Home » Modeling » EMF » non containment references to large data sets
non containment references to large data sets [message #425805] |
Mon, 08 December 2008 19:22  |
Take an example model like
<eClassifiers xsi:type="ecore:EClass" name="Transaction">
<eStructuralFeatures xsi:type="ecore:EReference" name="buyer"
eType="#//Person"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="seller"
eType="#//Person"/>
</eClassifiers>
where the buyer and seller references are non containment references to
Person and each Person comes from a large data base of people.
There are really two types of data here: transactional data; and static
data (i.e. Person).
The data set for Person is too large to hold in memory. Instead we
maintain a cache of loaded Persons.
When we serialise Transactions out into resources the Person objects must
be contained within another resource in that resource set.
The problem is that we process a lot of transactions and we don't really
want to hold onto them in a resource once we finished processing them as
this will just fill up memory.
We can simply toss the resource set at that point but that would toss the
cached Person objects.
Is there some way to chain up resource sets so that we can keep all the
cached Person objects in one resource set then create new resource sets
for each transaction and point that resource set to the shared Person
resource set?
Any advice on how best to manage data like this where we are primarily
focussed on processing transactional data which is associated with static
data from large data sets?
Re: non containment references to large data sets [message #425884 is a reply to message #425882] |
Wed, 10 December 2008 23:44   |
I evaluated Teneo about a month ago and was impressed with it. We plan to
use it when we do our new persistence in the next phase of the project.
However, one thing that I am yet to resolve is how to handle our static
data. Our transactional data will refer to the static data but when it
serialises we will serialise only references to static data. This means
any parts of our system that manipulate these transactions will need a
mechanism to resolve the static data again.
The reason we don't want to serialise the static data with the
transactional data is that the full object graph for the static data might
be huge. For example take a simple model where a Department has a list of
Person's which is a containment relationship. If we associate the
Department with a Transaction then you can reach all the Person's (eg.
>100,000) from the Department. So if this whole tree was serialised we'd
send the whole database across the wire.
To avoid this we plan to use the Resource mechanism in EMF. Another
approach might be to use Hibernates proxy mechanism here.
All that is for the next phase but I ran into an issue that I need to
resolve now. Because the relationships to the static data are non
containment (for the above reasons) then when I go to serialise a
transaction (e.g. to print it out) it fails cause the static data is not
in a resource.
I was hoping that for now I could do something simple that aligns with
what we will do for the next phase which is why I asked this question.
But I think its to big an issue for now so I am going with a cludgy
workaround.
jason henriksen wrote:
> We use Teneo. Teneo is excellent because it takes your EMF objects and
> persists them into a database via Hibernate. It works really well.
> It's an eclipse project, but you can find out more here:
> http://elver.org/hibernate/index.html
> Also, I'm wondering if you're running into a containment problem.
> Also:
> Is your Cache also an EMF object? If so, you might be having a problem
> with EMF's containment modeling.
> Jason
> Andrew H wrote:
>> To be honest, exactly how we will manage this is not yet determined. We
>> are migrating our application to EMF in a phased approach. Persistence
>> will be the next phase. However, in this phase I need to deal with the
>> fact that the transaction needs to link to the static data in a non
>> containment way which is causing me issues when I serialise the
>> transaction (mainly for debugging).
>> Hibernate caching is what I am expecting to use to cache the static
>> data, but I wasn't sure how that plays with Resources.
>> How are you using the two together? And how does that cope with if the
>> same cached object is needed on two threads at the same time? What
>> resource would that object live in? Or do you have a copy per thread?
>> cheers
>> Andrew
>>> > the cached Person objects.
>>> Out of curiosity, why does that happen? We use hibernate's cache and
>>> it seems to hold on to the right stuff. We have on Resource per
>>> thread that we fill it with stuff, serialize the stuff and then clear
>>> out the resource at the end of each request. That seems to work for us.
>>> (Or is it not working optimally and we haven't discovered it yet?
