
> Joel
Re: problem customizing edit plugin, PropertyDescriptor [message #427076 is a reply to message #426983] Fri, 30 January 2009 19:18 Go to previous messageGo to next message
Hi Ed,
mmh, I was clear :(
Alright... I have elements that are typed by an EClass. For the type feature, the drop-down in the properties view gives
me the choice of all EClasses that are reachable in the current ResourceSet. But I want to narrow down this choice,
since one may only select EClasses from certain EPackages (depending on the element's context). My approach was
overriding getChoiceOfValues(Object). This works fine except for this typeing/filtering functionality: I can type
"EPack...", then the EPackage class appears at the top. However, when I hit enter, the EPackage is not selected, but I
find another element being selected instead.
So, my question is whether my approach to customize the ItemPropertyDescriptor is correct?
Joel
Ed Merks wrote:
> Joel,
> Comments below.
>> Hi,
>> element selected.
> it...
>> Thanks for helping
>> Joel
Re: problem customizing edit plugin, PropertyDescriptor [message #427079 is a reply to message #427076] Sat, 31 January 2009 03:49 Go to previous messageGo to next message
Hi Joel,
> My approach was overriding getChoiceOfValues(Object).
This is what I do all the time (generated based on custom templates or
genmodel annotations) and everything works fine for us including typing.
Could you show us sourcecode?
Jim
> Hi Ed,
> mmh, I was clear :(
> feature, the drop-down in the properties view gives me the choice of all
> narrow down this choice, since one may only select EClasses from certain
> typeing/filtering functionality: I can type "EPack...", then the
> EPackage is not selected, but I find another element being selected
> instead.
> Thanks
> Joel
> Ed Merks wrote:
>> Joel,
>> Comments below.
>>> Hi,
>>> element selected.
>> choose it...
>>> Thanks for helping
>>> Joel
Re: problem customizing edit plugin, PropertyDescriptor [message #427080 is a reply to message #427079] Sat, 31 January 2009 04:26 Go to previous messageGo to next message
Hi Jim,
here's my changed addPropertyDescriptor method from the NodeItemProvider class.
Nodes may be inside a graph pattern. One of these graph pattern may be a domain graph pattern. A domain graph pattern is
associated with a typed model, which references a list of packages. I want an EClass of each of those packages to be in
the list of choices. In case that something along this way is null (because the model is not consistent), I catch the
NullPointerException and return an empty list.
What do you do different?
Thanks for helping
Joel
* This adds a property descriptor for the EType feature.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated NOT
protected void addETypePropertyDescriptor(Object object) {
itemPropertyDescriptors.add
new ItemPropertyDescriptor(
((ComposeableAdapterFactory)adapterFactory).getRootAdapterFa ctory(),
getResourceLocator(),
getString("_UI_ETypedElement_eType_feature"),
getString("_UI_PropertyDescriptor_description", "_UI_ETypedElement_eType_feature", "_UI_ETypedElement_type"),
EcorePackage.Literals.ETYPED_ELEMENT__ETYPE,
true,
null,
null,
null){
public Collection getChoiceOfValues(Object object) {
Node node = (Node) object;
try {
for (GraphPattern graphPattern : node.getGraphPattern()) {
if (graphPattern instanceof DomainGraphPattern){
TypedModel typedModel = ((DomainGraphPattern) graphPattern).getTypedModel();
EList<EClass> eClassList = new BasicEList<EClass>();
for (EPackage usedPackage : typedModel.getUsedPackage()) {
for (EClassifier eClassifier : usedPackage.getEClassifiers()) {
if (eClassifier instanceof EClass){
eClassList.add((EClass) eClassifier);
return eClassList;
} catch (NullPointerException e) {
//nothing to worry about there. May occur if the necessary references have not been set up properly.
return Collections.EMPTY_LIST;
Jim van Dam wrote:
> Hi Joel,
> Regards,
> Jim
>> Hi Ed,
>> mmh, I was clear :(
>> to narrow down this choice, since one may only select EClasses from
>> was overriding getChoiceOfValues(Object). This works fine except for
>> this typeing/filtering functionality: I can type "EPack...", then the
>> instead.
>> Thanks
>> Joel
>> Ed Merks wrote:
>>> Joel,
>>> Comments below.
>>>> Hi,
>>>> large list of choices, it is very helpful that I can start typing,
>>>> element selected.
>>> first thing in the filtered result is selected and hitting enter
>>> should choose it...
>>>> Thanks for helping
>>>> Joel
Re: problem customizing edit plugin, PropertyDescriptor [message #427082 is a reply to message #427080] Sat, 31 January 2009 07:51 Go to previous messageGo to next message
Joel,
As Jim suggests, we do this type of filtering all over the place (do
something to returned a reduced set of choices) and have never seen this
type of problem. The filtering as you type is completely orthoganal to
the set of choices originally returned, so certainly the problem can't
be in your properly descriptor, I don't think. All I can do is suggest
you set a breakpoint where the value is being set, and then look down
the stack to see where something has gone wrong in the process. That's
would I'd need to do, if I could reproduce the problem, which I can't...
