Home » Modeling » EMF » Dependency on org.eclipse.core.runtime in generated model plug-in
Dependency on org.eclipse.core.runtime in generated model plug-in [message #425776] Mon, 08 December 2008 10:40 Go to next message
Heya,
I just asked myself why a generated EMF model plug-in contains a
dependency to org.eclipse.core.runtime?
Felix
Re: Dependency on org.eclipse.core.runtime in generated model plug-in [message #425793 is a reply to message #425776] Mon, 08 December 2008 13:44 Go to previous messageGo to next message
Felix,
Usually it's easy to find out when you try to remove the dependency and
see what happens.
AFAIK at least the extension markup in the plugin.xml requires a
dependency on org.eclipse.core.runtime (at least on something within).
Can you describe your concerns with this dependency?
Cheers
/Eike
Felix Dorner schrieb:
> Heya,
> Felix
Re: Dependency on org.eclipse.core.runtime in generated model plug-in [message #425799 is a reply to message #425793] Mon, 08 December 2008 16:18 Go to previous messageGo to next message
Hey Eike,
> see what happens.
At what time? Compile? Run?
Not sure I understand what you mean.
Its not a concern. I just wanted to know why it's needed.
Felix
Re: Dependency on org.eclipse.core.runtime in generated model plug-in [message #425800 is a reply to message #425799] Mon, 08 December 2008 16:42 Go to previous messageGo to next message
Felix,
EMF's runtime uses things, like Eclipse's plugin class, from that. You
could try to remove it and see what the compiler complains about...
Felix Dorner wrote:
> Hey Eike,
>> and see what happens.
> Felix
Re: Dependency on org.eclipse.core.runtime in generated model plug-in [message #425802 is a reply to message #425800] Mon, 08 December 2008 17:04 Go to previous messageGo to next message
Hey Ed,
If I remove it from the model plug-in, there's nothing that the compiler
complains.
In contrast is the edit plug-in which requires the Plugin class, at
compile time. At runtime its absence is detected and the standalone
implementation takes over, nicely explained in the new book.
public abstract class EMFPlugin implements ResourceLocator, Logger
public static final boolean IS_ECLIPSE_RUNNING;
static
boolean result = false;
try
result = Platform.isRunning();
catch (Throwable exception)
// Assume that we aren't running.
IS_ECLIPSE_RUNNING = result;
Re: Dependency on org.eclipse.core.runtime in generated model plug-in [message #425804 is a reply to message #425802] Mon, 08 December 2008 17:11 Go to previous message
Felix,
Oh yes, I forgot that the model plugin doesn't always have a plugin. In
any case, the model depend on EMF which depends on the core Eclipse
runtime, so indirectly you always depend on it...
Felix Dorner wrote:
> Hey Ed,
> compiler complains.
> static
> try
>> You could try to remove it and see what the compiler complains about...
Previous Topic:[CDO] Restore Resource from Audit
Next Topic:Springsource objectweb tree and attribute bundle versions
Current Time: Sat Jul 19 21:57:07 EDT 2025
Powered by FUDForum. Page generated in 0.04107 seconds