>>> Hmm....)
>>> Jason
>>>> eType="#//Person"/>
>>>> eType="#//Person"/>
>>>> </eClassifiers>
>>>> to Person and each Person comes from a large data base of people.
>>>> static data (i.e. Person).
>>>> must be contained within another resource in that resource set.
>>>> really want to hold onto them in a resource once we finished
>>>> processing them as this will just fill up memory.
>>>> the cached Person objects in one resource set then create new
>>>> resource sets for each transaction and point that resource set to the
>>>> shared Person resource set?
>>>> primarily focussed on processing transactional data which is
>>>> associated with static data from large data sets?
Re: non containment references to large data sets [message #425889 is a reply to message #425885] |
Thu, 11 December 2008 03:11   |
Andrew,
Comments below...
Andrew H schrieb:
> Thanks Eike
> Our plans were to use Teneo for persistence but I may review that
> given that SDO may help with some of our static data issues.
I bet it's just a typo but CDO is *not* SDO!
> Can CDO and Teneo be used together?
Yes, as Tom pointed out, we have a Teneo-based Hibernate backend
integration. Martin Taal and I developed it.
> It will be a couple of months before we hit the persistence phase of
> our project so I will defer the eval till then.
I'll be here ;-)
Cheers
/Eike
> cheers
> Andrew
> Eike Stepper wrote:
>> Andrew,
>> Just one more side note. With CDO you also have the advantage that
>> you can switch the back-end persistence technology without impacting
>> the application. We're even working on a back-end agnostic query
>> language handler...
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>>> We are migrating our application to EMF in a phased approach.
>>> Persistence will be the next phase. However, in this phase I need to
>>> deal with the fact that the transaction needs to link to the static
>>> data in a non containment way which is causing me issues when I
>>> serialise the transaction (mainly for debugging).
>>> the same cached object is needed on two threads at the same time?
>>> What resource would that object live in? Or do you have a copy per
>>> thread?
>>> cheers
>>> Andrew
>>>> toss
>>>> and it seems to hold on to the right stuff. We have on Resource
>>>> per thread that we fill it with stuff, serialize the stuff and then
>>>> clear out the resource at the end of each request. That seems to
>>>> work for us.
>>>> Hmm....)
>>>> Jason
>>>>> eType="#//Person"/>
>>>>> eType="#//Person"/>
>>>>> </eClassifiers>
>>>>> references to Person and each Person comes from a large data base
>>>>> of people.
>>>>> objects must be contained within another resource in that resource
>>>>> set.
>>>>> toss the cached Person objects.
>>>>> all the cached Person objects in one resource set then create new
>>>>> the shared Person resource set?
Re: non containment references to large data sets [message #425890 is a reply to message #425884] |
Thu, 11 December 2008 03:23   |
Andrew,
Comments below...
> to use it when we do our new persistence in the next phase of the
> project.
> static data. Our transactional data will refer to the static data but
> when it serialises we will serialise only references to static data.
> This means any parts of our system that manipulate these transactions
> will need a mechanism to resolve the static data again.
> might be huge.
This was one of the main reasons to create CDO: Load and save
containment references with the same caharcteristics as cross
references. In CDO there's internally no difference between them. In
other words, you can load objects without their children (and that's the
default) and you can even load children without their parent (through
cross references, queries or by ID).
This enables you at model-design-time to focus on your business aspects
and create containment references where they are logically desired
instead of being influenced already by later persistence/scalability
decisions.
Cheers
/Eike
> we'd send the whole database across the wire.
> not in a resource.
> workaround.
>> and persists them into a database via Hibernate. It works really well.
>> Also:
>> problem with EMF's containment modeling.
>> Jason
>>> thread?
>>> cheers
>>> Andrew
>>>> toss
>>>> work for us.
>>>> Hmm....)
>>>> Jason
>>>>> eType="#//Person"/>
>>>>> eType="#//Person"/>
>>>>> </eClassifiers>
>>>>> of people.
