java.lang.NumberFormatException when reading a model [message #426393] |
Fri, 02 January 2009 10:03  |
I have the error
java.lang.NumberFormatException: For input string:
"aadlSpec[@name=prodcons]" when I try to read a model in a standalone
environment. This model is successfully opened in an eclipse plugin
environment.
The used plugin have the following extensions:
<plugin>
<extension
point="org.eclipse.emf.ecore.generated_package">
<package
uri="http:///AADL/property"
class="edu.cmu.sei.aadl.model.property.PropertyPackage">
</package>
</extension>
<extension
<package
uri="http:///AADL/component"
class="edu.cmu.sei.aadl.model.component.ComponentPackage">
</package>
</extension>
<extension
<package
uri="http:///AADL/instance"
class="edu.cmu.sei.aadl.model.instance.InstancePackage">
</package>
</extension>
<extension
<package
uri="http:///AADL/connection"
class="edu.cmu.sei.aadl.model.connection.ConnectionPackage" >
</package>
</extension>
<extension
<package
uri="http:///AADL/core"
class="edu.cmu.sei.aadl.model.core.CorePackage">
</package>
</extension>
<extension
<package
uri="http:///AADL/feature"
class="edu.cmu.sei.aadl.model.feature.FeaturePackage">
</package>
</extension>
<extension
<package
uri="http:///AADL/flow"
class="edu.cmu.sei.aadl.model.flow.FlowPackage">
</package>
</extension>
<extension
id="AadlObjectMarker"
name="Aadl Model Object Marker"
point="org.eclipse.core.resources.markers">
<super
type="org.eclipse.core.resources.problemmarker"/>
<super type = "org.eclipse.emf.ecore.diagnostic"/>
<!--attribute
name="uri">
</attribute-->
<persistent
value="true">
</persistent>
</extension>
<extension
id="AadlGotoMarker"
name="Goto AObject Marker"
<super
type="edu.cmu.sei.aadl.model.AadlObjectMarker">
</super>
<!--attribute
name="uri">
</attribute-->
<persistent
value="true">
</persistent>
</extension>
<extension
id="AadlTextMarker"
name="Aadl Text Marker"
<super
type="org.eclipse.core.resources.problemmarker">
</super>
<persistent
value="true">
</persistent>
</extension>
<extension
id="AadlTextGotoMarker"
name="Goto AADL Source Text Marker"
<super
type="edu.cmu.sei.aadl.model.AadlTextMarker">
</super>
<persistent
value="false">
</persistent>
</extension>
<extension point="org.eclipse.core.runtime.adapters">
<factory
class="edu.cmu.sei.aadl.model.pluginsupport.AObjectAdapterFactory "
adaptableType="edu.cmu.sei.aadl.model.core.AObject">
<adapter type="org.eclipse.ui.IActionFilter"/>
</factory>
<factory
class=" edu.cmu.sei.aadl.model.pluginsupport.IResourceAdapterFactory "
adaptableType="org.eclipse.core.resources.IResource">
<adapter type="edu.cmu.sei.aadl.model.core.AObject"/>
</factory>
</extension>
</plugin>
How can I read this model in a standalone environment?
Thanks in advance,
Anne Robert.
FUDForum. Page generated in 0.05062 seconds
