Home » Modeling » EMF » [CDO] CDO View throws OutOfMemoryError
[CDO] CDO View throws OutOfMemoryError [message #426107] |
Tue, 16 December 2008 10:00  |
I am using CDO 2.0.0M3. I tried to use CDO View to browse repository
content. After entering server address and pressing OK, it throws out of
memory error. Heap limit is 1024mb, before connecting it was using about
150mb. And repository database is empty.
Saulius
java.lang.OutOfMemoryError: Java heap space
at
org.eclipse.emf.cdo.spi.common.CDOIDLibraryDescriptorImpl.<init >(CDOIDLibraryDescriptorImpl.java:54)
at
org.eclipse.emf.cdo.common.id.CDOIDUtil.readLibraryDescripto r(CDOIDUtil.java:235)
at
org.eclipse.emf.internal.cdo.protocol.OpenSessionRequest.con firming(OpenSessionRequest.java:147)
at
org.eclipse.emf.internal.cdo.protocol.OpenSessionRequest.con firming(OpenSessionRequest.java:1)
at
org.eclipse.emf.internal.cdo.protocol.CDOClientRequest.confi rming(CDOClientRequest.java:103)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedI nput(RequestWithConfirmation.java:118)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:317)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(R equestWithConfirmation.java:98)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.jav a:68)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:237)
at
org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalPr otocol.java:392)
at
org.eclipse.net4j.signal.RequestWithConfirmation.send(Reques tWithConfirmation.java:82)
at
org.eclipse.net4j.signal.RequestWithConfirmation.send(Reques tWithConfirmation.java:73)
at
org.eclipse.emf.internal.cdo.CDOSessionImpl.doActivate(CDOSe ssionImpl.java:808)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycl e.java:53)
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:69)
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:59)
at
org.eclipse.net4j.util.container.ManagedContainer.getElement (ManagedContainer.java:274)
at
org.eclipse.net4j.util.container.ManagedContainer.getElement (ManagedContainer.java:255)
at
org.eclipse.emf.cdo.internal.ui.actions.OpenSessionAction.do Run(OpenSessionAction.java:76)
at
org.eclipse.net4j.util.ui.actions.LongRunningAction$1.run(Lo ngRunningAction.java:164)
Re: [CDO] CDO View throws OutOfMemoryError [message #426139 is a reply to message #426113] |
Wed, 17 December 2008 03:33   |
I am running CDOServer as plugin from my target platform. Which is
2.0.0M3. I have no problem with my application accessing server, so I
guess it should be something wrong on a client side. My cdo config is below.
I was not able to connect with negotiator enabled. Is CDO View supports
access with login/password?
I disabled negatiator and URL was tcp://localhost, Repository: repo1,
Autoregistry: false.
Build of CDO and Net4J I am running is 20081127. I believe it is M3.
Saulius
<cdoServer>
<acceptor type="tcp" listenAddr="0.0.0.0" port="2036">
<negotiator type="challenge" description="users.txt"/>
</acceptor>
<repository name="repo1">
<property name="overrideUUID"
value="1ff5d226-b1f0-40fb-aba2-0c31b38c764f"/>
<property name="supportingAudits" value="true"/>
<property name="verifyingRevisions" value="false"/>
<property name="currentLRUCapacity" value="10000"/>
<property name="revisedLRUCapacity" value="100"/>
<store type="db">
<mappingStrategy type="horizontal">
<property name="qualifiedNames" value="true"/>
<property name="toManyReferences" value="ONE_TABLE_PER_REFERENCE"/>
<property name="toOneReferences" value="LIKE_ATTRIBUTES"/>
</mappingStrategy>
<jdbcDelegate type="statement" />
<dbAdapter name="mysql"/>
<dataSource class="com.mysql.jdbc.jdbc2.optional.MysqlDataSource" .../>
</store>
</repository>
</cdoServer>
On 12/16/2008 7:23 PM, Víctor Roldán Betancort wrote:
> Saulius,
> that looks really strange. Could you please provide more information
> regarding the environment where you performed this action?
> - How are you running CDOServer? Which backend are you using? Derby,
> MySQL, PostgreSQL, Hibernate...
> - Content of cdoserver.xml?
> - Input values to the "open session" dialog (server description and
> repository name fields)
> Have you downloaded Net4J 2.0.0M3 as well?
> Cheers,
> Víctor.
> Saulius Tvarijonas escribió:
>> Hi,
>> of memory error. Heap limit is 1024mb, before connecting it was using
>> about 150mb. And repository database is empty.
>> Saulius
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Re: [CDO] CDO View throws OutOfMemoryError [message #426145 is a reply to message #426144] |
Wed, 17 December 2008 04:27   |
Eike,
Sorry for confusing. When I wrote "CDO View" I mean CDO UI plugin :). I
understand CDOView interface. In my application we already have
authentication working with negotiator. So it is configured in my CDO
server and works from my client. I just wanted to know if CDO UI plugin
allows to connect to CDO server which is configured with negotiator.
Saulius
On 12/17/2008 11:18 AM, Eike Stepper wrote:
> Saulius,
> Comments below..
> Saulius Tvarijonas schrieb:
>> Hi,
>> below.
> If you're using any sort of negotiation you must usually ensure that the
> INegotiators of both client and server side properly match together.
> INegotiators are currently only supported by IConnectors. Since
> server-side connectors are created by an IAcceptor you need to configure
> the acceptor with the needed INegotiator so tat it can pass it down to
> new connectors. If you do so you need to add a matching negotiator to
> your client connector before connecting, too.