>>>>> set.
Re: non containment references to large data sets [message #425923 is a reply to message #425890] |
Thu, 11 December 2008 18:04   |
Hi Eike
See inline
>> might be huge.
> decisions.
On the surface it certainly sounds like CDO will be very useful to us.
Particularly for our static data. For our transactional data we tend to
send the whole transaction around all the time so a simple EMF / Teneo
solution would probably work well. But anything that processes our
transactions would need to resolve the associated static data and it seems
like CDO would do this nicely.
Just out of curiosity, if it turned out that CDO was a good fit for our
static data but not for our transactional, can that work? i.e. our
transactional models would not be CDO models (just normal EMF) but our
static data ones would be.
I'm not saying this is necessarily likely but would be interested to know
if its an all or nothing proposition.
Also, I noticed there was an audit view capability. That might be very
useful to us to be able to see what the static data looked like when the
transaction was created. Does this work only off timestamps or is there a
way to associate a transaction with a particular version of our static
data?
> Cheers
> /Eike
>> not in a resource.
>> workaround.
>>> Also:
>>> Jason
>>>> thread?
>>>> cheers
>>>> Andrew
>>>>> toss
>>>>> work for us.
>>>>> Hmm....)
>>>>> Jason
>>>>>> eType="#//Person"/>
>>>>>> eType="#//Person"/>
>>>>>> </eClassifiers>
>>>>>> of people.
>>>>>> set.
Re: non containment references to large data sets [message #425927 is a reply to message #425923] |
Fri, 12 December 2008 01:49   |
Andreww,
Comments below...
Andrew H schrieb:
> Hi Eike
> [...] On the surface it certainly sounds like CDO will be very useful
> to us. Particularly for our static data. For our transactional data we
> tend to send the whole transaction around all the time so a simple EMF
> / Teneo solution would probably work well. But anything that processes
> our transactions would need to resolve the associated static data and
> it seems like CDO would do this nicely.
> our static data but not for our transactional, can that work? i.e. our
> know if its an all or nothing proposition.
In CDO 2.0 you can mix different types of Resources in a single
ResourceSet and have cross references between them. It's possible to use
multiple CDOResources (possibly from/to multiple model repositories)
together wit XMLResources, TeneoResource and others.
CDO generally supports these "external" references while some of our
back-end are not yet uptodate with this framework feature. We're
planning to work on this issue until 2.0 GA.
That said, in your case it looks as if you want to reference the static
data (possibly CDO-managed) from the transactional data (possibly
Teneo-managed). Wouldn't that require Teneo to be able to handle these
Teneo-external references?
Of course it's your own decision and I know that Teneo is generally a
good choice, but if you already decide to use CDO for some data, why not
use it for all data. You could still choose different CDO back-end types
for different resources...
> the transaction was created. Does this work only off timestamps or is
> there a way to associate a transaction with a particular version of
> our static data?
Auditing is currently only supported by our proprietary JDBC back-end
adapter (although we discussed support in the other adapters as well). I
guess adding this feature to our Teneo/Hibernate adapter will be a
particular challenge ;-)
Regarding timestamps and versions in historical data, CDO works like
this: Each committed transaction creates a set of revisions for the new
and changed objects. The ID of such a transaction (== revision set) is
the timestamp of the commit operation. Each revision carries its own
version number together with the timestamps of two transactions, the one
that created the revision and the one that created the following
revisions (valid from -> until).
You could for any EObject determine the validity range (e.g. the
creation time) and then open an audit view to look at the whole object
graph as it was exactly at that time.
Cheers
/Eike
Re: non containment references to large data sets [message #425969 is a reply to message #425927] |
Sun, 14 December 2008 14:16   |
Hi Andrew,
For your info, currently Teneo does not out-of-the-box support external references to other objects
persisted by other persistence engines. You can make references transient (using an annotation) to
prevent them from being persisted in the database and then use some other string field to persist
the uri. But this can be improved I think.
