Home » Modeling » EMF » Auto-create node's children
Auto-create node's children [message #425960] Sat, 13 December 2008 15:45 Go to next message
Originally posted by: nuclearpsyche.gmail.com
When a user adds a node to the tree I would like that node to
automatically create two children for itself.
Where do I put the code that does this?
I want this to only happens the first time the node is created.
Thank you,
tamer
Re: Auto-create node's children [message #425962 is a reply to message #425960] Sat, 13 December 2008 18:31 Go to previous messageGo to next message
Tamer,
Comments below.
Tamer wrote:
You can specialize the collectNewChildDescriptors of the parent; note
that there is no need to use commands to create the initial instance
being added, i.e., you can just create a new object, initialize it
however you want, and pass it along as the new child to be created.
> Thank you,
> tamer
Re: Auto-create node's children [message #425963 is a reply to message #425962] Sat, 13 December 2008 23:34 Go to previous messageGo to next message
Hi Ed,
Thank you for your response. I had some trouble applying what you said.
It seems like the function you mentioned gets called each time the node
is selected -- not when it is created. I want to run the code that
creates the children when the parent is created.
Also I don't see exactly how to pass the created children instead of
using an AddCommand.
Thanks again for your help.
tamer
Ed Merks wrote:
> Tamer,
> Comments below.
> Tamer wrote:
>> Hi,
>> Thank you,
>> tamer
Re: Auto-create node's children [message #425964 is a reply to message #425963] Sun, 14 December 2008 03:51 Go to previous messageGo to next message
Tamer,
Please note also that it's usually a bad idea to add automatic child
creation to objects on the model level.
This causes problem when you deserialize a model resource (duplicated
nodes).
This has been discussed here several times, e.g.
http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg2 6718.html
Cheers
/Eike
Tamer schrieb:
> Hi Ed,
> said. It seems like the function you mentioned gets called each time
> the node is selected -- not when it is created. I want to run the code
> that creates the children when the parent is created.
> tamer
> Ed Merks wrote:
>> Tamer,
>> Comments below.
>> Tamer wrote:
>>> Hi,
>>> Thank you,
>>> tamer
Re: Auto-create node's children [message #425965 is a reply to message #425964] Sun, 14 December 2008 08:50 Go to previous messageGo to next message
--------------090501050901000505040004
Guys,
Comments below.
Eike Stepper wrote:
> Tamer,
Definitely that's going to cause problems.
> nodes).
Deserializers and copiers just aren't going to work.
> Cheers
> /Eike
> http://thegordian.blogspot.com
> Tamer schrieb:
>> Hi Ed,
Yes, it's done as part of preparing the command.
>> I want to run the code that creates the children when the parent is
>> created.
You have to go one level up then. The parent is created under the grand
parent. Evey time a grand parent is selected, the commands for creating
children for it will be created and tested for executability to populate
the menu. At that point you can create the "parent", the child of the
"grand parent", and populate it with "children", grand children of the
grand parent.
Here's an example from EGenericTypeItemProvider where we want to allow
upper and lower bound children to be created only if this generic type
is type argument of another generic type and we want to allow type
arguments to be created only if this generic type has a classifier with
type parameters.
* This adds {@link
org.eclipse.emf.edit.command.CommandParameter}s describing the children
* that can be created under this object.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated NOT
protected void collectNewChildDescriptors(Collection<Object>
newChildDescriptors, Object object)
super.collectNewChildDescriptors(newChildDescriptors, object);
EGenericType eGenericType = (EGenericType)object;
if (eGenericType.eContainmentFeature() ==
EcorePackage.Literals.EGENERIC_TYPE__ETYPE_ARGUMENTS &&
eGenericType.getEClassifier() == null &&
eGenericType.getETypeParameter() == null)
newChildDescriptors.add
(createChildParameter
(EcorePackage.Literals.EGENERIC_TYPE__EUPPER_BOUND,
EcoreFactory.eINSTANCE.createEGenericType()));
(EcorePackage.Literals.EGENERIC_TYPE__ELOWER_BOUND,
if (eGenericType.getEClassifier() != null &&
!eGenericType.getEClassifier().getETypeParameters().isEmpty( ))
(EcorePackage.Literals.EGENERIC_TYPE__ETYPE_ARGUMENTS,
It doesn't show prepopulation of the new object, but the new generic
type being created could have features set on it if that's what I'd
wanted...
>> tamer
>> Ed Merks wrote:
>>> Tamer,
>>> Comments below.
>>> Tamer wrote:
>>>> Hi,
>>> note that there is no need to use commands to create the initial
>>> instance being added, i.e., you can just create a new object,
>>> initialize it however you want, and pass it along as the new child
>>> to be created.
>>>> Thank you,
>>>> tamer
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Guys,<br>
<br>
Comments below.<br>
<br>
Eike Stepper wrote:
<blockquote cite="mid:gi2hdp$d3o$1@build.eclipse.org" type="cite">Tamer,
<br>
<br>
<br>
</blockquote>
Definitely that's going to cause problems.<br>
<blockquote cite="mid:gi2hdp$d3o$1@build.eclipse.org" type="cite">This
nodes).
