[CDO] Restore Resource from Audit [message #425786] |
Mon, 08 December 2008 12:24  |
In my application I have implemented an optional action "SaveAsVersion" in
order to enter version name and comment before saving the CDOResource. With
the name and comment I also store the timestamp from right after the save
(session.getRepositoryTime()).
The idea is that I would retrieve the Audit from a named save point by using
session.openAudit(new ResourceSetImpl(), timeStamp), and then switch the
root object from the audit view to the running transaction. In this way I
hoped to be able to "load" an older state of the root object's containment
tree and restore as the latest.
I found a promising thread by Andr
Re: [CDO] Restore Resource from Audit [message #425791 is a reply to message #425786] |
Mon, 08 December 2008 13:41  |
Bjoern,
Some comments in addition to Simon's below...
session.getRepositoryTime() is only an approximate repository time. In
CDO 2.0 I would recommend to use transaction.getLastCommitTime() which
gives exactly the time that is also stored in the revisions themselves.
As Simon noticed, it is not possible to change objects in an audit view.
So you can not *move* it to another transaction. Maybe you can copy
selected values from the "old" object in the audit view to a "new"
object inthe transaction?
> I found a promising thread by András Ökrös "[CDO] Version handling
> ( http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg3 5324.html)"
> partly dealing with this matter. The key sentence for me was: "Just detach
> objects from the audit view and attach them to the transaction before
> committing it".
Apologies. The intended semantics of the term "detach" changed several
times in the past. While formerly it meant *local* detachment of an
object from a view, nowadays it means physical removal of the object
from the persistent object graph. And this can only be done in a
transaction.
> I have tried this in different ways either by removing and adding between
> the resources (audit and current transaction) as well as casting to
> InternalCDOObject and using the CDUStateMachine.INSTANCE.detach resp.
> CDUStateMachine.INSTANCE.attach, unfortunately without success.
As I said above, audit views do not permit any object modifications,
including addition or removal from the graph. And using internal code
does not seem like a good idea either. I think the only valid approach
is to *copy* data instead of *move* it.
Does this help?
Cheers
/Eike
> I would really appreciate to know if there is any recommended way to do
> this.
> Bjoern
FUDForum. Page generated in 0.03747 seconds