So triggered by this discussion (and that the same thing has come up before) I have started to
implement a special annotation @URI which makes it possible to denote an EReference as an external
reference. This should work for both Teneo standalone and is a good basis for adding the same
support to Teneo embedded in CDO. A first implementation should be in the next build (this week
somewhere).
gr. Martin
Eike Stepper wrote:
> Andreww,
> Comments below...
> Andrew H schrieb:
>> Hi Eike
>> our static data?
> Cheers
> /Eike
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: non containment references to large data sets [message #426126 is a reply to message #425969] |
Tue, 16 December 2008 21:55   |
Thanks Martin
So if we used CDO w Teneo for static data and straight Teneo for
transactional data this is not going to be a seamless experience. i.e. its
not going to be as clean as if we went straight teneo for both or CDO w
Teneo for both?
cheers
Andrew
Martin Taal wrote:
> Hi Andrew,
I have started to
for adding the same
> somewhere).
> gr. Martin
> Eike Stepper wrote:
>> Andreww,
>> Comments below...
>> Andrew H schrieb:
>>> Hi Eike
>>> our static data?
>> Cheers
>> /Eike
Re: non containment references to large data sets [message #426127 is a reply to message #425927] |
Tue, 16 December 2008 21:56   |
Thanks Eike
See inline
Eike Stepper wrote:
> Andreww,
> Comments below...
> Andrew H schrieb:
>> Hi Eike
I agree that it would be preferable to have it all in one place with one
persistence solution. This will certainly be what we will aim for.
When this project kicked off I did an evaluation of several areas of EMF.
This was so that we were comfortable we would have an acceptable answer
for all the things we need to do with our models (GUI, business rules,
transformation, persistence, serialisation to / from XML, use in JEE & Web
services etc).
We are currently in the first phase which is introducing the model itself
and transforming it for integration with various systems. Persistence
isn't till the next phase, but unfortunately I have had to anticipate some
aspects of persistence (next phase) now. These relate to static data.
My evaluation for persistence was done for persisting our transactional
data with Teneo because Teneo is based on hibernate which I know pretty
well is a proven industry approach. This was enough to give the tick to
persistence and for a high level plan. Teneo was an excellent fit for the
transactional data.
Unfortunately, I didn't do a separate evaluation for our static data. I
assumed simply that the same approach would fit well. However, our static
data has some differing requirements to our transactional data.
- transactions tend to be self contained where we hold the entire
transaction in memory and send it around the system in its entirety.
Static data tends to be large and interconnected and we only ever want a
small part of the model in memory.
- Static data needs to be able to be fetched on demand so it can be
reattached to the transactional data as needed. In a way the Resource for
static data needs to provide a virtual window on the the persisted static
data, so that it can resolve any URI's for these objects without needing
to hold the entire database in memory.
We can certainly build support for these requirements on top of Teneo but
I expect that there could be quite a lot of work involved. Work that seems
to already be done by CDO.
So I'm kind of stuck now, where I have an answer for transactional data
persistence that I feel I understand well and am very comfortable with,
but only a potential answer for static data that I don't understand at all
yet.
The only solution is for me to evaluate CDO, but I don't have time right
now. Thanks to your feedback, at least I know a little more now. That
whilst there can be some possibilities of having a CDO solution for static
data and a teneo one for transactional data it is likely to be less than
ideal so the most likely outcome is to choose one over the other.
thanks for your help
>> our static data?
OK good to know.
Right so for a revision of one of our Transactions (sorry to overload the
term here but I'm referring to our transactional data) I could determine
the timestamp for its creation and use that to unambiguously determine the
correct revision for the static data that it is associated with?
cheers
Andrew
Re: non containment references to large data sets [message #426142 is a reply to message #426126] |
Wed, 17 December 2008 04:07   |
Hi Andrew,
It depends on your requirements. The latest Teneo build (30 minutes ago) has a new feature called
External (see below) which maybe of help in combining Teneo and CDO. Here are also some other
thoughts to help you in your questions. Let me know.