<br>
</blockquote>
Deserializers and copiers just aren't going to work.<br>
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg2 6718.html"> http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg2 6718.html</a>
<br>
<br>
Cheers
<br>
/Eike
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a>
<br>
<br>
<br>
<br>
Tamer schrieb:
<br>
<blockquote type="cite">Hi Ed,
<br>
<br>
is selected -- not when it is created. </blockquote>
</blockquote>
Yes, it's done as part of preparing the command.<br>
<blockquote type="cite">I want to run the code that creates the
<br>
</blockquote>
</blockquote>
You have to go one level up then.&nbsp; The parent is created under the
grand parent.&nbsp; Evey time a grand parent is selected, the commands for
creating children for it will be created and tested for executability
to populate the menu.&nbsp; At that point you can create the "parent", the
child of the "grand parent", and populate it with "children", grand
children of the grand parent. <br>
<blockquote type="cite">Also I don't see exactly how to pass the
created children instead of using an AddCommand.
<br>
</blockquote>
</blockquote>
type parameters.<br>
<blockquote><small>&nbsp; /**</small><br>
<small>&nbsp;&nbsp; * This adds {@link
org.eclipse.emf.edit.command.CommandParameter}s describing the children</small><br>
<small>&nbsp;&nbsp; * that can be created under this object.</small><br>
<small>&nbsp;&nbsp; * &lt;!-- begin-user-doc --&gt;</small><br>
<small>&nbsp;&nbsp; * &lt;!-- end-user-doc --&gt;</small><br>
<small>&nbsp;&nbsp; * @generated NOT</small><br>
<small>&nbsp;&nbsp; */</small><br>
<small>&nbsp; @Override</small><br>
<small>&nbsp; protected void
collectNewChildDescriptors(Collection&lt;Object&gt;
newChildDescriptors, Object object)</small><br>
<small>&nbsp; {</small><br>
<small>&nbsp;&nbsp;&nbsp; super.collectNewChildDescriptors(newChildDescriptors,
object);</small><br>
<br>
<small>&nbsp;&nbsp;&nbsp; EGenericType eGenericType = (EGenericType)object;</small><br>
<br>
<small>&nbsp;&nbsp;&nbsp; if (eGenericType.eContainmentFeature() ==
EcorePackage.Literals.EGENERIC_TYPE__ETYPE_ARGUMENTS &amp;&amp;</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; eGenericType.getEClassifier() == null &amp;&amp; </small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; eGenericType.getETypeParameter() == null)</small><br>
<small>&nbsp;&nbsp;&nbsp; {</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; newChildDescriptors.add</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; (createChildParameter</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; (EcorePackage.Literals.EGENERIC_TYPE__EUPPER_BOUND,</small> <br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; EcoreFactory.eINSTANCE.createEGenericType()));</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; (EcorePackage.Literals.EGENERIC_TYPE__ELOWER_BOUND,</small> <br>
<small>&nbsp;&nbsp;&nbsp; }</small><br>
<br>
<small>&nbsp;&nbsp;&nbsp; if (eGenericType.getEClassifier() != null &amp;&amp;
!eGenericType.getEClassifier().getETypeParameters().isEmpty( )) </small><br>
(EcorePackage.Literals.EGENERIC_TYPE__ETYPE_ARGUMENTS,</small ><br>
<small>&nbsp; }</small><br>
</blockquote>
wanted...<br>
<blockquote type="cite"><br>
<br>
<br>
tamer
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Tamer,
<br>
<br>
Comments below.
<br>
<br>
<br>
Tamer wrote:
<br>
<blockquote type="cite">Hi,
<br>
<br>
<br>
<br>
</blockquote>
<br>
<blockquote type="cite">I want this to only happens the first
<br>
Thank you,
<br>
<br>
tamer
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------090501050901000505040004--
Re: Auto-create node's children [message #425968 is a reply to message #425965] Sun, 14 December 2008 13:34 Go to previous messageGo to next message
Thank you both for your response. I appreciate your input/help.
Would it be a better idea to customize notifyChanged() method of the
parent to check for
if(notification.getEventType()==Notification.ADD)
And then create the children then? Or is that problematic?
Thank you!
tamer
Ed Merks wrote:
> Guys,
> Comments below.
> Eike Stepper wrote:
>> Tamer,
>> nodes).
>> Cheers
>> /Eike
>> Tamer schrieb:
>>> Hi Ed,
>>> created.
> grand parent.
> type parameters.
> * This adds {@link
> * @generated NOT
> @Override
> wanted...
>>> tamer
>>> Ed Merks wrote:
>>>> Tamer,
>>>> Comments below.
>>>> Tamer wrote:
>>>>> Hi,
>>>> to be created.