>> Is CDO View supports access with login/password?
> Not per view. But each view belongs to a session and this session has a
> protocol and this protocol has a channel and this channel has a
> connector and there we go ;-)
> From a client point of view and with respect to negotiation the
> protocol and channel are irrelevant (automatically created by the
> session). Usually you create your session through CDOSessionConfiguration:
> | // Prepare container
> IManagedContainer container = ContainerUtil.createContainer();
> Net4jUtil.prepareContainer(container); // Register Net4j factories
> TCPUtil.prepareContainer(container); // Register TCP factories
> CDOUtil.prepareContainer(container); // Register CDO factories
> container.activate();
> // Create connector
> IConnector connector = TCPUtil.getConnector(container, "localhost:2036");
> // Create configuration
> CDOSessionConfiguration configuration =
> CDOUtil.createSessionConfiguration();
> configuration.setConnector(connector);
> configuration.setRepositoryName("repo1");
> // Open session
> CDOSession session = configuration.openSession();
> session.getPackageRegistry().putEPackage(Model1Package.eINST ANCE);|
> If you're pulling your client connector out of an IManagedContainer it
> will already be connected. So you need to register a post processor with
> the container to inject your negotiator into the connector *before* it
> is returned. Please see also
> http://wiki.eclipse.org/FAQ_for_CDO_and_Net4j#How_can_I_use_ authentication.3F
> Cheers
> /Eike
> http://thegordian.blogspot.com
>> Saulius
>> <?xml version="1.0" encoding="UTF-8"?>
>> <cdoServer>
>> </acceptor>
>> <store type="db">
>> </mappingStrategy>
>> </store>
>> </repository>
>> </cdoServer>
>>> Saulius,
>>> Cheers,
>>> Víctor.
>>>> Hi,
>>>> Saulius
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: [CDO] CDO View throws OutOfMemoryError [message #426149 is a reply to message #426145] |
Wed, 17 December 2008 05:52   |
Saulius,
The shipped user interface (i.e. CDOSessions view) creates sessions
through the IPluginContainer. So my explanations still apply ;-)
Cheers
/Eike
> Eike,
> I understand CDOView interface. In my application we already have
> plugin allows to connect to CDO server which is configured with
> negotiator.
> Regards,
> Saulius
>> Saulius,
>> Comments below..
>>> Hi,
>>> below.
>> // Create connector
>> "localhost:2036");
>> // Open session
>> Cheers
>> /Eike
>>> Saulius
>>> <cdoServer>
>>> </acceptor>
>>> <store type="db">
>>> </mappingStrategy>
>>> </store>
>>> </repository>
>>> </cdoServer>
>>>> Saulius,
>>>> Cheers,
>>>> Víctor.
>>>>> Hi,
>>>>> Saulius
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
Re: [CDO] CDO View throws OutOfMemoryError [message #426156 is a reply to message #426149] |
Wed, 17 December 2008 08:45   |
Eike,
As I understand CDOSessions View out of box is not able to connect to
repository with negotiator. Unless somebody else prepares
UPluginContainer before CDOSessions View tries to connect.
It would be nice if CDOSessions View automatically could inject
ConnectorCredentialsInjector depending on URL. For example
tcp://admin:admin@localhost.
Saulius
On 12/17/2008 12:52 PM, Eike Stepper wrote:
> Saulius,
> Cheers
> /Eike
>> Eike,
>> negotiator.
>> Regards,
>> Saulius
>>> Saulius,
>>> Comments below..
>>>> Hi,
>>>> below.
>>> // Create connector
>>> "localhost:2036");
>>> // Open session
>>> Cheers
>>> /Eike
>>>> Saulius
>>>> <cdoServer>
>>>> </acceptor>
>>>> <store type="db">
>>>> </mappingStrategy>
>>>> </store>
>>>> </repository>
>>>> </cdoServer>
>>>>> Saulius,
>>>>> Cheers,
>>>>> Víctor.
>>>>>> Hi,
>>>>>> Saulius
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
Re: [CDO] CDO View throws OutOfMemoryError [message #426160 is a reply to message #426156] |
Wed, 17 December 2008 09:04  |
Saulius,
You can do so by contributing an IElementProcessor of your choice to the
extension point org.eclipse.net4j.util.elementProcessors.
Cheers
/Eike
> Eike,
> Regards,
> Saulius
>> Saulius,
>> Cheers
>> /Eike
>>> Eike,
>>> negotiator.
>>> Regards,
>>> Saulius
>>>> Saulius,
>>>> Comments below..
>>>>> Hi,
>>>>> below.
>>>> that the
>>>> configure
>>>> has a
>>>> // Create connector
>>>> "localhost:2036");
>>>> // Open session
>>>> with
>>>> Cheers
>>>> /Eike
>>>>> Saulius
>>>>> <cdoServer>
>>>>> </acceptor>
>>>>> <store type="db">
>>>>> </mappingStrategy>
>>>>> </store>
>>>>> </repository>
>>>>> </cdoServer>
>>>>>> Saulius,
>>>>>> Cheers,
>>>>>> Víctor.
>>>>>>> Hi,
>>>>>>> repository
>>>>>>> throws out
>>>>>>> using
>>>>>>> Saulius
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
Current Time: Sun Jul 20 12:26:47 EDT 2025
Powered by FUDForum. Page generated in 0.05992 seconds