There are two ways to use Teneo: standalone (the standard way), embedded within CDO.
Teneo standalone is very good in J2ee/webserver/webservice environments as it allows you to work
with generated model objects on the server so that you can write your custom server-side logic using
those model objects. Teneo with EMF has great value in a webservice environment, Xml/xmi
transformation of EMF combined with persisting using Teneo/Hibernate has a really good fit there.
Other nice Teneo features:
- works with advanced models (ecore itself for example)
- supports most xsd constructs (like choices, union, lists, extension, substitution groups) and all
ecore constructs (featuremaps for example)
- allows you to really fine-tune the relational model to your needs using annotations
- can operate on an existing relational schema (using annotations to match up the model and the
relational schema)
- very unintruisive, Teneo works with your model without changing the genmodel or changing the way
you generate your code
- supports advanced querying through hibernate
Teneo embedded within CDO: here the mapping functionality of Teneo is used so you have advantages of
being able to really influence how the relational schema looks like (using annotations).
Unfortunately the Teneo embedded in CDO functionality is not mature enough at the moment (because of
lack of time on my part). So I would wait for this solution a bit longer.
Then I added a new feature in Teneo which should allow you to work with CDOresources from Teneo
standalone:
The latest maintenance build of Teneo now has support for external references to non-teneo-persisted
objects. See here for more info:
http://www.elver.org/hibernate/hibernate_relations.html#exte rnal
This new feature also allows you to specify your own Hibernate UserType when persisting or loading
references. This allows you to completely customize how the external reference is stored in the
database (if even there) and also how it is resolved when loading the owner from the db.
Let me know if this new annotation helps a bit, and if not what can be changed to make it more usefull.
So with the above I think you can combine static data in CDO with transactional data in Teneo. Or
static data in a custom garbage collecting resource with transactional data in Teneo.
Btw, as I said I think Teneo with EMF has great value in a webservice environment. So if you use
Teneo in that area I am very interested to hear about your experience there. I am also interested in
contributions in that area, so if there are opportunities let me know.
gr. Martin
Andrew H wrote:
> Thanks Martin
> its not going to be as clean as if we went straight teneo for both or
> CDO w Teneo for both?
> cheers
> Andrew
> Martin Taal wrote:
>> Hi Andrew,
>> before)
> I have started to
> for adding the same
>> somewhere).
>> gr. Martin
>> Eike Stepper wrote:
>>> Andreww,
>>> Comments below...
>>> Andrew H schrieb:
>>>> Hi Eike
>>>> useful to us. Particularly for our static data. For our
>>>> transactional data we tend to send the whole transaction around all
>>>> the time so a simple EMF / Teneo solution would probably work well.
>>>> But anything that processes our transactions would need to resolve
>>>> the associated static data and it seems like CDO would do this nicely.
>>>> our transactional models would not be CDO models (just normal EMF)
>>>> but our static data ones would be.
>>> use multiple CDOResources (possibly from/to multiple model
>>> repositories) together wit XMLResources, TeneoResource and others.
>>> static data (possibly CDO-managed) from the transactional data
>>> (possibly Teneo-managed). Wouldn't that require Teneo to be able to
>>> handle these Teneo-external references?
>>> not use it for all data. You could still choose different CDO
>>> back-end types for different resources...
>>>> very useful to us to be able to see what the static data looked like
>>>> when the transaction was created. Does this work only off timestamps
>>>> or is there a way to associate a transaction with a particular
>>>> version of our static data?
>>> well). I guess adding this feature to our Teneo/Hibernate adapter
>>> will be a particular challenge ;-)
>>> new and changed objects. The ID of such a transaction (== revision
>>> set) is the timestamp of the commit operation. Each revision carries
>>> its own version number together with the timestamps of two
>>> transactions, the one that created the revision and the one that
>>> created the following revisions (valid from -> until).
