Home » Modeling » EMF » Reading CDATA content into an EMF model
Reading CDATA content into an EMF model [message #425897] Thu, 11 December 2008 06:26 Go to next message
Hello EMF community,
we're using EMF to read XML files (provided by some other black box
software) into a model. The XML files look something like this one:
<rn:structure xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:rn="http://www.foo.bar/rn">
<node name="Foo">
<documentation><![CDATA[Some text with lots of special
chars.]]></documentation>
</node>
</rn:structure>
Now, I'm having some trouble getting the CDATA value into the model's
documentation feature. The relevant Ecore model part is as follows:
<eClassifiers xsi:type="ecore:EClass" name="Node">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="documentation"
upperBound="-1"
eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
With the above, I think EMF doesn't behave correctly or I did something
wrong in the Ecore-file. When opening the above XML model with my
generated Editor, EMF reads in the value of the CDATA as desired. In the
properties view I see "Some text with lots of special chars." as value of
the documentation feature.
Strange behavior #1:
When a alter the read in model using the EMF generated editor and save it,
the <![CDATA[]]> disappeared in the XML file.
Strange behavior #2:
Using an XML or text editor I remove the <documentation>-tags and then
reopen the XML file using my EMF model editor. There I set the
documentation feature's value to "<![CDATA[Some <really> fönny and wíred
text with lots of special chars.]]>" and save the file. Now, the '<' get
transformed to "%lt;", however, not so the '>' symbols. Additionally, the
special characters are transformed to some UTF-8 encoding. What's
definitely no good, is that the just saved file cannot be opened with the
EMF editor anymore.
Can anybody give me a hint on how to read in the CDATA stuff into my
model's documentation feature without loosing the "<![CDATA[" and "]]>"
characters?
Any help is appreciated.
I'm using Eclipse Version: 3.4.1 with EMF Ecore 2.4.1.
Thx for reading,
Rob
Re: Reading CDATA content into an EMF model [message #425905 is a reply to message #425897] Thu, 11 December 2008 09:51 Go to previous messageGo to next message
--------------050406030005040807050901
Robert,
Long time no see...
Comments below.
> <node name="Foo">
> </node>
> </rn:structure>
> name="documentation" upperBound="-1"
> </eClassifiers>
> something wrong in the Ecore-file. When opening the above XML model
> with my generated Editor, EMF reads in the value of the CDATA as
> desired. In the properties view I see "Some text with lots of special
> chars." as value of the documentation feature.
> it, the <![CDATA[]]> disappeared in the XML file.
Yes, the final EMF model has no idea whether the data was specified
using CDATA or entities.
Re: Reading CDATA content into an EMF model [message #425930 is a reply to message #425905] Fri, 12 December 2008 04:33 Go to previous messageGo to next message
Ed,
Yes, long time no see. But I've been following your "Ed-around-the-world"
tour on your blog. ;-)
Answers and questions below.
Ed Merks wrote:
> Robert,
> Long time no see...
> Comments below.
>> <?xml version="1.0" encoding="UTF-8"?>
>> <node name="Foo">
>> </node>
>> </rn:structure>
>> </eClassifiers>
>> wíred text with lots of special chars.]]>" and save the file. Now, the
>> '<' get transformed to "%lt;", however, not so the '>' symbols.
> Yes, it's not actually necessary to escape the closing '>' in an
> attribute value.
Confirmed.
> Doesn't EMF write out a value as an attribute by default.
Is this actually a question? If so: In my case I did the trick by
specifying upper bound = -1 resulting the attribute being written out as a
child tag instead of an attribute of the parent tag.
>> Additionally, the special characters are transformed to some UTF-8
>> encoding. What's definitely no good, is that the just saved file
>> cannot be opened with the EMF editor anymore.
> There are some characters that simply aren't allowed in XML at all.
> Like the zero byte ASCII character.
Okay, I'll provide this to the black box developers just to make sure.
>> "]]>" characters?
> This option might produce what you want:
> * Serialized element content that needs escaping and doesn't
> contain <code>"]]>"</code>, will be escaped using CDATA.
> * The default value is false.
> * @since {@link #OPTION_SKIP_ESCAPE}
> * @since 2.4
> String OPTION_ESCAPE_USING_CDATA = "ESCAPE_USING_CDATA";
I've read about this option somewhere else yesterday. However, I didn't
find the right place to set it. Can I do this in the genmodel, or do I
need to modify a generated class or else?
> Is the actual model derived from a schema and you're using the generated
> resource for load and save?
I designed an ecore file via reverse engineering since there's no schema
available for the model. But we do use the generated resource for load in
combination with oaW to generate an Xtext editor.
Since I'm able to read in the CDATA stuff everything's okay for now. I was
just evaluating how to save the resource as that's a very likely
requirement that may come up by our customer in the near future.
>> Thx for reading,
>> Rob
Re: Reading CDATA content into an EMF model [message #425942 is a reply to message #425930] Fri, 12 December 2008 16:49 Go to previous messageGo to next message
Robert,
Comments below.
Robert Wloch wrote:
> Ed,
> "Ed-around-the-world" tour on your blog. ;-)
> Ed Merks wrote:
>> Robert,
>> Long time no see...
>> Comments below.
>>> <node name="Foo">
>>> </node>
>>> </rn:structure>
>>> model's documentation feature. The relevant Ecore model part is as
>>> follows:
>>> </eClassifiers>
>>> special chars." as value of the documentation feature.
>>> save it, the <![CDATA[]]> disappeared in the XML file.
>>> then reopen the XML file using my EMF model editor. There I set the
>>> the '<' get transformed to "%lt;", however, not so the '>' symbols.
>> attribute value.
> Confirmed.
> as a child tag instead of an attribute of the parent tag.
Yes, multi-valued features will by default be elements...
