Home » Modeling » EMF » [CDO] Proxies / Lazy Loading
[CDO] Proxies / Lazy Loading [message #425953] |
Sat, 13 December 2008 09:12  |
Hello again.
If I understand it right, CDO takes care about the lazy loading. Is this
completely independent from the persistence store (e.g. DerbyStore or
Teneo) used in the background?
What exaclty can be lazy loaded?
For example, let's assume the simple model in pseudo code like this:
class Document {
String small;
String large;
And now let's assume that I have 100000 documents of that type and want
to load all those documents into one table, but only want to show the
"small" string. The "large" string will only be accessed, when clicking
directly on one document. And now let's also assume that the whole
100000 documents won't fit into memory cause of the huge data contained
inside the "large" fields.
Will "large" be lazy loaded? (With Hibernate normal attributes by
default won't be lazy loaded.)
If not, would the following design help to use lazy loading for "large"
also in CDO? (It would help within Hibernate).
class Document {
String small;
LargeObject largeObject;
class LargeObject {
String large;
Kai
Re: [CDO] Proxies / Lazy Loading [message #425954 is a reply to message #425953] |
Sat, 13 December 2008 09:19   |
Kai,
Comments below...
Kai Schlamp schrieb:
> Hello again.
> this completely independent from the persistence store (e.g.
> DerbyStore or Teneo) used in the background?
Yes, completely independent.
All references, i.e. single-valued, many-valued, cross references,
containments...
> class Document {
> String small;
> String large;
> want to load all those documents into one table, but only want to show
> the "small" string. The "large" string will only be accessed, when
> clicking directly on one document. And now let's also assume that the
> whole 100000 documents won't fit into memory cause of the huge data
> contained inside the "large" fields.
No, CDO does currently not support lazy loading of single *attributes*.
What about making "large" a derived feature that is computed from a
contained data object?
> "large" also in CDO? (It would help within Hibernate).
> class Document {
> String small;
> class LargeObject {
> String large;
Oh yes, this is what I had in mind above ;-)
Cheers
/Eike
Re: [CDO] Proxies / Lazy Loading [message #425955 is a reply to message #425953] |
Sat, 13 December 2008 09:28   |
--------------090804070001060707050000
Kai,
By the way, if all your 100000 Document objects are contained in one
list, it could also be good to set a collection loading policy into the
session options:
| *public **void *testOpenSession() *throws *Exception
CDOSession session = openModel1Session();
CDOCollectionLoadingPolicy policy = CDOUtil.createCollectionLoadingPolicy(0, 100);
session.options().setCollectionLoadingPolicy(policy);
This one initially loads no target IDs into objects. Later, when a list
element is accessed, a maximum range of 100 elements *around* the
accessed list index are loaded if necessary.
Cheers
/Eike
> Hello again.
> class Document {
> String small;
> String large;
> class Document {
> String small;
> class LargeObject {
> String large;
> Best regards,
> Kai
<html>
<head>
http-equiv="Content-Type">
</head>
Kai,<br>
<br>
session options:<br>
<br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<!-- = Java Sourcecode to HTML automatically converted code = --><!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = -->
<!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3" cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td align="left" nowrap="nowrap"
valign="top"> <code><font color="#ffffff">
Re: [CDO] Proxies / Lazy Loading [message #425956 is a reply to message #425954] |
Sat, 13 December 2008 09:48   |
Hy Eike,
thanks a lot for the lightning fast answer.
A last question about that topic.
Let's get back to the table scenario with the little example model at
the bottom.
When I want to only show documents in the table that contain a specific
search string in the "large" attribute of LargeObject, all LargeObject
objects must be fetched (as there is no query solution in CDO 1.0.x), to
test if those contain the search string. Are already tested LargeObjects
garbage collected again and the largeObject attribute of Document set
back to the appropriate proxy? Cause otherwise the whole model would not
fit in the available memory.
I read somewhere that CDO (in contrast to Hibernate) supports this. Is
that right? Automatically without having me to do something?
Kai
Eike Stepper schrieb:
> Kai,
> Comments below...
>> Hello again.
> containments...
>> class Document {
>> String small;
>> String large;
>> class Document {
>> String small;
>> class LargeObject {
>> String large;
> Cheers
> /Eike
> http://thegordian.blogspot.com
Re: [CDO] Proxies / Lazy Loading [message #425957 is a reply to message #425955] |
Sat, 13 December 2008 10:11   |
Thanks for the tip, Eike.
Is this policy also available in CDO 1.0.x?
As in the docs
(http://download.eclipse.org/modeling/emf/cdo/javadoc/1.0.0/) I don't
see such a create method of CDOUtil, nor a class called
CDOCollectionLoadingPolicy.
Perhaps I switch to CDO 2.0.0 soon. I tried this once, but it didn't
seem to be so easy as there were some conflicts with plugins of the
Eclipse 3.4.1 Ganymede release (is there somewhere a little installation
instruction for CDO 2.0.0 + Eclipse Ganymede?) . But I will retry this,
at the latest when there is a query implementation (hql, sql, whatever)
for CDO 2.0.0.
Thanks a lot for your help.
Kai
> Kai,
> session options:
> Cheers
> /Eike
>> Hello again.
>> class Document {
>> String small;
>> String large;
>> class Document {
>> String small;
>> class LargeObject {
>> String large;
>> Best regards,
>> Kai
Re: [CDO] Proxies / Lazy Loading [message #425958 is a reply to message #425956] |
Sat, 13 December 2008 12:51   |
Kai,
Comments below...
> Hy Eike,
You're welcome ;-)
> the bottom.
> specific search string in the "large" attribute of LargeObject, all
> LargeObject objects must be fetched (as there is no query solution in
> CDO 1.0.x), to test if those contain the search string. Are already
> tested LargeObjects garbage collected again and the largeObject
> attribute of Document set back to the appropriate proxy?
Yes, that's the expected behaviour.
> Cause otherwise the whole model would not fit in the available memory.
Yes, it's incredible :P
Cheers
/Eike
> Best regards,
> Kai
>> Kai,
>> Comments below...
>>> Hello again.
>> containments...
>>> class Document {
>>> String small;
>>> String large;
>>> show the "small" string. The "large" string will only be accessed,
>>> when clicking directly on one document. And now let's also assume
>>> that the whole 100000 documents won't fit into memory cause of the
>>> huge data contained inside the "large" fields.
>>> class Document {
>>> String small;
>>> class LargeObject {
>>> String large;
>> Cheers
>> /Eike
Re: [CDO] Proxies / Lazy Loading [message #425959 is a reply to message #425957] |
Sat, 13 December 2008 12:55  |
> As in the docs
Apologies!!! I forgot for a moment that you are not using our wonderful
new version ;-)
> installation instruction for CDO 2.0.0 + Eclipse Ganymede?) .
No, because this setup is not officially supported. Users have reported
that it works, but it's on your own risk!
> But I will retry this, at the latest when there is a query
> implementation (hql, sql, whatever) for CDO 2.0.0.
It's moving up ;-)
Cheers
/Eike
Current Time: Sun Jul 20 13:31:17 EDT 2025
Powered by FUDForum. Page generated in 0.04966 seconds