>>> object graph as it was exactly at that time.
>>> Cheers
>>> /Eike
The Netherlands
Re: non containment references to large data sets [message #426152 is a reply to message #426127] |
Wed, 17 December 2008 06:15   |
Andrew,
Comments below...
Andrew H schrieb:
> [...] I agree that it would be preferable to have it all in one place
> with one persistence solution. This will certainly be what we will aim
> for.
> EMF. This was so that we were comfortable we would have an acceptable
> answer for all the things we need to do with our models (GUI, business
> rules, transformation, persistence, serialisation to / from XML, use
> in JEE & Web services etc).
> itself and transforming it for integration with various systems.
> Persistence isn't till the next phase, but unfortunately I have had to
> anticipate some aspects of persistence (next phase) now. These relate
> to static data.
> transactional data with Teneo because Teneo is based on hibernate
> which I know pretty well is a proven industry approach. This was
> enough to give the tick to persistence and for a high level plan.
> Teneo was an excellent fit for the transactional data.
> I assumed simply that the same approach would fit well. However, our
> static data has some differing requirements to our transactional data.
> a small part of the model in memory.
> for static data needs to provide a virtual window on the the persisted
> static data, so that it can resolve any URI's for these objects
> without needing to hold the entire database in memory.
> but I expect that there could be quite a lot of work involved. Work
> that seems to already be done by CDO.
> data persistence that I feel I understand well and am very comfortable
> with, but only a potential answer for static data that I don't
> understand at all yet.
> right now. Thanks to your feedback, at least I know a little more now.
> That whilst there can be some possibilities of having a CDO solution
> for static data and a teneo one for transactional data it is likely to
> be less than ideal so the most likely outcome is to choose one over
> the other.
I understand all the arguments pro Hibernate (including all the ones
that Martin gave) and that Teneo is a good fit between EMF and Hibernate.
That's why we have developed a Teneo-based HibernateStore for CDO. I'd
see it as an additional layer between EMF and Teneo with all the
possible advantages and draw-backs tat additional layers might impose.
If you don't need the additional advantages (or can't live with possible
disadvantages) for only parts of your data you should, at least in the
mid term, be fine with Teneo's new support for external references.
Since support for these is now in CDO and Teneo I really hope that we
will soon integrate this into our HibernateStore (CDO/Teneo integration)
as well.
> [...] Right so for a revision of one of our Transactions (sorry to
> overload the term here but I'm referring to our transactional data) I
> could determine the timestamp for its creation and use that to
> unambiguously determine the correct revision for the static data that
Yes, this happens automatically in CDO.
Cheers
/Eike
Re: non containment references to large data sets [message #426170 is a reply to message #426142] |
Wed, 17 December 2008 18:31   |
Hi Martin
Let me start by saying that I was very impressed with Teneo when I
evaluated it a month or two ago. What I was able to achieve in the short
time I spent with it was quite extraordinary. And the responsiveness of
yourself and all the EMF teams gives newcomers like myself a lot of
confidence in jumping on the EMF band wagon. So a big thanks to all.
Most of what we do fits very well within the standalone mode you outline
below.
This is why I evaluated Teneo only and not CDO as at the time I thought it
was a simple question.
JEE, Web Services, business services with business logic, plenty of
different searches across our data etc. are all major pieces.
I really do want the static data and transactional data stored together in
the database. We will undoubtedly want to do searches that span the two.
For example we may want to find all the transactions that a given person
is involved in. This could simply be searching on the person and joining
on to Transaction.
When we capture the Transaction in the GUI I want to wire it into the real
static data objects as this will make writing business rules that span
them easy. But when we send the transaction for processing (business
process, persistence etc.) I want to send only proxies for the static data
associated with it. When this reaches its destination it will need to be
reunited with its static data. And when persisted I'd like it attached
properly to it (not external). Similarly when we pull the transaction out
later.