>>> "]]>" characters?
>> * @since 2.4
> didn't find the right place to set it. Can I do this in the genmodel,
> or do I need to modify a generated class or else?
You'd generally modify the generated XyzResourceFactoryImpl. If you
don't have one, you'd change the GenPackage's Resource Type, delegate
the plugin.xml so it's regenerated, and regenerate so you do have one.
>> generated resource for load and save?
> schema available for the model. But we do use the generated resource
> for load in combination with oaW to generate an Xtext editor.
> was just evaluating how to save the resource as that's a very likely
No application should ever care whether CDATA or entities. Users might
be bothered, but applications shouldn't care...
>>> Thx for reading,
>>> Rob
Re: Reading CDATA content into an EMF model [message #425976 is a reply to message #425942] Mon, 15 December 2008 03:17 Go to previous messageGo to next message
Thanks for your help an clarification, Ed!
Re: Reading CDATA content into an EMF model [message #426049 is a reply to message #425976] Mon, 15 December 2008 07:34 Go to previous messageGo to next message
I have a same problem reading the comments in a xml file. When I read a
XML file using the EMF generated editor and save it, all the comments
disappeared in the XML file saved. Do you know how could I keep the
comments?
Thanks a lot
Mabu
Re: Reading CDATA content into an EMF model [message #426053 is a reply to message #426049] Mon, 15 December 2008 07:52 Go to previous messageGo to next message
Mabu,
Comments will only be preserved within complex types with mixed content
and only then within the mixed content itself.
Mabu wrote:
> Hi
> read a XML file using the EMF generated editor and save it, all the
> comments disappeared in the XML file saved. Do you know how could I
> keep the comments?
> Thanks a lot
> Mabu
Re: Reading CDATA content into an EMF model [message #426060 is a reply to message #426053] Mon, 15 December 2008 09:13 Go to previous messageGo to next message
Could you explain about it a bit more. Do you have an example ?
Re: Reading CDATA content into an EMF model [message #426066 is a reply to message #426060] Mon, 15 December 2008 10:50 Go to previous messageGo to next message
--------------080109050101030600050203
Mabu,
This article will likely help:
Binding XML to Java
< http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava>
<html>
<head>
http-equiv="Content-Type">
</head>
Mabu,<br>
<br>
This article will likely help:<br>
<blockquote><a target="_out"
href=" http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava">Binding
XML to Java</a><br>
</blockquote>
<br>
Mabu wrote:
<blockquote
cite="mid:fa8f618629aed7ea97dfa473ac375134$1@www.eclipse.org"
type="cite">Could you explain about it a bit more. Do you have an
example ? <br>
</blockquote>
</body>
</html>
--------------080109050101030600050203--
Re: Reading CDATA content into an EMF model [message #426074 is a reply to message #426060] Mon, 15 December 2008 11:40 Go to previous messageGo to next message
I found the solution, just add the attribute mixed="true" in the schema
and re-generate it. Thanks
Re: Reading CDATA content into an EMF model [message #426076 is a reply to message #426074] Mon, 15 December 2008 12:33 Go to previous messageGo to next message
Mabu,
Alternatively you can use ecore:mixed="true" so you don't actually
change the schema itself.
> schema and re-generate it. Thanks
Re: Reading CDATA content into an EMF model [message #427624 is a reply to message #425905] Tue, 24 February 2009 12:14 Go to previous messageGo to next message
Ed Merks wrote:
> Robert,
> Long time no see...
> Comments below.
>> <node name="Foo">
>> </node>
>> </rn:structure>
>> </eClassifiers>
I have the same problem: I add CDATA to the FeatureMap, save xml, then
load it and result FeatureMap loose information about CDATA. I don't
completely understand why it is correct, and why EMF couldn't determine
that data is specified using CDATA, because text and CDATA is a
different node types. And strictly speaking saved and loaded documents
are not equal (at least in terms of XMLUnit).
Thanks in advance,
Alexey
Re: Reading CDATA content into an EMF model [message #427625 is a reply to message #427624] Tue, 24 February 2009 12:40 Go to previous messageGo to next message
--------------090208050105040804030501
Do you have this XMLResource option mapped true in the resource factory
used to create your resource?
* Determines whether comments and CDATA will be preserved in any
mixed text processing.
* This option is applicable for loading XML resources (from DOM
node or an InputStream)
String OPTION_USE_LEXICAL_HANDLER = "USE_LEXICAL_HANDLER";
koloale wrote:
> Hello,
> Ed Merks wrote:
>> Robert,
>> Long time no see...
>> Comments below.
>>> <node name="Foo">
>>> </node>
>>> </rn:structure>
>>> follows:
>>> </eClassifiers>
> determine that data is specified using CDATA, because text and CDATA
> is a different node types. And strictly speaking saved and loaded
> documents are not equal (at least in terms of XMLUnit).
> Thanks in advance,
> Alexey
<html>
<head>
</head>
used to create your resource?<br>
<blockquote>
Re: Reading CDATA content into an EMF model [message #427637 is a reply to message #427625] Wed, 25 February 2009 02:20 Go to previous message
Oh, I'm sorry I didn't have this option set true. Thank you Ed.
> koloale wrote:
>> Hello,
>> Ed Merks wrote:
>>> Robert,
>>> Long time no see...
>>> Comments below.
>>>> <node name="Foo">
>>>> </node>
>>>> </rn:structure>
>>>> follows:
>>>> </eClassifiers>
>> Thanks in advance,
>> Alexey
Previous Topic:How to create custom constructors of model objects ?
Next Topic:[CDO] ERROR: Could not find feature CDOFeature ...
Current Time: Sun Jul 20 19:51:31 EDT 2025
Powered by FUDForum. Page generated in 0.07507 seconds
