Home » Modeling » EMF » Number format exception in genrated editor for feature with ExtendetMetaData
Number format exception in genrated editor for feature with ExtendetMetaData [message #425706] Fri, 05 December 2008 06:20 Go to next message
in my model I have a feature EInt with an annotation
ExtendedMetaData with a details entry
totalDigits -> 11
when now editing this feature in the editor
I am allowed to enter 10 digits. With entering the
11th digits I get the number format exception.
When changing the totalDigits to an other number
I can enter totalDigits-1.
By the way, where can I look up which entries
for ExtendetMetaData are possible?
Thank you
Torsten Link
Re: Number format exception in genrated editor for feature with ExtendetMetaData [message #425711 is a reply to message #425706] Fri, 05 December 2008 06:50 Go to previous messageGo to next message
--------------010102040904070400000805
Torsten,
Comments below.
Torsten Link wrote:
> Hello,
> totalDigits -> 11
Such an EAnnotation only makes sense on an EDataType and will be
ignored when it's on a feature.
How many digits can an int represent?
> With entering the
If you see a number format exception, that's produced by Java because
the number cannot be parsed. If you total digits thing was having an
impact, you'd see a nice message of the form "The value '...." must have
at most 5 digits.
I'm doubtful of this claim. I think this is assumed behavior, not
actual behavior, given that the annotation actually has no impact where
you put it.
This document describes the annotations produced from a schema and while
you can add those annotations to any model, they can only be used in the
same context in which they would appear if your model had started out as
a schema.
XML Schema to Ecore Mapping
< http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf>
> Thank you
> Torsten Link
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
<title></title>
</head>
Torsten,<br>
<br>
Comments below. <br>
<br>
Torsten Link wrote:
<blockquote cite="mid:hdfn06-cb8.ln1@link-lap.qatools.de" type="cite">
<pre wrap="">Hello,
totalDigits -&gt; 11
</pre>
</blockquote>
Such an EAnnotation only&nbsp; makes sense on an EDataType and will be
ignored when it's on a feature.<br>
<pre wrap="">
I am allowed to enter 10 digits. </pre>
</blockquote>
How many digits can an int represent?<br>
<pre wrap="">With entering the
</pre>
</blockquote>
the number cannot be parsed.&nbsp; If you total digits thing was having an
have at most 5 digits.<br>
<pre wrap="">
</pre>
</blockquote>
I'm doubtful of this claim.&nbsp; I think this is assumed behavior, not
you put it.<br>
<pre wrap="">
</pre>
</blockquote>
while you can add those annotations to any model, they can only be used
in the same context in which they would appear if your model had
started out as a schema.<br>
<blockquote><a
href=" http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf">XML
Schema to Ecore Mapping</a></blockquote>
<pre wrap="">
Thank you
Torsten Link
</pre>
</blockquote>
</body>
</html>
--------------010102040904070400000805--
Re: Number format exception in genrated editor for feature with ExtendetMetaData [message #425720 is a reply to message #425711] Fri, 05 December 2008 08:21 Go to previous message
Hi Ed,
sorry it was accidently that this behavior appear.
The first Time with 10 Digits I enter a number starting
with 9, than I increase the digits and start my number with
1. So it is the Integer which causes the problem.
Ed Merks wrote:
> Torsten,
> Comments below.
> Torsten Link wrote:
>> Hello,
>> totalDigits -> 11
>> With entering the
> at most 5 digits.
> you put it.
> a schema.
>> Thank you
>> Torsten Link
Previous Topic:How to cross reference between models.
Next Topic:ExtendedMetaData and inheritance
Current Time: Sat Jul 19 12:14:19 EDT 2025
Powered by FUDForum. Page generated in 0.09266 seconds