So this is the real complication on the standalone Teneo approach. How to
manage this way of working with static data. So that it is associated
properly with the transactions, serialised as proxies, and reunited with
the static data wherever it needs to be, persisted with the static data
etc.
Its really this aspect that seems to fit well with (my limited
understanding of) CDO.
Do you have any thoughts on how to satisfy this requirement in a
standalone Teneo approach?
One thing that may help in this is that the transactions themselves are
predominantly containment relationships. But all the relationships to
static data are not.
Incidentally, Web Services is still an unknown at this stage. The story
for EMF + JEE Web Services is not good thanks to JAXB being welded into
that stack. When I have time I will explore the Spring Web Service path as
Spring tends to be much more customisable. Their new app server may be
interesting for us.
When I queried on the list about this a while ago someone mentioned they
were looking into this but I never heard back.
regards
Andrew
Martin Taal wrote:
> Hi Andrew,
are also some other
within CDO.
annotations
> relational schema)
annotations).
> standalone:
from the db.
in Teneo.
> gr. Martin
> Andrew H wrote:
>> Thanks Martin
>> cheers
>> Andrew
>> Martin Taal wrote:
>>> Hi Andrew,
>>> before)
>> I have started to
>> for adding the same
>>> somewhere).
>>> gr. Martin
>>> Eike Stepper wrote:
>>>> Andreww,
>>>> Comments below...
>>>> Andrew H schrieb:
>>>>> Hi Eike
>>>> Cheers
>>>> /Eike
Re: non containment references to large data sets [message #426174 is a reply to message #426152] |
Wed, 17 December 2008 21:34   |
Thanks Eike
I'll take a close look at CDO in the new year and get a feel for just what
those pros and cons are.
Thanks again for your help
regards
Andrew
Eike Stepper wrote:
> Andrew,
> Comments below...
>> for.
>> to static data.
>> the other.
> as well.
> Cheers
> /Eike
Re: non containment references to large data sets [message #426177 is a reply to message #426170] |
Thu, 18 December 2008 00:36   |
Hi Andrew,
As Teneo also supports EMFResources you can read transactional data in one HibernateResource and
static data in another HibernateResource (both resources sharing the same Hibernate Session). Then
when serializing the transactional resource to xml/xmi (to send the data accross) the references to
the static data are handled as references (so not contained in the xml/xmi). Then when deserializing
the static data is again read from the db. The hibernate (EMF) resources support standard hibernate
lazy loading behavior (using cglib proxies and lazy loaded lists).
One thing you have to take into account is that Teneo is more a server oriented solution (although
there are people who use it at client side also) than an Eclipse RCP-oriented solution. CDO has much
better support for Eclipse RCP and also for synchronising the rcp client with a server running the
CDO server software (and CDO has many other nice features).
So which fits best also depends on where most of the business logic runs.
gr. Martin
Andrew H wrote:
> Hi Martin
> below.
> it was a simple question.
> in the database. We will undoubtedly want to do searches that span the
> two. For example we may want to find all the transactions that a given
> person is involved in. This could simply be searching on the person and
> joining on to Transaction.
> real static data objects as this will make writing business rules that
> span them easy. But when we send the transaction for processing
> (business process, persistence etc.) I want to send only proxies for the
> static data associated with it. When this reaches its destination it
> will need to be reunited with its static data. And when persisted I'd
> like it attached properly to it (not external). Similarly when we pull
> the transaction out later.
> to manage this way of working with static data. So that it is associated
> etc.
> as Spring tends to be much more customisable. Their new app server may
> be interesting for us.
> regards
> Andrew
> Martin Taal wrote:
>> Hi Andrew,
>> ago) has
> are also some other
> within CDO.
>> environments as
>> custom
>> has a
> annotations
>> match
>> relational schema)
>> used
>> (using
> annotations).
>> enough
>> standalone:
>> UserType when
>> owner
> from the db.
>> data
> in Teneo.