> Hi Jim,
> a domain graph pattern. A domain graph pattern is associated with a
> each of those packages to be in the list of choices. In case that
> consistent), I catch the NullPointerException and return an empty list.
> Thanks for helping
> Joel
> * @generated NOT
> true,
> null,
> null,
> null){
> try {
> return eClassList;
> Jim van Dam wrote:
>> Hi Joel,
>> or genmodel annotations) and everything works fine for us including
>> typing.
>> Regards,
>> Jim
>>> Hi Ed,
>>> mmh, I was clear :(
>>> want to narrow down this choice, since one may only select EClasses
>>> approach was overriding getChoiceOfValues(Object). This works fine
>>> when I hit enter, the EPackage is not selected, but I find another
>>> Thanks
>>> Joel
>>> Ed Merks wrote:
>>>> Joel,
>>>> Comments below.
>>>>> Hi,
>>>> should choose it...
>>>>> Thanks for helping
>>>>> Joel
Re: problem customizing edit plugin, PropertyDescriptor [message #427086 is a reply to message #427082] Sat, 31 January 2009 09:21 Go to previous messageGo to next message
--------------010507070702060004050302
Okay, could this be a GMF problem?
I observe that the property is set twice: First the correct value is set, and then it is immediately set to another
value. This happens when I use the properties view of the GMF editor. When I use the tree editor's properties view,
everything is fine!
I attached the two stacks of the first and the second (erroneous) call of the objects set method. Here is where the
second differs from the first
PropertySheetViewer.applyEditorValue() line: 258
PropertySheetViewer.setInput(Object) line: 963
PropertySheetPage.refresh() line: 471
TggPropertySection(AdvancedPropertySection).refresh() line: 188
AdvancedPropertySection$1.run() line: 215
RunnableLock.run() line: 35
UISynchronizer(Synchronizer).runAsyncMessages(boolean) line: 133
Display.runAsyncMessages(boolean) line: 3800
Display.readAndDispatch() line: 3425
I don't understand why GMF would be interfering here. Any why the second call of the set method only occurs when I
type/filter the given choices (e.g. "EPack..." to find the class EPackage more quickly). Maybe anyone of you has an
idea? Otherwise, I'll dig deeper myself when I find the time.
Joel
Ed Merks wrote:
> Joel,
>> Hi Jim,
>> Thanks for helping
>> Joel
>> * @generated NOT
>> true,
>> null,
>> null,
>> null){
>> try {
>> return eClassList;
>> Jim van Dam wrote:
>>> Hi Joel,
>>> typing.
>>> Regards,
>>> Jim
>>>> Hi Ed,
>>>> mmh, I was clear :(
>>>> Thanks
>>>> Joel
>>>> Ed Merks wrote:
>>>>> Joel,
>>>>> Comments below.
>>>>>> Hi,
>>>>> should choose it...
>>>>>> Thanks for helping
>>>>>> Joel
name="stack1.txt"
Content-Disposition: inline;
filename="stack1.txt"
NodeImpl.setEType(EClassifier) line: 419
NodeImpl(ETypedElementImpl).eSet(int, Object) line: 596
NodeImpl(VariableImpl).eSet(int, Object) line: 441
NodeImpl.eSet(int, Object) line: 542
NodeImpl(BasicEObjectImpl).eSet(EStructuralFeature, Object) line: 1071
SetCommand.doExecute() line: 721
SetCommand(AbstractOverrideableCommand).execute() line: 131
EMFCommandOperation.doExecute(IProgressMonitor, IAdaptable) line: 119
EMFCommandOperation(AbstractEMFOperation).execute(IProgressM onitor, IAdaptable) line: 169
DefaultOperationHistory.execute(IUndoableOperation, IProgressMonitor, IAdaptable) line: 511
WorkspaceCommandStackImpl.doExecute(Command, Map<?,?>) line: 201
WorkspaceCommandStackImpl(AbstractTransactionalCommandStack) .execute(Command, Map<?,?>) line: 165
WorkspaceCommandStackImpl(AbstractTransactionalCommandStack) .execute(Command) line: 219
NodeItemProvider$1(ItemPropertyDescriptor).setPropertyValue( Object, Object) line: 1427
PropertySource.setPropertyValue(Object, Object) line: 116
SetModelPropertyValueCommand.doExecuteWithResult(IProgressMo nitor, IAdaptable) line: 104
SetModelPropertyValueCommand(AbstractTransactionalCommand).d oExecute(IProgressMonitor, IAdaptable) line: 247
SetModelPropertyValueCommand(AbstractEMFOperation).execute(I ProgressMonitor, IAdaptable) line: 169
CompositeTransactionalCommand(CompositeEMFOperation).doExecu te(IProgressMonitor, IAdaptable) line: 216
CompositeTransactionalCommand(AbstractEMFOperation).execute( IProgressMonitor, IAdaptable) line: 169
