Home » Modeling » EMF » Add IProgressMonitor to DeleteCommand
Add IProgressMonitor to DeleteCommand [message #426193] Thu, 18 December 2008 12:23 Go to next message
Is there a way to add progress monitor to DeleteCommand and more generally
to an EMF Command ?
Thank you for your response !
Sylvain
Re: Add IProgressMonitor to DeleteCommand [message #426196 is a reply to message #426193] Thu, 18 December 2008 15:35 Go to previous messageGo to next message
Sylvain,
I've never thought about it. It seems tricky. Does it really take that
long?
Sylvain Dudoit wrote:
> generally to an EMF Command ?
> Sylvain
Re: Add IProgressMonitor to DeleteCommand [message #426201 is a reply to message #426196] Fri, 19 December 2008 03:37 Go to previous messageGo to next message
I'm using EMF 2.3 and I can have some nodes containing more than 100
subnodes.
So, when I use DeleteCommand for the parent node, it takes a while and
could frozes the application.
An idea of the best solution ? reimplement commands to add progres monitor
Thank,
Sylvain
Re: Add IProgressMonitor to DeleteCommand [message #426207 is a reply to message #426201] Fri, 19 December 2008 08:02 Go to previous messageGo to next message
Sylvain,
I'm really not sure how you will measure progress in a meaningful way.
Having a progress monitor come up when you do a "simple" delete might be
very annoying to the user. Unless your users are complaining, it seems
a lot of work with potentially negative gain...
> subnodes.
> monitor ?
> Thank,
> Sylvain
Re: Add IProgressMonitor to DeleteCommand [message #426211 is a reply to message #426207] Fri, 19 December 2008 09:26 Go to previous message
I agree with Ed, measuring the work would not be very precise here. Why
don't you just wrap your call into
org.eclipse.swt.custom.BusyIndicator.showWhile(Display, Runnable)? The
user would see an hour glass until the command has completed.
Kind regards, Sebastian
Previous Topic:different instances of ECorePackages
Next Topic:Problem loading model as a resource
Current Time: Sat Jul 19 16:32:36 EDT 2025
Powered by FUDForum. Page generated in 0.04084 seconds