>> there.
>> gr. Martin
>> Andrew H wrote:
>>> Thanks Martin
>>> i.e. its not going to be as clean as if we went straight teneo for
>>> both or CDO w Teneo for both?
>>> cheers
>>> Andrew
>>> Martin Taal wrote:
>>>> Hi Andrew,
>>>> transient
>>>> other
>>>> before)
>>> I have started to
>>>> denote an
>>>> basis
>>> for adding the same
>>>> in the
>>>> somewhere).
>>>> gr. Martin
>>>> Eike Stepper wrote:
>>>>> Andreww,
>>>>> Comments below...
>>>>> Andrew H schrieb:
>>>>>> Hi Eike
>>>>>> all the time so a simple EMF / Teneo solution would probably work
>>>>>> well. But anything that processes our transactions would need to
>>>>>> resolve the associated static data and it seems like CDO would do
>>>>>> this nicely.
>>>>>> for our static data but not for our transactional, can that work?
>>>>>> i.e. our transactional models would not be CDO models (just normal
>>>>>> EMF) but our static data ones would be.
>>>>>> to know if its an all or nothing proposition.
>>>>> to use multiple CDOResources (possibly from/to multiple model
>>>>> our back-end are not yet uptodate with this framework feature.
>>>>> We're planning to work on this issue until 2.0 GA.
>>>>> a good choice, but if you already decide to use CDO for some data,
>>>>> why not use it for all data. You could still choose different CDO
>>>>>> like when the transaction was created. Does this work only off
>>>>>> timestamps or is there a way to associate a transaction with a
>>>>>> particular version of our static data?
>>>>> back-end adapter (although we discussed support in the other
>>>>> adapters as well). I guess adding this feature to our
>>>>> Teneo/Hibernate adapter will be a particular challenge ;-)
>>>>> like this: Each committed transaction creates a set of revisions
>>>>> for the new and changed objects. The ID of such a transaction (==
>>>>> revision set) is the timestamp of the commit operation. Each
>>>>> revision carries its own version number together with the
>>>>> timestamps of two transactions, the one that created the revision
>>>>> and the one that created the following revisions (valid from ->
>>>>> until).
>>>>> Cheers
>>>>> /Eike
The Netherlands
Re: non containment references to large data sets [message #426197 is a reply to message #426177] |
Thu, 18 December 2008 18:05  |
So it may be possible to build a client side HibernateResource for static
data that works off a hibernate cache. I'll look into this in the new year
thanks again for your help
Martin Taal wrote:
> Hi Andrew,
> gr. Martin
> Andrew H wrote:
>> Hi Martin
>> below.
>> etc.
>> regards
>> Andrew
>> Martin Taal wrote:
>>> Hi Andrew,
>>> ago) has
>> are also some other
>> within CDO.
>>> environments as
>>> custom
>>> has a
>> annotations
>>> match
>>> relational schema)
>>> used
>>> (using
>> annotations).
>>> enough
>>> standalone:
>>> UserType when
>>> owner
>> from the db.
>>> data
>> in Teneo.
>>> there.
>>> gr. Martin
>>> Andrew H wrote:
>>>> Thanks Martin
>>>> cheers
>>>> Andrew
>>>> Martin Taal wrote:
>>>>> Hi Andrew,
>>>>> transient
>>>>> other
>>>>> before)
>>>> I have started to
>>>>> denote an
>>>>> basis
>>>> for adding the same
>>>>> in the
>>>>> somewhere).
>>>>> gr. Martin
>>>>> Eike Stepper wrote:
>>>>>> Andreww,
>>>>>> Comments below...
>>>>>> Andrew H schrieb:
>>>>>>> Hi Eike
>>>>>>> this nicely.
>>>>>> until).
>>>>>> Cheers
>>>>>> /Eike
Current Time: Sun Jul 20 12:08:18 EDT 2025
Powered by FUDForum. Page generated in 0.08736 seconds