TriggeredOperations.execute(IProgressMonitor, IAdaptable) line: 165
UndoableModelPropertySheetEntry.valueChanged(UndoableModelPr opertySheetEntry, ICommand) line: 244
UndoableModelPropertySheetEntry.setValue(Object) line: 199
UndoableModelPropertySheetEntry.applyEditorValue() line: 127
CellEditor$1.run() line: 333
SafeRunner.run(ISafeRunnable) line: 37
Platform.run(ISafeRunnable) line: 880
JFaceUtil$1.run(ISafeRunnable) line: 48
SafeRunnable.run(ISafeRunnable) line: 175
ExtendedComboBoxCellEditor(CellEditor).fireApplyEditorValue( ) line: 331
ExtendedComboBoxCellEditor(ComboBoxCellEditor).applyEditorVa lueAndDeactivate() line: 273
ComboBoxCellEditor$2.widgetDefaultSelected(SelectionEvent) line: 151
TypedListener.handleEvent(Event) line: 113
EventTable.sendEvent(Event) line: 84
CCombo(Widget).sendEvent(Event) line: 1003
CCombo(Widget).sendEvent(int, Event, boolean) line: 1027
CCombo(Widget).sendEvent(int, Event) line: 1012
CCombo(Widget).notifyListeners(int, Event) line: 770
CCombo.listEvent(Event) line: 1071
CCombo$1.handleEvent(Event) line: 110
List(Widget).sendEvent(Event) line: 1003
List(Widget).sendEvent(int, Event, boolean) line: 1027
List(Widget).sendEvent(int, Event) line: 1012
List(Widget).sendKeyEvent(int, int, int, int, Event) line: 1040
List(Widget).sendKeyEvent(int, int, int, int) line: 1036
List(Widget).wmChar(int, int, int) line: 1352
List(Control).WM_CHAR(int, int) line: 3894
List.WM_CHAR(int, int) line: 1528
List(Control).windowProc(int, int, int, int) line: 3787
Display.windowProc(int, int, int, int) line: 4528
OS.DispatchMessageW(MSG) line: not available [native method]
OS.DispatchMessage(MSG) line: 2371
Display.readAndDispatch() line: 3420
Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 2382
Workbench.runUI() line: 2346
Workbench.access$4(Workbench) line: 2198
Workbench$5.run() line: 493
Realm.runWithDefault(Realm, Runnable) line: 288
Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 488
PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 149
IDEApplication.start(IApplicationContext) line: 113
EclipseAppHandle.run(Object) line: 193
EclipseAppLauncher.runApplication(Object) line: 110
EclipseAppLauncher.start(Object) line: 79
EclipseStarter.run(Object) line: 386
EclipseStarter.run(String[], Runnable) line: 179
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not available [native method]
NativeMethodAccessorImpl.invoke(Object, Object[]) line: not available
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: not available
Method.invoke(Object, Object...) line: not available
Main.invokeFramework(String[], URL[]) line: 549
Main.basicRun(String[]) line: 504
Main.run(String[]) line: 1236
Main.main(String[]) line: 1212
name="stack2.txt"
filename="stack2.txt"
--------------010507070702060004050302--
Re: problem customizing edit plugin, PropertyDescriptor [message #427264 is a reply to message #427086] Mon, 09 February 2009 10:12 Go to previous message
In case someone still reads this thread:
I think this is caused by bugs 183039 and 193757 (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=183039,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=193757).
Overriding getChoiceOfValues(Object) seems to have nothing to do with
it. It's a general GMF bug, and I think caused by a reset of the typing
filter during the first set() of the new value. The subsequent
ExtendedComboBoxCellEditor.doGetValue() call then returns a wrong value,
because it's using a filtered-index-based get() on the unfiltered list.
Jan
> set, and then it is immediately set to another value. This happens when
> editor's properties view, everything is fine!
> of the objects set method. Here is where the second differs from the first
> call of the set method only occurs when I type/filter the given choices
> of you has an idea? Otherwise, I'll dig deeper myself when I find the time.
> Thanks
> Joel
Previous Topic:JRE Compliance Level and Runtime Compatibility
Next Topic:Re: [Teneo] Problem with saving after deleting object referencing StringToXXXMap
Current Time: Sun Jul 20 03:32:34 EDT 2025
Powered by FUDForum. Page generated in 0.25679 seconds