>>>>> Thank you,
>>>>> tamer
Re: Auto-create node's children [message #425970 is a reply to message #425968] Sun, 14 December 2008 14:52 Go to previous messageGo to next message
Tamer,
Comments below.
> parent to check for
Don't do anything directly in the model in this regard. The item
provider is the place where new children are created and that's exactly
the one and only place you should be creating prepopulated additions.
I'm not quite sure why you don't just try what's already been suggested...
> Thank you!
> tamer
> Ed Merks wrote:
>> Guys,
>> Comments below.
>> Eike Stepper wrote:
>>> Tamer,
>>> (duplicated nodes).
>>> Cheers
>>> /Eike
>>> Tamer schrieb:
>>>> Hi Ed,
>>>> time the node is selected -- not when it is created.
>>>> created.
>> grand parent. Evey time a grand parent is selected, the commands for
>> to populate the menu. At that point you can create the "parent", the
>> allow upper and lower bound children to be created only if this
>> generic type is type argument of another generic type and we want to
>> allow type arguments to be created only if this generic type has a
>> classifier with type parameters.
>> * This adds {@link
>> children
>> * @generated NOT
>> @Override
>> wanted...
>>>> tamer
>>>> Ed Merks wrote:
>>>>> Tamer,
>>>>> Comments below.
>>>>> Tamer wrote:
>>>>>> Hi,
>>>>> to be created.
>>>>>> Thank you,
>>>>>> tamer
Re: Auto-create node's children [message #425971 is a reply to message #425970] Sun, 14 December 2008 15:16 Go to previous messageGo to next message
Hi Ed,
I tried what you suggested but I actually use an EMF/GMF combined
editor. So the solution works from the tab of my editor where I have the
model displayed as a tree but it doesn't work from the diagram tab.
I'm also using a transactional editing domain so maybe that's why I have
to use AddCommands to populate the node's children.
tamer
Ed Merks wrote:
> Tamer,
> Comments below.
>> parent to check for
>> Thank you!
>> tamer
>> Ed Merks wrote:
>>> Guys,
>>> Comments below.
>>> Eike Stepper wrote:
>>>> Tamer,
>>>> (duplicated nodes).
>>>> Cheers
>>>> /Eike
>>>> Tamer schrieb:
>>>>> Hi Ed,
>>>>> created.
>>> * This adds {@link
>>> children
>>> * @generated NOT
>>> @Override
>>> wanted...
>>>>> tamer
>>>>> Ed Merks wrote:
>>>>>> Tamer,
>>>>>> Comments below.
>>>>>> Tamer wrote:
>>>>>>> Hi,
>>>>>> to be created.
>>>>>>> Thank you,
>>>>>>> tamer
Re: Auto-create node's children [message #425973 is a reply to message #425971] Sun, 14 December 2008 19:57 Go to previous message
Tamer,
In GMF there is some type of "creation tool". I'm not sure how that
works, but it's probably something similar that you can specialize.
I don't think the editing domain can know about newly created objects
until you attach them to a parent, so I doubt editing domains are an
issue. Keep in mind that an AddCommand is used when you do, for
example, a copy and paste, or drag and drop to move something to a
different parent in the tree, so it's highly unlikely that specializing
AddCommand will not result in desirable side-effects.
Tamer wrote:
> Hi Ed,
> the model displayed as a tree but it doesn't work from the diagram tab.
> have to use AddCommands to populate the node's children.
> Best regards,
> tamer
> Ed Merks wrote:
>> Tamer,
>> Comments below.
>>> parent to check for
>> exactly the one and only place you should be creating prepopulated
>> additions. I'm not quite sure why you don't just try what's already
>> been suggested...
>>> Thank you!
>>> tamer
>>> Ed Merks wrote:
>>>> Guys,
>>>> Comments below.
>>>> Eike Stepper wrote:
>>>>> Tamer,
>>>>> child creation to objects on the model level.
>>>>> (duplicated nodes).
>>>>> Cheers
>>>>> /Eike
>>>>> Tamer schrieb:
>>>>>> Hi Ed,
>>>>>> is created.
>>>> for creating children for it will be created and tested for
>>>> executability to populate the menu. At that point you can create
>>>> the "parent", the child of the "grand parent", and populate it with
>>>> "children", grand children of the grand parent.
>>>> to allow type arguments to be created only if this generic type has
>>>> a classifier with type parameters.
>>>> * This adds {@link
>>>> children
>>>> * @generated NOT
>>>> @Override
>>>> generic type being created could have features set on it if that's
>>>> what I'd wanted...
>>>>>> tamer
>>>>>> Ed Merks wrote:
>>>>>>> Tamer,
>>>>>>> Comments below.
>>>>>>> Tamer wrote:
>>>>>>>> Hi,
>>>>>>>> Thank you,
>>>>>>>> tamer
Previous Topic:ECore Editor not displaying as model tree
Next Topic:[CDO] CDOObject containment problems
Current Time: Sun Jul 20 17:59:41 EDT 2025
Powered by FUDForum. Page generated in 0.05652 seconds
